Old 10-16-2013, 03:25 AM   #113
Lokki
Lokki's Avatar
Drives: 2013 BRZ, Galaxy Blue, Manual trans
subscribed!
Lokki is offline   Reply With Quote
Old 10-16-2013, 10:00 AM   #114
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
JPxM0Dz do you have your fogs installed from Diode Dynamics yet ?
thanks
ucsmfu is offline   Reply With Quote
Old 12-15-2013, 07:42 PM   #115
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Anyone notice that the 2 screws holding it is not enough?
When taping on the front of the fog lights it's kind of loose
Old 01-29-2014, 05:26 PM   #116
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Yes, I wrapped the tabs that don't use the screws with some electrical tape to build them up for a tighter fit.
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 02-06-2014, 09:37 PM   #117
JS + BRZ
Drives: 2010 MS3
I was installing a set of new LEDs for my BRZ fogs.
I took them out easily. Swapped the bulbs.
For the life of me, I can't figure out myself to put the brackets to line up to the mount properly. It's not 'clicking' in to the mount for some reason.
Right now, I just pushed in the bottom parts and it's holding them fine, but I can see how the bulb is pointing up. I think it's going to blind the drivers in front. I didn't know 45W LED for fogs are this bright.
Any tip on putting the brackets to the mount?
Thanks guys.
Old 02-07-2014, 03:25 AM   #118
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Check the splines on the bulbs, you may need to remove some of them to make it fit.
Where did you find 45w LED's? That's pretty hectic.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 02-07-2014, 11:35 AM   #119
Diode Dynamics
Diode Dynamics's Avatar
We have 80 watt LEDs for those fog lights
http://www.diodedynamics.com/store/l...leds-pair.html
Nick C.
John C.
Diode Dynamics
The Following 2 Users Say Thank You to Diode Dynamics For This Useful Post:
pinski (09-24-2014), sav (02-11-2014)
Old 05-25-2014, 12:54 PM   #120
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
Hey guys...
Is this the right fog light to get??
http://heubergersubaruparts.com/part...up=FOG%20LAMPS
Phantom Super Charged - 2014 BRZ
rhythmM is offline   Reply With Quote
Old 05-27-2014, 02:12 PM   #121
rhythmM
rhythmM's Avatar
Also, has anyone tried running 55w HIDs in these? or is 35w the absolute threshold.
thanks!
Old 05-27-2014, 03:21 PM   #122
sav
sav's Avatar
Bad idea with 35w ballasts.
95RON SAV Tuned
Old 05-27-2014, 05:00 PM   #123
rhythmM
rhythmM's Avatar
Are you recommending to stick with 35w? Or against HIDs in general for fog lights. Lol
Old 05-27-2014, 05:15 PM   #124
sav
sav's Avatar
Haha sorry no I meant 55w HID's in general. I'm running 35w HID in mine and it's fine but they do generate quite a bit of heat. I have tested 55w and I'm sure the heat from those would be too much.
I might go back to halogen though because HID looks nice but they don't work well in a reflector housing.
95RON SAV Tuned
Old 06-23-2014, 04:57 PM   #125
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
does anyone know the diameter of the OEM brz fogs?
Jive Turkey is offline   Reply With Quote
Old 07-18-2014, 01:53 AM   #126
darkuni
Drives: BRZ 2013
Can we not just get LED version of stock bulb?
darkuni is offline   Reply With Quote
DIY Rear foglight Silverdub DIY (Do-It-Yourself) Guides 159 04-09-2018 01:14 PM
Is foglight wiring in the car? FastLap Scion FR-S / Toyota 86 GT86 General Forum 7 08-27-2012 12:54 AM
Foglight replacement help Zadkiel Cosmetic Modification (Interior/Exterior/Lighting) 4 08-06-2012 12:11 PM
Rear Bumper Foglight kanundrum Cosmetic Modification (Interior/Exterior/Lighting) 2 06-08-2012 01:47 AM
