Old 05-28-2014, 02:16 PM   #1723
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by 69Marshall69 View Post
I took apart my BOV and had a brown 13psi spring. I'm connecting the boost gauge side of my wideband failsafe this weekend to find out what I'm running for vacuum. I ordered a 10psi spring(white) and see if it will release properly.
Unless you are running 100% speed density, I think you are going to be disappointed when you install that white spring. I think you guys are worrying too much about what you think is compressor surge and not enough about following the manufacturer of your BOV's advice. The FA20 is more than capable of pulling down over -20 in/hg. With that being said the number can vary depending on where you are pulling that vacuum/boost source from.
Old 05-28-2014, 04:41 PM   #1724
sw20kosh
Drives: 2013 Black FR-S
I am running a hybrid MAF/SD tune. Uses MAF untill it maxes out the V.
If my BOV is pre-MAF it wouldn't hurt to put in a softer spring right? The BOV may open at idle and during high vac situations but as soon as the vac gets more positive, the BOV spring should shut the BOV and boost can build.
I want to get rid of this horrible flutter I am getting at the GT3076 compressor during low boost lift-offs. Sounds great at high boost lift-offs but no great otherwise.
Old 05-28-2014, 04:46 PM   #1725
King Tut
NASA SpecE30 Racer
King Tut's Avatar
If the BOV is far enough forward that it's opening/closing in high vacuum situations won't mess with the flow of the air across the MAF sensor, then you should be fine as the MAF will still meter the air properly.
Old 05-28-2014, 04:51 PM   #1726
Dipstik-sportech
Dipstik-sportech's Avatar
I put an 8psi spring in mine and it was open at idle. I had low speed drivability issues and stalling. Put an 10psi one back in and it drives OK but it still flutters
The Frozen North
Old 05-28-2014, 05:01 PM   #1727
sw20kosh
The Frozen North
Where is your BOV in relation to the MAF? pre-MAF? post-MAF? 1 foot away from MAF? 2 feet? 3 feet?
Is it the standard Full Blown kit location?
Old 05-28-2014, 05:10 PM   #1728
Dipstik-sportech
Yeah it the standard location pre maf about 8-10"
The Frozen North
Old 05-28-2014, 05:20 PM   #1729
sw20kosh
The Frozen North
That is strange that it would cause driveability problems. I am guessing turbulence from being too close to the MAF?
There is always this for $300: http://www.turbosmartdirect.com/Prod...BOV-BLACK.html
Old 05-28-2014, 07:13 PM   #1730
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
add me to the list @King Tut i will try to free time for a build log soon.
xDBOYx is offline   Reply With Quote
Old 05-28-2014, 07:15 PM   #1731
Dipstik-sportech
Damn I can't see it coming down to that.
The Frozen North
Old 05-28-2014, 08:13 PM   #1732
69Marshall69
69Marshall69's Avatar
Drives: 2013 Subaru BRZ-S
When I bought my kit, it was a kit already put on another BRZ. It came with the pre-installed brown spring. Even though I am not 100% certain what my vacuum is, it doesn't hurt to try a softer spring. Otherwise I have a useless BOV, it never releases. Not good for the turbo to have back pressure, so its worth a shot changing the spring out.
69Marshall69 is offline   Reply With Quote
Old 05-28-2014, 10:16 PM   #1733
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
We have run more than a few cars with no BOV over the years. Compressor surge is over rated IMHO.
What most of you are experiencing is normal. Basically the theory to setting up a BOV is to have it fight the wastegate until the last possible second. Which will cause a slight surge (nothing to worry about) at full boost shifts/off throttle events and will cause a very light "surge" at less than peak boost during shifts/off throttle events. This is normal.
You want a "cough" at WOT and a light/short turkey gobble/quail call at less than WOT.
Infamous Performance is offline   Reply With Quote
The Following 2 Users Say Thank You to Infamous Performance For This Useful Post:
69Marshall69 (05-29-2014), Travisty75 (10-24-2014)
Old 05-28-2014, 10:51 PM   #1734
sw20kosh
I'd rather not have the turkey at all. It's a very unattractive / annoying sound.
If the BOV is being held shut by the boost line to it + spring then I see no other reason why I can't use, say a 10inHG spring other than the valve being open during idle and cruise.
Old 05-29-2014, 09:07 AM   #1735
69Marshall69
I just want to blow some load bro .
The Following User Says Thank You to 69Marshall69 For This Useful Post:
Darryljr11 (05-30-2014)
Old 05-29-2014, 10:54 AM   #1736
King Tut
NASA SpecE30 Racer
King Tut's Avatar
If your BOV doesn't open up at all when you shift, then there is something wrong with it.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
