Old 05-28-2014, 06:33 PM   #43
Trunksse
Drives: Firestorm FR-S
So if I understand correctly, the recommendation for a NA w/ boltons + E-85 would be to get any GF-5 0w-20 oil and cut my oil change interval down to 3-5K? Also, the highly recommended oils would be Red Line 0w-20 and Pennzoil Ultra Platinum 0w-20?
Trunksse is offline   Reply With Quote
Old 05-28-2014, 11:31 PM   #44
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Amsoil dominator 10w-30 if you are catless
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 05-29-2014, 06:27 PM   #45
Trunksse
I think I'll get the Amsoil Signature Series 0w-20 since its GF-5 and change the oil every 3k miles and see how that goes.
Sent from my Nexus 7 using Tapatalk
Old 06-17-2014, 03:42 AM   #46
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
bump. Very interested to see what oils people use. I e-mailed AMSOIL, asking for their recommendation for E85 usage. I changed my oil with Redline 5w-20 this time around, but if I can find it next time I think I'll do AMSOIL 0w-20 unless there's another solid alternative that's not crazy expensive.
unsurety is offline   Reply With Quote
Old 06-17-2014, 04:03 AM   #47
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
why so??
Carlitoz3 is offline   Reply With Quote
Old 07-04-2014, 03:02 PM   #48
Dan@AWD
Drives: 2013 Argento FR-S
I've had no issues with Motul 8100 0w-30, problem is we will not know there are any problems until we get a (knock knock; who's this) sound...
I thought I was good, but didn't realize my oil behaves like a 40 weight oil which IMHO is too much for this engine. That is why I want alternatives. I would like to go with something more off the shelf than 300V. (Maybe that's the answer....)
@bluesubie
I got the knock knock at about 3800 miles on the same oil. Mobil 1 5w-30 on E85. I was over the miles I would have liked to be at to change the oil.
Dan@AWD is offline   Reply With Quote
The Following User Says Thank You to Dan@AWD For This Useful Post:
Sportsguy83 (07-04-2014)
Old 07-04-2014, 03:20 PM   #49
Reaper
Reaper's Avatar
Drives: violent
Originally Posted by Carlitoz3 View Post
why so??
any high zddp oil is bad for cats
Old 07-04-2014, 03:22 PM   #50
Dan@AWD
No cats here.
Old 07-04-2014, 03:38 PM   #51
Dan@AWD
For a boosted 500+ whp FA20 what has been the consensus on the correct oil to use. Since the Subaru boosted FA20 uses 5w-30 and supposedly no bearing/clearances differences.
I was thinking about using Motul Synthetic Engine Oil 8100 5W40 X-CESS part # 102784 1l / 102870 5l. For the people with good oil knowledge of how it works and additives and such what are your thoughts? Trying not to spin another rod bearing while .
Old 07-05-2014, 12:06 AM   #52
Reaper
Reaper's Avatar
Drives: violent
Amsoil dominator 10w30
Old 07-05-2014, 12:55 AM   #53
Dan@AWD
Explain. Also no feedback on my question?
Old 07-05-2014, 02:22 AM   #54
viscositosis.rex
Drives: Currently 2018 Taco
Find out which motor oil blenders use Lubrizol additive package formulations containing the Trident H-E-I technology. H-E-I stands for hydroethanol inhibitors.
Here's a hint: I installed Pennzoil Platinum Ultra with PurePlus 5W20 in my vehicle today. This oil will lead the way to ILSAC GF-6, which will require greater corrosion protection, for starters.
Beware of the great menace to society, White Sludge.
viscositosis.rex is offline   Reply With Quote
Old 07-05-2014, 04:06 AM   #55
Reaper
Reaper's Avatar
Drives: violent
Late at night, on phone, drunk. Ill get back to ya
Old 07-05-2014, 06:54 PM   #56
Reaper
Reaper's Avatar
Drives: violent
@Dan@AWD I use amsoil dominator because of a conversation I had with one of their engineers, NOT a salesman.
Dominator and Z-rod both produced some of the best 4 ball wear tests in the industry and that's what initially caught my attention. They are both high in zddp and the gentleman I talked with said race teams have sent in oil samples that survived close to 300* oil temps (dominator). Dominator has also been used in a lot of situations exposing it to alky and ethanol based fuels without problems.
Z-rod is a similar oil and was specifically marketed towards older hot rods with flat tappet cams(brutal wear item) that saw long storage periods and a high potential for fuel dilution. It's biggest difference between it and dominator is its high detergent level. Since dominator is a "race" oil it has no detergents which when running e85 doesn't matter since the e acts like a cleaner. Both are very high in zddp which is bad for cats but that's also not an issue for us.
I have no oil cooler and live in 90-100*F ambient temps dding 450whp without overheating in some steep mountains. I run amsoil dominator 10w30 and have a MAPerformance 8qt oil pan. I've been changing my oil at 3500 miles but amsoil is telling me to go longer. I just sent in a UOA for 3,500 and tentatively am going to send in another at 5k. I'll post those.
The Following 2 Users Say Thank You to Reaper For This Useful Post:
GhostOp86 (12-09-2015), spitfire481 (07-06-2014)
WTB: UEL HEADERS! Non specific Asian Delight Engine, Exhaust, Bolt-Ons 1 02-07-2014 04:51 PM
Specific Vishnu OFT threads... Tromatic Software Tuning 6 12-07-2013 03:09 PM
Looking for a specific spoiler ... Need help finding it. pwnisher Cosmetic Modification (Interior/Exterior/Lighting) 8 07-10-2013 10:56 PM
Anyone know where to get FR-S specific key chains? mmieszanek Scion FR-S / Toyota 86 GT86 General Forum 4 02-26-2013 04:28 PM
Specific iso bdanisi Engine, Exhaust, Transmission 1 02-12-2013 09:31 PM
