| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#43 | |
Drives: 2004 Subaru Forester 2.5XT
The viscosity on that is better than the used oil viscosity on most GF5 5W-30 uoa's from a WRX. ![]() According to this particular voa, RL uses around 33 ppm of silicon in their 0W-20 (different lab). http://www.bobistheoilguy.com/forums...Number=1630856 So I guess you could say your real silicon reading is ~10-~15 ppm's. That TBN is nice!! 7,500+ mile oci's easy! No doubt the TBN is helped by RL's very generous amount of calcium for detergency. -Dennis |
| The Following User Says Thank You to bluesubie For This Useful Post: | Dezoris (05-28-2014) |
#44 |
Fat on Corn Syrup
Lot of smart people in here. I'm not one of them when it comes to this level of oil analysis.
I'm just trying to figure out what oil I should run in Phoenix during the summer in a NA car with minimal bolt ons that sees the track for HPDE one weekend a month without an oil cooler yet. In our bikes (CBR1000RR and GSXR 750) we run a slightly heavier oil in the summer and we can feel it's better. But this is our first flat four... Sent from a secret volcano base using trained sharks |
#45 |
Drives: '13 Asphalt FRS 6MT, '04 IS 5MT/LSD
Kavanaugh, please read this. It's the bible as far as oil goes, in my opinion: http://ferrarichat.com/forum/faq.php?faq=haas_articles
It sounds like what you may want is a 0w30 for your environment. Flow is more important than oil thickness Here is a technical data sheet for Amsoil. I hate the ponzi bullshit, but they do have a superior product: http://www.amsoil.com/lit/databulletins/g2880.pdf I guess the most important thing to remember is that flow equals lubrication, not pressure, and generally a thicker oil flows less well. |
| The Following User Says Thank You to Nasty Sausage For This Useful Post: | kavanagh (05-28-2014) |
#46 | |
![]() Some of it is not accurate and some is outdated: http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3294902/1/Dr_Haas'_Motor_Oil_University_ Regarding Amsoil, I'd pick the 5W-20 over the 0W-30 Signature Series any day. There's not a huge difference in viscosity at 100C, the HTHS of the 5W-20 is nearly the same as many 30 weights (2.8 vs 2.9 minimum for xW-30), less viscosity modifers (narrower viscosity range) usually means a more stable oil, and the 5W-20 as a much better NOACK volatility. kavanagh - You cannot always determine that an oil is "heavier" by the grade on the bottle. Kinematic viscosity and HTHS play a part as well as the operational viscosity that the oil has in an engine. As I mentioned in Dezoris's analysis reply above, many xW-30 oils shear to a 20 grade so you're not always gaining a thicker operational viscosity and better bearing protection by running 0W-30 or 5W-30. -Dennis |
| The Following 2 Users Say Thank You to bluesubie For This Useful Post: | kavanagh (05-28-2014), Nasty Sausage (05-28-2014) |
#47 |
Thanks Dennis!
#48 | |
Drives: 2022 BRZ Limited
..maybe, just maybe the oil analysis are just simply the analysis of the oils but unless we tear the engines after a certain miles (boosted or not) we can never make sure the real effects..![]() Also, I have been using 0w-40 ever since I owned this car I wonder if it also may cause higher oil temps since some people report lower oil temps with similar setup (OEM oil cooler and SC kit) ..maybe I can try 0w-30 next time since someone else mentioned Rotrex uses its own oil feeding/cooling system unlike turbos
#49 | |
It's not always that useful for determining engine wear and never useful to try to compare one oil against another. http://www.bobistheoilguy.com/used-oil-analysis/ -Dennis |
| The Following User Says Thank You to bluesubie For This Useful Post: | glamcem (06-02-2014) |
| Quickie: 0w20 vs 5w20 / 5w30 | empower-auto | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 43 | 12-17-2016 02:54 PM |
| Servicing at dealership - do they use 0W20? | Fizz | AUSTRALIA | 23 | 01-13-2015 01:55 AM |
| Eneos 0w20 | Hayashi | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 154 | 10-27-2014 06:04 PM |
| Redline 0w20, notice to vendors/shops | BRZPDX | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 05-06-2014 04:26 PM |
| Anyone want 0.65 liters of Amsoil SS 0W20? | Laika | NY / NJ / CT / PA | 0 | 03-31-2013 07:53 PM |
