Old 05-30-2014, 01:23 AM   #1
Augora
Hood plastic removal
On the brz hood, there's a piece of plastic attached to the underside of the hood at the rear driver's side corner. It's held in by 3 "clips" which have a philips hole in them. I pulled on them but they seem rigidly stuck on there, any idea how to remove this piece? Thanks.
Augora is offline   Reply With Quote
Old 05-30-2014, 01:28 AM   #2
Colombo
Drives: '13 BRZ
Gently unscrew them and then pull the clip out.
Colombo is offline   Reply With Quote
Old 05-30-2014, 01:45 AM   #3
Augora
That simple eh? When I gave them a turn they seemed to be free spinning, but there really is something they are unscrewing from?
Old 05-30-2014, 10:12 AM   #4
Colombo
Drives: '13 BRZ
They just release from the base but don't actually come out. You can't apply too much force inward or they will just stay in the locked position.
Old 05-30-2014, 10:47 AM   #5
andrew20195
Drives: 2013 Subaru BRZ
If the whole clip is spinning, use your fingers to hold the outside of the clip and unscrew the center
andrew20195 is offline   Reply With Quote
Old 05-31-2014, 09:11 AM   #6
Norton 850
I believe those are one-way push-in fasteners. You will need to pry on the head to get them out and doing so, may ruin them.
Why do you want to remove that plastic piece?
Norton 850 is offline   Reply With Quote
Old 05-31-2014, 02:04 PM   #7
andrew20195
They should just be push in, screw out type clips. A quarter turn counterclockwise should unlock them, and as long as you're careful removing them they should be reusable.
Old 06-01-2014, 07:52 AM   #8
Augora
Thanks chaps, came out easily once stabilized the outer ring (1/4 turn and they popped right out).
Was taking out the piece for some engine bay detailing, wanted to avoid spraying anything on the paint.
Old 06-01-2014, 09:33 AM   #9
Norton 850
Ok, I understand now.
In better light I can actually see that these fasteners are made from two pieces. And while holding the outer piece I was able to rotate the inner mandrel, which allows the fastener to be pulled right out.
Carbon hood and hood dampers?? ft86me Cosmetic Modification (Interior/Exterior/Lighting) 15 10-19-2013 12:57 PM
Looking for vis aem hood or seibon fa hood ready to ship Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-30-2013 12:25 AM
Looking for Hood Dampers meant for CF hood. Vicious LED Scion FR-S / Toyota 86 GT86 General Forum 3 12-31-2012 03:47 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 11:06 PM
