#57 |
Autocrosser
Drives: Asphalt 6-speed FR-S
I am not certain about using the LEDs as DRLs, because I had the dealership turn off the DRLs long before installing the 10 Series headlamps. The lights are controlled entirely by the stalk on the steering column. The only time the LEDs or HIDs turn on is when I turn the stalk 1 click and 2 clicks respectively.
#58 |
Drives: Asphalt FRS
Sounds like 10 series headlights would have to remove the parking + on the FRS body side and replace with a custom wire from the DRL + up to both headlights where the white wire (LED Strip) is to achieve DRL functionality, but lose parking led light.
#59 |
Drives: Asphalt FRS
Anyone found a way to wire up the 6 pin 10 series headlights for full functionality + the DRL? Simply rewiring the 6 pins will not give drl functionality, but instead it will function like the JDM 86 where they have no drls. As seen as in this video
[ame="https://www.youtube.com/watch?v=aIaY7hOk0CM"]https://www.youtube.com/watch?v=aIaY7hOk0CM[/ame] As far as I know: JDM = 6 pin no drl, LEDs turn on with Lowbeam HID (LED pin = weaker led wire available) USDM = 6 pin with DRL, LEDS do not turn on with Lowbeam HID (LED pin = stronger led wire available) Europe Spec = 7 pin with DRL, LEDS also turn on with lowbeam (Has both LED pins thus the 7 pins instead of 6) Last edited by FRSHunter; 05-10-2014 at 03:39 AM. |
#60 | |
Drives: 2019 BMW ///M4
Here you go http://www.ft86club.com/forums/showthread.php?t=44066
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#61 |
Drives: Asphalt FRS
Thanks, but I think it might be different for non 10 series frs with 10 series headlights
#62 | |
Am I correct in that the LED strip is the daytime light and comes on when you put the lights up one click. When you turn the headlights on the LED strip turns off? |
#63 | |
Drives: Scion FR-S Whiteout
The led strip will stay on with one click (parking mode) and two clicks (low beam). The led strip will not function as a true drl. Make sure you unplug the drl resistor when installing the lights. You got it disabled but best to be safe than sorry. Can fry your new headlights. Sent from my iPad using Tapatalk
If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious shit.
#64 |
Drives: 2013 Raven FRS MT
Is it easier to get a set of 10 series lights from the dealer now? Have not checked on it recently.
#65 | |
Online it is. Dealers might be too since monograms have them as well. Still pricey I think Sent from my iPad using Tapatalk
| The Following User Says Thank You to Calavera For This Useful Post: | AVodka14 (05-27-2014) |
#66 | ||
Autocrosser
#67 | |
Autocrosser
They aren't cheap, but they are OEM HIDs, so that's to be expected. Winjets were not around when I made the decision, but even in hindsight, I'm glad I bought the factory units versus the replicas. |
| The Following User Says Thank You to Fonzie517 For This Useful Post: | AVodka14 (05-30-2014) |
#68 |
Drives: White out Scion Frs
What color wire from the headlight that need to tap to the 12v resistor line? to get DRL running constantly?
THanks
#69 |
Cool Guy
#70 |
Drives: 2015 Halo FR-S
So the standard 6 pin harness doesn't physically fit into the 8 pin harness size-wise at all - I'm confused about how re-pinning it will work? Wouldn't you have to also buy an 8 pin harness? Sorry if I'm just having a dense moment here.
| WTT: FR-S headlamps for BRZ | Nothing | Southeast | 2 | 03-30-2013 07:41 AM |
| Auto-Off Headlamps | nktech | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 12-10-2012 10:51 AM |
| Purple/Blue headlamps | BMWDavid | Other Vehicles & General Automotive Discussions | 0 | 11-24-2012 02:40 PM |
| Installing GT86 AC unit? | SupraLove | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-07-2012 03:08 PM |
| limited 86 headlamps | SuperDave | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 08-04-2012 04:41 AM |
