Old 05-30-2014, 06:21 AM   #1
86socal
86socal's Avatar
Drives: White frs
OEM end link with coilovers bad?
Using OEM endlink with coilovers a bad idea?
86socal is offline   Reply With Quote
Old 05-30-2014, 07:32 PM   #2
86socal
86socal's Avatar
Drives: White frs
Bump
Old 05-30-2014, 07:34 PM   #3
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Depends on how low you are. If you suspect the end link is hitting the lca, then get shorter end links.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
The Following User Says Thank You to SportInjected For This Useful Post:
86socal (05-30-2014)
Old 05-30-2014, 11:16 PM   #4
coupeae86
Drives: 2013 FRS 1986 Corolla GTS
I'll start off by saying I am not certain, but this is what I think. If you have a fully threaded body coilover you need the adjustable end links. Because to lower the car you are shortening the entire lower strut mount. Am I wrong?
coupeae86 is offline   Reply With Quote
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 01:09 PM
Rear toe link and toe changes Suberman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-30-2014 07:49 AM
Toe Link Install problems SLICVIC Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 03-30-2013 09:20 PM
Gearbox: Cable Link or Mechanical Link? Marrk BRZ First-Gen (2012+) — General Topics 42 07-02-2012 12:45 AM
