Old 01-24-2014, 09:45 AM   #1
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
Brake Air Ducts
I will like to add brake duct, to my APR Carbon Ducts... but I dont want to pay $300 for them I am waiting for someone to do a plate for the brake sheapper than that, $300 is just too much for a hose and a Plate mount... is there any cheap plate...
kombatlion is offline   Reply With Quote
Old 01-24-2014, 09:55 AM   #2
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
You could buy a full kit for nearly the same price as those ducts: http://www.tf-works.com/tf-brake-duc...-s-subaru-brz/
The Following User Says Thank You to ATL BRZ For This Useful Post:
supra2nv (07-03-2014)
Old 01-24-2014, 10:04 AM   #3
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Yes I like them but again $380 for a hose and a brake plate is too much, I have APR Carbon for looks too and I wont remove them, But I will like the plate and the hose and not to pay $300
The Following User Says Thank You to kombatlion For This Useful Post:
normancw (01-24-2014)
Old 01-24-2014, 10:35 AM   #4
ATL BRZ
ATL BRZ's Avatar
One could argue that $360 retail for just the APR CF bumper ducts is too much. They also create more openings in the front bumper which will add more drag at speed.
The @Touge Factory kit is not just hose and backing plates. It's a full kit including custom fit bumper ducts and all the hardware needed (clamps, couplers, washer tank spacers, zip ties, loctite). The TF rotor backing plates are hand made and welded from aluminum, and they direct air to the center of the rotors and through the vanes, which is optimal for cooling. The APR backing plates direct air at the face of the rotors, which is less effective at cooling the rotors. The hoses included in the TF kit are high temp rated silicone which is expensive. Lots of time went into the development of the kit. They actually went with the current setup after testing ducts in the fog light location and determining that there isn't enough room back there to run the hoses, especially on the driver's side. The TF kit is actually a good deal, all things considered.
Originally Posted by Touge Factory View Post
We TIG weld everything in-house, and backing plates are precision laser cut. All components for the backing plate is made out of T6061 aluminum. Due to the thickness of the backing plate, welding could slightly distort the backing plate.
We have a Jig with a used OEM rotor and entire front spinlde + hub assembly (removed from an FR-S with less then 150miles) that we use to check fitment prior to shipping out to ensure everything fits accordingly.
everything is made in-house with all parts made in the USA to ensure durability.
We include Loc-Tite for hub bolts, we include stainless steel Clampco worm clamps. We include double ply high temp hose....etc.
The kit looks simple, because we took the time and design to make it as simple as possible.
I have never seen a DIY kit that seals the rotor completely like ours. They mostly just blow cool air somewhere near the rotor.
You may think this kit for $400 is expensive - but there is not a whole lot of margin we make off this kit at all. Go and purchase 11 feet of high temp 2-ply hose. That right there is majority of your $200 kit that you're thinking of... maybe you can build one with dryer ducts for $200.... maybe.
Sure we could buy Chinese made parts to cut some cost...
Would I run that on our FR-S? Nope.
We made this kit, because we want to offer drivers who do not have the funds to spend on a large Brake kit setup to be competitive and enjoy the car.
To run hoses from your APR bumper ducts you'll at least have to remove/replace your washer fluid tank with something much smaller, and you may even have to cut out a big section of your wheel well liners. Not saying it's impossible, but it's definitely more work. With the TF kit you keep the stock washer tank and you only have to trim a little section of the wheel well liner and they provide detailed instructions for the whole install.
The Following 6 Users Say Thank You to ATL BRZ For This Useful Post:
diss7 (01-25-2014), kombatlion (01-24-2014), PoorMansRacing (01-24-2014), Sleepless (07-17-2014), supra2nv (07-03-2014), Touge Factory (01-24-2014)
Old 01-24-2014, 11:58 AM   #5
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Thanks you have made me think about this... I drive hard and will do ocassionally track driving so I may need to think about this, like you say cutting my fender liners is not a road I want to go neighter!
Old 01-24-2014, 12:05 PM   #6
ATL BRZ
ATL BRZ's Avatar
Originally Posted by normancw View Post
Do you have to remove the bumper to install the TF kit?
No, everything can be installed underneath the car with the undertray and skid plate removed.
The only full APR kit I've seen installed was done without fender liners at all! Not something you want to daily drive with or EVER in the rain! Like I said the hose routing from the fog light ducts is very tricky due to the lack of space, especially with the stock washer fluid tank present.
The Following 4 Users Say Thank You to ATL BRZ For This Useful Post:
kombatlion (01-24-2014), normancw (01-24-2014), supra2nv (07-03-2014), Touge Factory (01-24-2014)
Old 05-27-2014, 01:15 PM   #7
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Will the driver side ducting fit around Perrin oil cooler lines? It looks like it will but I would like to be sure.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 05-27-2014, 01:17 PM   #8
ATL BRZ
ATL BRZ's Avatar
Yes. I'm running both without issues. Check out my build thread for pics.
Old 05-27-2014, 01:21 PM   #9
zdr93523
zdr93523's Avatar
Thanks for the quick reply. I hadn't looked at your build until now but ours are eerily similar. Maybe I'll start my own build thread and just have 1 post... "See ATL BRZ build (excpet in white)" Off topic, and you can PM the reply rather than thread jack this one, but how do you like your lip/diffuser? What effects did you notice?
www.makesmodels.com
www.camautomag.com
The Following User Says Thank You to zdr93523 For This Useful Post:
ATL BRZ (05-27-2014)
Old 07-17-2014, 04:39 PM   #10
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Same here, thanks to the info you provided in this thread Nice setup that really works!
Sleepless is offline   Reply With Quote
APR Brake Ducts msile Cosmetic Modification (Interior/Exterior/Lighting) 23 09-08-2014 01:30 PM
FS: APR Carbon Brake Cooling Ducts trackjunkie Brakes, Suspension, Chassis 5 02-12-2014 03:27 PM
Brake ducts from Toyota 86 RCG and BRZ RA brn12345 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 11-26-2013 08:47 PM
Do APR brake ducts really work? Anthony Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 10-21-2013 06:59 PM
APR Performance Carbon Fiber Brake ducts! enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 16 06-01-2013 02:56 PM
