#1723 |
NASA SpecE30 Racer
Unless you are running 100% speed density, I think you are going to be disappointed when you install that white spring. I think you guys are worrying too much about what you think is compressor surge and not enough about following the manufacturer of your BOV's advice. The FA20 is more than capable of pulling down over -20 in/hg. With that being said the number can vary depending on where you are pulling that vacuum/boost source from.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#1724 | |
Drives: 2013 Black FR-S
If my BOV is pre-MAF it wouldn't hurt to put in a softer spring right? The BOV may open at idle and during high vac situations but as soon as the vac gets more positive, the BOV spring should shut the BOV and boost can build. I want to get rid of this horrible flutter I am getting at the GT3076 compressor during low boost lift-offs. Sounds great at high boost lift-offs but no great otherwise. |
#1725 | |
NASA SpecE30 Racer
- King Tut
#1726 |
I put an 8psi spring in mine and it was open at idle. I had low speed drivability issues and stalling. Put an 10psi one back in and it drives OK but it still flutters
The Frozen North
#1727 | |
Is it the standard Full Blown kit location? |
#1728 |
Yeah it the standard location pre maf about 8-10"
The Frozen North
#1729 | |
There is always this for $300: http://www.turbosmartdirect.com/Prod...BOV-BLACK.html
#1731 | |
The Frozen North
#1732 |
Drives: 2013 Subaru BRZ-S
When I bought my kit, it was a kit already put on another BRZ. It came with the pre-installed brown spring. Even though I am not 100% certain what my vacuum is, it doesn't hurt to try a softer spring. Otherwise I have a useless BOV, it never releases. Not good for the turbo to have back pressure, so its worth a shot changing the spring out.
#1733 |
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
We have run more than a few cars with no BOV over the years. Compressor surge is over rated IMHO.
What most of you are experiencing is normal. Basically the theory to setting up a BOV is to have it fight the wastegate until the last possible second. Which will cause a slight surge (nothing to worry about) at full boost shifts/off throttle events and will cause a very light "surge" at less than peak boost during shifts/off throttle events. This is normal. You want a "cough" at WOT and a light/short turkey gobble/quail call at less than WOT. |
#1734 | |
If the BOV is being held shut by the boost line to it + spring then I see no other reason why I can't use, say a 10inHG spring other than the valve being open during idle and cruise. |
#1735 |
I just want to blow some load bro .
#1736 | |
NASA SpecE30 Racer
- King Tut
| Tags |
| best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo |
| AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 10:46 AM |
| Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 03:10 AM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
| Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
| WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 09:15 PM |
