#1121 |
#1122 | ||
Drives: 2013 Subaru BRZ
[ame="https://www.youtube.com/watch?v=2XQGCQYnhuU"]2014 Spring Nationals - 57 CS - East Course - YouTube[/ame] I tried both the 235/40R17 ZII's and the 225/45R17 R-S3 V2's during the Pro. I started on V2's, having never run them before, and was initially less than impressed. They are very similar to the V1's in the way they respond, and I'm used to the ZII's. I didn't know where to set the pressures so I tried 35 square - I came to the conclusion that this was too low. In the afternoon I switched the ZII's and they felt so much more precise but the times didn't show much of an improvement - only ~.3 per side on a faster course. On day 2 of the Pro it rained so I swapped to V2's to see how they would do and I was thoroughly impressed! The car was a blast to drive and felt very well controlled. I effectively matched Fenter's wet times which I was very happy with. I wouldn't hesitate to treat the R-S3 V2's as acceptable wet tires, although probably slower than DW's. For the Tour I stuck with R-S3's for the contingency potential. Day 1 didn't go well, as I made mistakes on run 1 and 2, and then had what seemed to be overheated V2's for run 3 (2 drivers in the Tour). On Day 2 I was able to throw down a good run on run 2, but again felt like the tires gave up a little bit on run 3. On both days I sprayed the tires from run 1. 225/45R17 R-S3 V2 Summary: Very pleased with the wet and dry performance, but managing heat seems to be similar to the ZII where they must be cared for. The tires are slow to respond like the V1's and you must turn earlier than you think. The balance tends more towards understeer than oversteer and is difficult to shift. Here were my setups if anyone is curious. 235/40R17 ZII Front Pressure (PSI): 32~33 Rear Pressure (PSI): 29~30 Front Konis (Turns from Soft): 1 Rear Konis (Turns from Soft): 1 225/45R17 R-S3 V2 Front Pressure (PSI): 39 Rear Pressure (PSI): 44 Front Konis (Turns from Soft): 1 Rear Konis (Turns from Soft): 1.5
-John L.
2011 BMW M3 - 57 FS 2007 Ford SGT - 57 FS 2013 Subaru BRZ - Sold Last edited by Rexpelagi; 05-28-2014 at 06:07 PM. |
| The Following 2 Users Say Thank You to Rexpelagi For This Useful Post: | jdrxb9 (05-29-2014), Sccabrz192 (05-28-2014) |
#1123 |
From what I've seen, the FoST tends to be the car to have in most situations over the FiST, although the Celica can still compete with either. The FiST can't put down power well, which is the main complaint I've heard. The FoST isn't great either, but better than the FiST.
-John L.
2011 BMW M3 - 57 FS 2007 Ford SGT - 57 FS 2013 Subaru BRZ - Sold |
#1124 |
C-Street AutoX
John, after decent time in each car now, do you think the BRZ is faster/slower/no difference than your RX-8?
So it's safe to say that most drivers were on the RS3's due to rain/contingency reasons? |
#1125 | |||
Thanks for the kind words John and from the driving I saw you do, same to you! I think it was even closer in the Pro and I got Chris on the right side thanks in large part to the drag starts. Quote:
Well said. I think I would definitely wan the FiST in wet conditions as well. The weight and power of the FoST becomes a handicap. Quote:
The Celica definitely will be a tough contender. I would also add the Genesis R-Spec and Neon SRT4 to the mix of potential cars to have. One more thought on tire experience at Lincoln. Last year at Fall Nats, the OPR was thick on corner entry on the East course due to the threshold braking required. There were a few corners like that again on the East course at Spring Nats by the time I ran in 5th heat. I missed my braking zones twice on the Federals (felt like I was trying to stop on wet pavement). The same thing happened to me on my third run last year at Fall Nats on the Z2's too but to an even larger extent...felt more like I was on the lake ice racing. I have only noticed this where the OPR is heavy under threshold braking. The Rivals started to feel like that under lateral load as well but to a much smaller extent. They didn't seem to pick up chunks of OPR like the Z2 and Federals but instead had a glaze of OPR (almost looked like someone sprayed the tire with tire shine). |
#1126 | |
Fenter and Harvey are very good drivers, and having tried a Miata last year and finding it 'felt' like crap goes to show that feel isn't a timer. The BRZ feels so much better than the RX-8, but I want to give it a real try at a few events and see how the times compare. If the bar comes in soon I'll let you guys know how it does. Regarding the R-S3's, I instabought the day they announced contingency since I knew they worked well for others. They are also relatively cheap, so that is another reason. But I would say that generally people got them for contingency. As a side note some drivers in CS were still on V1's, including the 350Z and Nick/Brandon in their FR-S (maybe others), so some people were just running what they already had likely before the contingency was announced.
-John L.
#1127 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Is anyone else seeing a trend, not just with Trevor, but other events, Focus ST are running same or better times than the CS cars?
I can't wait to see what the post-national SEB meeting will look like. BRZ to ES, Focus to CS :P
#1128 |
Drives: Some kind of Subaru
I've noticed that too. Those Focus STs are fast! I'd also be okay with the BRZ going to ES.
#1129 |
Dodging cones
We run similar times to top 99 sports and 03 MR2S' so I think it would be a fair move.
#1130 |
Drives: Yes
I have the Nats-winning GS Celica and drivers in my region. I run roughly the same times they do depending on the course, but I agree that GS seems almost as fast and sometimes faster than CS this year (but course dependent).
Nice driving Trevor and John! |
| The Following User Says Thank You to Biggins For This Useful Post: | TRev (05-29-2014) |
#1131 |
Drives: 2014 BRZ Limited, 2013 Focus ST
I'm thinking of picking up a lightly used set of 245/40/17 BFG Rivals to use in CS. Does anyone here have any experience with that size/model tire for autoX purposes (with stock size rim of course)? Thoughts?
#1132 |
Drives: BMW 135i, soon to BRZ
RE: miata feel...
I have no idea if Chris' car feels like crap or not, but Fenter is a damn smart setup guy. It might still feel like crap but with tons of tweak to get it fast. |
#1133 |
i'm sorry, what?
Drives: Canada
just put on fresh R1Rs , 235/40/17, any recommended pressures for a sunny day of autocross?
I'm reading people like to hover between 32-35, I've got a pyrometer to dial it as the day goes by but would like to have a good starting base.
#1134 | |
C-Street AutoX
I've had success with them. I'll be updating the thread with this weekends results soon. http://www.ft86club.com/forums/showthread.php?t=41955 |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
