Old 05-29-2014, 01:32 PM   #1
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
liqui moly mos2 additive opinion
So about an our ago I dumped in a can of mos2 into my engine oil which has mobil 1 extended performance 5w30. First thing I noticed is they the engine is a lot quieter. From what I heard from bob is the oil guy forums is that is an additive that works compared to many snake oils.
Rocket.BRZ is offline   Reply With Quote
Old 05-29-2014, 01:48 PM   #2
Dezoris
Dezoris's Avatar
I always have to ask this, why use an additive when you can just use an oil with high moly?
Old 05-29-2014, 02:01 PM   #3
Rocket.BRZ
a lot of oil companies don't use moly as much as they use to. Maybe it's because they have found something better or maybe it's to save money I don't really know. But moly is proven to provide excellent lubrication.
Old 05-29-2014, 02:12 PM   #4
Dezoris
Dezoris's Avatar
The reason I run redline 0w20 is it's more like a 0w30 and has one of the higher moly contents. Usually in the 650 range on UOA.
I used to use a Moly additive in my oil 10 years ago, until UOA got common enough to find what I was looking for.
additive, liqui moly, mos2, oil additive
RS-R RAN-UP oil additive Symbiont Engine, Exhaust, Transmission 46 12-10-2014 04:15 PM
Subaru OEM Coolant System Additive JDKane527 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 05-27-2014 01:24 PM
liqui moly synthoil high tech 10w60 Djen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-16-2013 04:22 PM
Opinion? cncnjn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 08-10-2013 11:00 PM
