Old 05-27-2014, 02:52 PM   #1709
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Brzzee View Post
Some pics with text on your radiator mount modification, please.
I know he took pics and wrote a description somewhere on the forum. Perhaps in the Combating the Heat thread.
Old 05-27-2014, 03:44 PM   #1710
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Hi guys!
So I'm a newbie, and I do not have a twin or any car at all yet. I'm shopping around and doing my research. I plan to keep whatever car I get for an indefinitely long amount of time, so I want to know how much potential a car really has. Which is why I'm looking at this thread already lol.
I've been reading this thread in my spare time, post by post. Got up to page 44 so far lol, lots of good information. And I noticed that FBM (or LJ, the owner?) has been improving the kit as problems are found.
So I have a few questions:
1. Whats the situation with heat like now? I see that the shroud is being sold for $200 as a separate piece, and people seem to switch to Spal fans. I find it odd that the kits dont come with these things included. Is it because the heat issue is mainly evident only during track use?
2. I live in NYC and while temps are low most of the year, the summers feel terrible with 90F+ and high humidity. So I'd really like my airconditioner to work... Again, I've read a lot of varying reports about this. It seems like the AC definitely blows warm air when the car isn't moving. Could that be fixed by adding a smaller fan on the condenser? I work with watercooling PCs, so that was my first thought lol.
3. I don't understand the difference between Stage 1 and Stage 2 kits. The premium stage 1 costs pretty much the same as the Stage 2 and the main difference seems to be the intercooler and fuel injectors. Is there any reason why I wouldn't want to just go straight for Stage 2 and keep it at low boost until I'm ready?
4. I'm a huge DIY type of person. I would love to be able to install a FBM kit by myself but my resources are limited. How feasible is it to attempt this when all I have is a driveway? I'd probably have to work in small steps since I cant leave my car disassembled out in the open lol.
I've read some build logs and they vary from do-able to scary. The fact that these kits are constantly being improved also made me want to ask this question. If everything really is a bolt-on fit at this point, that would make me feel better.
Sorry if some of these questions are repetitive, I've read through about half this thread and a few other threads already, but I haven't read everything unfortunately.
Old 05-27-2014, 03:44 PM   #1711
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Here is some info from @Ironsquid :
http://www.ft86club.com/forums/showthread.php?t=57792
Old 05-27-2014, 03:53 PM   #1712
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by PandaSPUR View Post
Hi guys!
1. The cheap slim fans and non shroud was sufficient for my use on the street in Florida. They never melted nor failed to work and the only issue was when in stop and go traffic or in a fast food drive thru line they were not able to pull enough cool air across the radiator or the A/C condensor and the temps would rise a little bit before stabalizing and the A/C would stop blowing cold. All other times the temps and A/C worked fine.
2. I think an additional pusher fan on the A/C condensor would probably help in the situations I mentioned above.
3. Stage 1 is really meant for the GT/X28 - GT/X30 builds and the Stage 2 is more for the GT/X35 and big horsepower guys. If you don't need the bigger injectors for running E85 or the larger intercooler to keep the higher PSI levels cool, then stick with the Stage 1.
4. If you get a prewelded oil pan from LJ @FullBlown then I would say it is 100% a DIY install affair with nothing more difficult than drilling out a few holes or doing some simple wiring and fab for the fuel pump install. You need something to cut the plastic for the intercooler piping as well.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
Boba_kz (05-28-2014), carlossanchez89 (05-27-2014), PandaSPUR (05-27-2014)
Old 05-27-2014, 04:19 PM   #1713
PandaSPUR
PandaSPUR's Avatar
Thanks for the quick reply!
1 and 2. So I'll be fine in NYC weather then, very glad to hear that.
3. I guess I understand what the difference is between the two. I just dont see why going with the bigger IC and injectors from the start would be a bad idea. If I want 300whp, Stage 1 will get me there, but so could Stage 2 at the same price and with more room for growth. I'm missing something right?
4. What fabrication is needed for the fuel pump? I dont have any welding or other specialty equipment, so I'm glad to hear that I can get the oil pan pre-made. I read about your fuel pump install in your build log, and that definitely did seem confusing to me.
