Old 01-13-2014, 01:41 PM   #337
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
No. There is a little built in though.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 04-25-2014, 08:57 AM   #338
makinen
makinen's Avatar
Drives: Toyota 86
I think nobody cares this product now, but I have kept warranty-replaced mounts to use later.
Now I prepare stock spring seats to use with conical washers.
Using a hand drill, the spot-welded flat washer was removed.
The conical washer will be used as a replacement.
I'll check how long the mounts will last with this setup.
makinen is offline   Reply With Quote
The Following 2 Users Say Thank You to makinen For This Useful Post:
ATL BRZ (04-27-2014), DAEMANO (05-16-2014)
Old 05-26-2014, 10:31 AM   #339
makinen
makinen's Avatar
Drives: Toyota 86
I've installed Com-C mounts with RCE Tarmac springs and Koni Yellows.
This is a stock spring perch on the Koni Yellow.
And a spring perch without flat washer on the Koni.
With a conical washer. As you can see, the conical washer is slightly thicker than the flat welded washer.
Alignment spec:
Front camber -3, toe 0
Rear camber -2, toe 0
In the last year, it failed after a day of HPDE. Only the mounts are installed to the stock struts.
This time, they have survived after a day of HPDE on wet road plus over 600 km trip to and from the Korean International Circuit. Wet condition may give less load to the mounts but I think this signal is positive.
The Following User Says Thank You to makinen For This Useful Post:
Calum (05-26-2014)
Old 05-26-2014, 11:28 AM   #340
wootwoot
Drives: FRS
I had to to send a nasty email to every single address on the whiteline web page before Jan would finally respond. Basically, I had to make him look like a **** in front of everyone he works with before I finally got my money back.... Worked for me.
The Following User Says Thank You to wootwoot For This Useful Post:
feldy (05-26-2014)
Old 05-26-2014, 05:39 PM   #341
Calum
That Guy
Drives: 2013 asphalt FRS MT
Attachment 79871
Attachment 79872
Attachment 79873
Alignment spec:
So drilling was the best way to get the flat washers off. Did you try any other method?
Old 05-26-2014, 05:53 PM   #342
feldy
feldy's Avatar
Hope his works. I was going to give this same idea a shot. But ended up wth better plates. I also had to email the entire whiteline email address to get my money back.
Attachment 79871
Attachment 79872
Attachment 79873
Alignment spec:
The Following User Says Thank You to feldy For This Useful Post:
makinen (05-27-2014)
Old 05-26-2014, 08:20 PM   #343
makinen
makinen's Avatar
Drives: Toyota 86
A conventional drill bit didnot work.
A spot weld cutter was used and the result was great.
I don't know exact size of it. You may guess from the photos in my previous post.
Calum (05-26-2014)
Old 05-30-2014, 02:39 PM   #344
Calum
That Guy
How are they holding up with the conical washers?
Old 05-31-2014, 03:28 PM   #345
Proof
Proof's Avatar
Drives: 2007 STI Limited / 2014 BRZ Limited
Also wondering. Mine have been on for 1000 miles but when I move the car out of the garage I get a loud pop from both sides. Only happens once after the car has sat for a night. Then never happens the rest of the day.
Proof is offline   Reply With Quote
The Following User Says Thank You to Proof For This Useful Post:
Calum (06-01-2014)
Old 05-31-2014, 10:09 PM   #346
makinen
makinen's Avatar
Drives: Toyota 86
I got small pop noise sometimes when mount nuts are not tightened.
Koni Yellows have not enough threads left with conical washers. The urethane(or whatever) stopper at the top part of the mount nut cannot contact with the shaft of Koni. So those nuts sometimes are loose.
Except that problem, currently working well.
Calum (06-01-2014)
Old 08-29-2014, 11:03 PM   #347
cnk
Drives: '13 DGM BRZ Limited
In case anyone is still waiting on Whiteline for an update, I got one from Jan last week. They have tried a few fixes, but they all did not meet durability standards. They are testing some other fixes now, but no ETA.
As for me, I removed the Comp-C's this past Monday and replaced them with HVT camber plates. No issues at all with the HVT's. When I inspected the bearings in the Comp-C's, the passenger side was extremely notchy and would stick which would explain why I would get coil bind at times where the bearing would stick and then release causing a popping noise from the spring. The driver's side was quiet until recently when I heard some coil bind as well. Upon inspection, the bearing was a lot smoother, but you could feel some graininess from the bearing with your fingers so it looks like it was only a matter of time before it would start having issues.
I'll post up if I get any more updates from Whiteline.
The Following 2 Users Say Thank You to cnk For This Useful Post:
OGSCION (08-30-2014), Pat (08-31-2014)
Old 10-01-2014, 08:05 PM   #348
makinen
makinen's Avatar
Drives: Toyota 86
Hello,
Finally the day came.
My RH Com-C mount started to make noise.
Compared to LH one, the rubber looks bent slightly.
I'll go back to the stock or HVT.
Old 05-27-2015, 12:35 AM   #349
piaoyi
piaoyi's Avatar
Drives: Sakura Miku
I have the clunking noise and was wondering if anyone has a solution for it
Niknej-jenkiN
piaoyi is offline   Reply With Quote
Old 05-27-2015, 05:15 AM   #350
Calum
That Guy
Stock, group-n, or a camber plate. Sorry.
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-11-2013 11:31 PM
Buyer Beware: Motor Mounts cobrabyte Engine, Exhaust, Transmission 5 01-04-2013 08:14 PM
Autocross Camera Mounts? fritzy BRZ First-Gen (2012+) — General Topics 7 08-03-2012 10:48 PM
SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports Font Motorsports Interior Parts (Incl. Lighting) 2 07-03-2012 06:43 PM
Dash Mounts for gadgets smbrm Cosmetic Modification (Interior/Exterior/Lighting) 0 06-28-2012 07:07 PM
