Old 05-28-2014, 09:01 PM   #5783
stevo585
Drives: White 2014 BRZ
Originally Posted by shif7i7down View Post
I wanted to share my exciting experiment. My friend and i used a gtech (which is suppose to be fairly accurate) and got 3consistent. Et quarter mile run with the esc.
With both of us in the car, 2 of the runs produces a 14.1et and 1 run was 14.02 ,
All 3 runs are roughly 5.8sec 0 to 60mph.
Best money I've every spent on mods. EVER!
I've hit 14.6 on the OFT e85 stage 2 on a stock car. I would think 13's should be easy. Seems like no one has 1/4 mile tracked their car with the ESC?
stevo585 is offline   Reply With Quote
Old 05-28-2014, 09:10 PM   #5784
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
stock mt frs weight is roughtly 2786lbs, i weigh 160 my friend weighs 130.
so total combined 3076lbs.
MODS: esc 1.5 dump.
everything else is stock also take elevation into consideration also.
Thank You.
If you are at ~205whp, from ESC and 1.5 dump pack, from ~165-170whp, that is about +40whp.
If accurate, then compared to this: http://www.edmunds.com/car-reviews/t...ck-tested.html The extra low end torque of the ESC over the innovate makes quite a difference (.3sec)
stevo585: I've hit 14.6 on the OFT e85 stage 2 on a stock car. I would think 13's should be easy. Seems like no one has 1/4 mile tracked their car with the ESC?
14.6 on e85, at sea level, what did edmunds do to hit 14.8 completely stock?
If anyone has posted an actual track time I missed it.
but with dual dumps and bolt-ons shiv hit 217, I estimate 235whp with E85, that should be good for another .3 seconds off of 1/4 mile. I think we can hit 13.7
Target70 is offline   Reply With Quote
The Following User Says Thank You to Target70 For This Useful Post:
DAEMANO (05-28-2014)
Old 05-28-2014, 09:58 PM   #5785
shif7i7down
Erected Member
Drives: frs
Originally Posted by Target70 View Post
Thank You.
the way that the esc distributes power is very different then bolt ons. it's alot of low end acceleration up to redline.. i found that by launching at 2.5k rpm then as soon as you let off the clutch just wot all the way to redline letting the low end trq do all the work.
but yeah, with 217whp, you should hit 13.8 , that's with a 150lb driver.
@ 235whp you should be at 13.5
shif7i7down is offline   Reply With Quote
The Following User Says Thank You to shif7i7down For This Useful Post:
Old 05-28-2014, 11:32 PM   #5786
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
New 3rd gear log taken today, looks pretty solid. AFRs seem a bit high in the low RPM, but I don't normally stomp it from down there, so that could be a learning thing with the ECU (it was pulling fuel).
On a side note, the batteries aren't dipping as much now when the ESC is engaged (I believe that they were dropping into the 21.x before, now staying around 23). I'm also getting 38-40 MPG on the highway when cruising at ~70 now.
Phantom ESC - 3rd Gear Pull
alexand3r is offline   Reply With Quote
Old 05-29-2014, 12:08 AM   #5787
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Glad to see everyone is enjoying the system. Are any of the new guys not running the 1.5 pack?
Installed Mods:
Old 05-29-2014, 12:10 AM   #5788
shif7i7down
Erected Member
Drives: frs
from reading the post, sounds like everyone went for the 1.5 kit
Old 05-29-2014, 12:19 AM   #5789
TM
TM's Avatar
Drives: DGM BRZ 6MT
I didn't get mine yet. I think Rob forgot about me I emailed him again today and he said he has it available and will ship it tomorrow.
Can we start an owners thread that lists the owners and links to their shared experiences? A lot of the experiences any dynos are getting lost in this mega thread. I checked out the other FI owners threads and their lists ranges from 20-40 owners. I believe that we have about 20-30 users running this kit and the list will show others how many people are backing up this kit and running it successfully, which can help change people's perspective of an electric supercharger. I can organize it if you guys want.
TM is offline   Reply With Quote
The Following 3 Users Say Thank You to TM For This Useful Post:
enwave (05-29-2014), robwbright (05-29-2014), shif7i7down (05-29-2014)
Old 05-29-2014, 12:20 AM   #5790
shif7i7down
Erected Member
Drives: frs
Not a bad idea, we should start an owners thread.
Old 05-29-2014, 01:47 AM   #5791
TM
TM's Avatar
Drives: DGM BRZ 6MT
I've just spent about 1.5 hours combing through a chunk of this thread instead of sleeping.
I think I've compiled a list of about 70% of the ESC kit owners here. Not really sure who was part of the second batch.
http://www.ft86club.com/forums/showthread.php?p=1765486
The Following 2 Users Say Thank You to TM For This Useful Post:
DAEMANO (05-29-2014), Gums (05-29-2014)
Old 05-29-2014, 02:33 AM   #5792
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
Guys I still have plans on creating the walkthrough for the install but got side tracked with my lowering springs install and the fact that I'm giving senior finals and grades this week. I promise to do the work.
Here's the car at the moment:
Installed Mods:
The Following 5 Users Say Thank You to Sojhinn For This Useful Post:
alexand3r (05-29-2014), DAEMANO (05-29-2014), Gums (05-29-2014), nlowell (05-29-2014), robwbright (05-29-2014)
Old 05-29-2014, 06:45 AM   #5793
raven1231
Same here, he said it will be ready this week. He was going to ship it the first time he sent the controller back but I wanted to hold off to make sure it was working right first. I can't wait to have it all back up and running again . Estimated delivery was yesterday but it got stuck in customs for a few days . I'm hoping for today!
Old 05-29-2014, 07:53 AM   #5794
shif7i7down
Erected Member
Drives: frs
I got a quick question about the phantom tune. I'm scheduled for a dyno power pull next week Wednesday and i just wanted to make sure. If i want to do a baseline dyno,is the phantom tune save enough for me to just remove the compressor,install the stock intake tube and disarmed the esc with the toggle switch by the volt meter or do i have to flash back to stock Rom also?
Also forgot to mention that mph for the 14.02et gtech run was 105mph
DAEMANO (06-05-2014)
Old 05-29-2014, 08:05 AM   #5795
TM
TM's Avatar
Drives: DGM BRZ 6MT
To get a true baseline pull, I would flash back to stock.
Old 05-29-2014, 08:06 AM   #5796
raven1231
This is the only way it would be most accurate. However if you for whatever reason don't want to then I would pm shiv to make sure there wont be an issue.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
