#43 |
So elite I'm 1338
Drives: WRB Subaru BRZ
..... Sounds like you are all having issues because you have NO idea what you are doing to your car. :P
| The Following User Says Thank You to tahdizzle For This Useful Post: | Wilso (05-27-2014) |
#44 |
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
#45 |
Drives: 2014 DGM BRZ
Figured out my problem...Was the Valenti Reverse bumper light. I assume it was the flashing function of the triangle. Rewired it to where the triangle only comes on solid when the brakes are applied and the issue is now gone.
#46 |
Drives: gt-86
Electrical Gremilins. My car suffered from random ABS lights at the weirdest times. No logic. I was familiar with over sensitivity to voltage drop issues in Euro car ABS systems. I thought maybe my LiFePO4 (Lithium battery) was cutting out or unstable at high running temps. Found a very good diligent Toyota Technician. First time he spent a day with the car and finally cleared the codes. Second time spent a day and traced the problem to the ground connector on battery. This has a built-in temperature switch and ground fault protection.
It is a known problem. Toyota is replacing cable free of charge under warranty. Just no parts in Taiwan...need to wait two weeks. Mine is getting worse and worse. Means I do not have ABS. At the track we can not do pedal dance. Infact we thought ABS was off with pedal dance but know we know that is not true after smoking a few tires with the light on. |
#47 | |
#48 | |
Funny I just started having same issue with Toms after install.
#49 |
#50 | |
You would not happened to have any gauges piggy backed off the tail light fuse? I also have just added oil pressure gauge and used tail light fuse for dimmer. Also I noticed its easy to recreate by just letting the car idle and holding the brake pedal down for a while almost like its either a temp/voltage issue.
#51 | |
#52 |
So my lights are from a dead ABS sensor. Probably when I did my coilovers. If you have these lights its worth a check at the dealer to make sure your sensors aren't dead. Tech said the sensors are very sensitive and fragile T_T
#53 | |
When did your lights come on? (Abs/traction) at a stop or just driving?
#54 |
#55 |
I think this thread has multiple causes. I believe mine is related to brake switch tsb. Just happens i installed toms tails and pressure gauge at same time i noticed the abs light.
#56 |
Drives: gt-86
The ABS cable itself is usually the problem, not the ABS sensor on the end.
ABS cables/wire use very thin wire strands. If you over extend or kink the cable you can break strands in the cable. This is not visible. Even if you check with ohm meter comes up OK. However depending how bad the break it can corrupt signal and trip a fault. Temperature and motion can be triggers in this situation. Always disconnect and tie back your ABS wires when you are doing suspension work. |
| The Following User Says Thank You to Totality For This Useful Post: | Wilso (03-01-2015) |
| Traction/VSC Setting Preference | ashtray | BRZ First-Gen (2012+) — General Topics | 27 | 08-24-2018 03:39 PM |
| TPMS warning light **New Info** | sdiver68 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 10-11-2012 07:25 PM |
| TPMS and Traction Control | Mavrik | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-02-2012 01:50 PM |
| traction control issue | *KID* | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 07-08-2012 08:13 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 11:20 AM |
