#113 | |
Drives: Toyota 86 TRD Version AT
#114 |
Drives: A bunch of 'em...
Are you sure?
#115 |
Junior
Drives: a car
Yes. On the first page I posted a link to a website that tested more than a dozen oils at higher temps for an hour, check that site out. It's got some useful info for those looking to track their car.
#116 |
Always going to have some adverse opinions on the forum.
Some of us have been collecting data for well over a year now. 195F - 220F is common within 10 minutes of spirited driving and is completely normal on a stock car. Any Toyota/Subaru Engineer would have tested and experienced this during development. Ranges and Data Collected: 100-169F Warm Up Phase, high oil pressures 170-189F Near Operating temps, oil pressures still higher 190-225F Normal Operating Range, oil pressures normalize 225-245F Middle End of operating range for track use, 5% drop in oil pressures 245-255F Upper End of operating ranges for track use, 10% further drop in pressures on 0w20 255-265F Red Zone of operating ranges for track zone, 0w20 starts to thin, oil pressures drop to questionable range. 265F+ Playing with fire on 0w20
#117 | |
Generally 250 is a little on the high side but many cars run right around there on the track. Above 260 and you definitely want to look at cooling things a bit more. What kind of oil were you running? |
#118 |
One week old car all stock as off the showroom floor including tire pressure. LOL
Except for a track pipe - muffler delete. |
#119 |
Yes. I tracked my car a lot while NA. I had to pull into the pits after 5-6 hot laps when the oil temp starts to get around 130-135C. After my SC install, without the oil cooler, I would reach the same temps in 3 hot laps.
#120 |
So I need an oil cooler. I plan on running more than 3 fucking laps...
#121 | |
#122 |
On it.
Problem is, there seem to be none that fit the KW blower kit... |
#123 | |
Drives: 2013 BRZ Premium Dark Gray Metallic
#124 | |
#125 |
About to pull the trigger on the Kraftwerks kit.
Oil cooler necessary for on the street and daily driving or will I be able to get by without? I figure I won't push it to extreme levels like a track would for starters, but it's also not really cool during summers here. Plan on getting the Kraftwerks oil cooler when it releases for that piece of mind regardless of daily driving. |
#126 | |
| Oil cooler needed? Don't know? See some results inside | Sportsguy83 | Engine, Exhaust, Transmission | 159 | 03-15-2015 05:27 PM |
| Perrin Oil Cooler - Impressions, Pics, and Data | swift996 | Engine, Exhaust, Transmission | 36 | 04-29-2014 09:03 AM |
| Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. | mike the snake | Engine, Exhaust, Bolt-Ons | 1 | 01-31-2014 05:46 PM |
| Car/Ambient temperature to log data | gdrider77 | Software Tuning | 6 | 01-19-2014 08:49 AM |
