Old 05-28-2014, 10:31 AM   #15
akyp
Drives: 2012 86
Originally Posted by shiv@vishnu View Post
In v1.60, we have made the following changes:
-Added support for A01F ROM
-Extensively revised Stage 1 mapping (new MAF scaling, new fuel mapping, new ignition mapping, tweaked VVT mapping)
-Revised Stage 2 (revised ignition mapping)
-Added both 91 an 93 oct map variants
-No changes to E85 maps at this time.
By the time the v1.60 maps are released, there may be a few more changes. But that is all for now
Thanks for your work.
For those of us with 98 RON fuel (no ethanol), should we use 91 or 93 maps? What are the primary differences?
akyp is offline   Reply With Quote
Old 05-28-2014, 12:07 PM   #16
Lytheum
Drives: 2013 BRZ Premium 6MT
will we have to wait for a .bin release of 1.6? have 700c still and cant use the .dev file.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 05-28-2014, 01:35 PM   #17
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by aero.kit View Post
And what about maps for 700G series ?
I mean for Crawford BPB .
And what about BPB + Vortech Kit .
Thank you
Do you have both? There's not much to gain from the BPB if you have a Vortech kit installed. Does your experience differ?
98 is equivalent to 94 AKI, so I would run the 93 map. I'm assuming the 93 is more aggressive and runs more advanced timing.
TM is offline   Reply With Quote
Old 05-28-2014, 01:40 PM   #18
aero.kit
Drives: GT86
At the moment i don't have.
aero.kit is offline   Reply With Quote
Old 05-28-2014, 03:29 PM   #19
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
a quote from shiv about the BPB and Phantom, but I assume the same results with any Force Induction application.
"Shiv:
Anyway, tested the BPB yesterday with both the Phantom and NA (full bolt on- OFH + Custom bat-back) set ups. With a tank full of 93oct. With the Phantom, it doesn't look like a good match. Lost power just about everywhere. It didn't look promising so I didn't bother with custom tuning with the BPBs. I will probably give it a try when more time permits though. But these results make sense as more airflow would suggest shortening the runners are the way to go."
here is the full post: http://www.ft86club.com/forums/showp...&postcount=218
Target70 is offline   Reply With Quote
Old 05-28-2014, 03:45 PM   #20
aero.kit
Drives: GT86
"Shiv:
thank's
Old 05-29-2014, 10:28 PM   #21
rickjames
rickjames's Avatar
Drives: Red Toyota (FT)86 GT MT
Hi Shiv,
I'm running a modified Stage 1 700G map (for Australian fuels). Working awesome!
Just FYI:
FKLC is only active in USDM ROMs right now (C and D family)
should be FLKC.
When will the new maps be available??
rickjames is offline   Reply With Quote
Old 05-29-2014, 10:34 PM   #22
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Patiently waiting on NA BPB+EL+e85 tune
Carlitoz3 is offline   Reply With Quote
Old 05-29-2014, 10:44 PM   #23
Malt
Drives: 2015 WRX
Pretty sure shiv said that with E85 and the BPB's there wasn't much gains to be had. Looking for the quote now.
Malt is offline   Reply With Quote
Old 05-29-2014, 11:09 PM   #24
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Yes, BPB and E85 isn't a really good match since the BPB take away from top end power (above 6500rpm). And that is were E85 maps really shine!
Shiv@Openflash is offline   Reply With Quote
Old 05-29-2014, 11:14 PM   #25
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
You aren't kidding. I have been paying very specific attention to my driving and the performance of the car since I am going to be racing at the Wicked Big Meet on the 8th and I feel two distinct (but small) bumps in power. One where the cam phasing is and one higher up at the top. I am more focused on the feel than the numbers though.
Luckrider is offline   Reply With Quote
Old 05-29-2014, 11:22 PM   #26
AL008
Drives: Celica 04
Originally Posted by AL008 View Post
When you say: Revised Stage 2, will Stage 2 get all of those "Extensive revisions" that stage 1 got such as (new MAF scaling, new fuel mapping, new ignition mapping, tweaked VVT mapping)?
@shiv,
Would you be able to provide any insight into this please.
Thanks.
AL008 is offline   Reply With Quote
Old 05-30-2014, 05:35 AM   #27
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
@shiv@vishnu is the v1.60 that you put in your first post good to download? I'm just getting ready to got to stage 2 UEL on 91oct so would that be my most up to date tune?
Triumphrider is offline   Reply With Quote
Old 05-30-2014, 05:43 AM   #28
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
That's just a log of the 1.60 tune.
Openflash manager data display problem. mid_life_crisis Software Tuning 6 05-14-2014 09:22 AM
OpenFlash Tablet: Multi-Gauge Function and FLKC logging Shiv@Openflash Software Tuning 52 05-08-2014 08:30 PM
OpenFlash Manager 1.07.1 Mad_Hatter Software Tuning 24 04-24-2014 06:46 AM
Now Available: OpenFlash Manager 1.04 Shiv@Openflash Software Tuning 37 12-14-2013 10:02 PM