Old 05-27-2014, 04:35 PM   #1714
Dipstik-sportech
Dipstik-sportech's Avatar
You can also get their cast aluminium oil pan with the bung for the oil return built in. I haven't had any issues with the base kits slim fans but I still plan to get the shroud combo for extra security.
The Frozen North
Old 05-27-2014, 11:54 PM   #1715
FullBlown
FullBlown's Avatar
Drives: Scion FRS
The difference from the stage 1 and 2 is the the intercooler, turbo and injectors. The stage 2 comes with a gtx35. We can custom tailor a kit for you with say a gt28 or gt30 turbo and the bigger intercooler, injectors if you want.
As far as bolt on, we have cast oil pans ready to go. No need to weld at all.
FullBlown is offline   Reply With Quote
Old 05-28-2014, 02:23 AM   #1716
pmccut
Drives: Blue Subarus
Hi guys!
I have the base kit and had issues with cooling in NorCal weather, which is quite mild - low 80s are typical. In stop and go traffic A/C would blow hot, and pushing it on mountain roads would see uncomfortable temps, even at night when it was in the 50s.
@FullBlown installed their radiator and oil cooler on the car which made it better, but the temps would still rise quite a bit on fun drives. I took it to the track in quite cold weather and it really didn't go well at all. A couple laps in and I'd have to do a cool-down lap.
Next step was the SPAL fans + shrouding, and ceramic coating everything in sight. Headers, dump tube, OP, DP, and turbo blanket. This made the biggest difference. I have yet to see the dial move. I'm planning to take it back to the same track in a month and see how it goes.
TL;DR do everything the first time.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
The Following User Says Thank You to pmccut For This Useful Post:
Old 05-28-2014, 04:33 AM   #1717
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Exactly what I was looking for to visualize the upper radiator support brackets. Big thanks!
Hope your new ride is everything you hoped it would be.
I'm still on the Weds and MPSS drawing nice complements wherever I happen to be.
Brzzee is offline   Reply With Quote
Old 05-28-2014, 09:16 AM   #1718
King Tut
NASA SpecE30 Racer
King Tut's Avatar
In the end with the rubbing issues I had, I wish I had just kept my Weds and 245 MPSS and dealed with less traction. I might go with Weds again on my next ride.
Old 05-28-2014, 09:30 AM   #1719
mike the snake
In the pics in the link, Ironsquid drilled holes forward in the grommets.
What I did was drill new holes well in front of the grommets, into the metal frame, over an inch forward. This gains a LOT more clearance.
Drilling holes forward in the grommet only gains you 1/4''-3/8''.
Drilling new holes in front of the grommets gains 1.5''-2'' clearance.
New holes for the mounting posts, and some small tabs of rubber between the frame and radiator is all that's needed.
The Following User Says Thank You to mike the snake For This Useful Post:
Old 05-28-2014, 11:38 AM   #1720
PandaSPUR
PandaSPUR's Avatar
That sounds good, so then I could just swap out the turbo itself if I ever want more power. And good to know I dont need to weld lol. Thanks
Hmm i see. So yea it sounds like I should definitely at least opt for ceramic coating at the time of purchase, that seems like the most annoying thing to change later.
I'll probably upgrade the rad and add the oil cooler first if I do end up buying a twin. Thanks
Old 05-28-2014, 02:03 PM   #1721
69Marshall69
69Marshall69's Avatar
Drives: 2013 Subaru BRZ-S
I took apart my BOV and had a brown 13psi spring. I'm connecting the boost gauge side of my wideband failsafe this weekend to find out what I'm running for vacuum. I ordered a 10psi spring(white) and see if it will release properly.
69Marshall69 is offline   Reply With Quote
Old 05-28-2014, 02:06 PM   #1722
Dipstik-sportech
Brown is a -12psi and a white is a -9psi. Remember we don't have the bv50 we have the Q so some of the numbers are different. I need to order a white cause I'm low compression and I draw less vacuum.
The Frozen North
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
