Old 05-19-2014, 10:05 PM   #85
brianhj
Drives: 2017 Camaro 1SS
LOL
Originally Posted by FRSdrive View Post
16x9.5 +0 / 16x8.5 +0
brianhj is offline   Reply With Quote
Old 05-20-2014, 12:30 PM   #86
GuerillaRacing
GuerillaRacing's Avatar
Drives: Scion FR-S
GuerillaRacing is offline   Reply With Quote
Old 05-20-2014, 04:30 PM   #87
FRSdrive
FRSdrive's Avatar
Drives: 2013 FRS, 1985 Corolla GTS (AE86)
Originally Posted by brianhj View Post
LOL
LOL
FRSdrive is offline   Reply With Quote
Old 05-21-2014, 03:35 PM   #88
GuerillaRacing
Drives: Scion FR-S
LOL
LOL
Old 05-21-2014, 10:55 PM   #89
makesdrivingfunagain
Actually I think those are pretty cool! I am looking to 16's someday.
makesdrivingfunagain is offline   Reply With Quote
Old 05-26-2014, 10:37 PM   #90
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Join the movement!
dori. is offline   Reply With Quote
Old 05-26-2014, 11:06 PM   #91
Yeah, I am actually new to the import scene. I came from the domestic world. Is this becoming popular to decrease in the wheel size? As from my personal experience many people are going larger and wider wheels.
Old 05-26-2014, 11:22 PM   #92
Weasel Soup
Veteran RallyCrosser
Weasel Soup's Avatar
Drives: 10 Series FR-S, 95 Escort Rally Car
Small diameter wheels are almost always lighter when comparing same width. Rubber & air is lighter/less dense than aluminum. IMO, Wheels only need to be large enough to clear the brakes.
Big wheels are just for 'peacocking' ...
Everything should be attempted twice. Once to satisfy curiosity, and the second time to see if you like it.
My Journal
2016 SCCA RallyCross National Champion - Prepared Rear Wheel Drive
Weasel Soup is offline   Reply With Quote
Old 05-27-2014, 03:23 AM   #93
Boxer486
Drives: small
Couple things.
1-That rubber is often lined with steel belts and performance tires are quite often heavier than the performance wheels they go on to.
2-For most people it is for strutting, but at a certain application and power point, big wheels are advantageous or even necessary.
Boxer486 is offline   Reply With Quote
Old 05-27-2014, 05:17 AM   #94
Trettiosjuan
Drives: GT86
Originally Posted by Boxer486 View Post
Couple things.
Can agree with that.
Here's my take. I run mine with "regular" (surprisingly grippy) soft sidewalled 16" tires now. Oh yes indeed there is more movement, but I realised that I actually like that, it makes it more fun to play with weight transfer. Even if steering is less sharp, there is a lot of grip feedback. Once you really start sliding, it's not as progressive as a stiff tyre though. But because of the extra movement, you know what's happening anyway.
Thing is, our cars show their talent and are enjoyable with almost any tyre. And soft doesn't mean bad. Relative to a soft tyre, the suspension with springs, dampers and bushes, and the body also, become stiffer. For a given harshness of your ride straight on: would you rather have soft tires on a stiff body and suspension on a twisty road, or superstiff tires on a sloppy suspension and body?? This is often forgotten, and why people start with stiff low profile tires and end up with full suspension and bracing mods and wonder how their car got so harsh... (and how their wallet got so light )
As such, to keep that ratio as good as possible, I still have subframe inserts, steering rack bushes and a front strut brace on my soft tires.
And as you already know, similar things happen when the wheel is light. Wheel forces become lower and again suspension and body are better equipped to keep ground contact. My soft tyre weight is 7,2kg, rim 5,3kg = wheel 12,5kg. That's 26,5lbs for you guys. For the whole wheel, not just the rim or tyre.
Most obvious in daily driving, ride is much better. What can I say, mine is a DD. And on bad twisty roads together with excellent wheel control as described above, that also means a lot more fluid drive and, uh oh, dare I claim so, faster!?! Or most important for me, very enjoyable
All depends on what you want from your car... And sometimes less is more.
Trettiosjuan is offline   Reply With Quote
Old 05-28-2014, 10:09 PM   #95
Weasel Soup
Couple things.
The steel belts (woven strands) are still lighter than the aluminum (solid). I've dropped from 'Extreme Performance' summer tires on 18" wheels down to studless snow tires on 16" wheels and been 10 lbs lighter per wheel. I know that's not a 100% fair comparison, but even a gravel rally tire on the same 16" wheel resulted in 5 lbs less per wheel than the 18" setup.
As with any car modification, its all about what the owner wants from the change...
Just for the sake of debate (educate me), why would someone on stock brakes get a benefit from a set of 18x8" wheels over a set of 17x8" wheels? I know that a car with 50% more power than stock usually needs bigger brakes, which can make bigger wheels necessary, but any car at near stock power w/stock brakes? Why would bigger wheels benefit them?
My Journal
Old 05-29-2014, 12:40 AM   #96
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Originally Posted by Trettiosjuan View Post
If those are meaty, anybody appreciate these?
SPLOOOOOOOOSH
Does anyone know the OEM 16" tire brand? I know it's 205/55R16, but aside from that?
NissanGuy is offline   Reply With Quote
Old 05-29-2014, 02:22 AM   #97
Boxer486
Drives: small
You can look up tire weights on tire rack and you'll see steel in tires can easily outpace aluminum in wheels especially once you get to 18". Just check out how heavy Bridgestone REs are.
18x8 offers a larger contact patch than 17x8 based on the trigonometry of the extra radius. Whether that gets you shorter or longer distances is a question of balance with the rest of the car. Traction wise, 18s get you more potential grip from more surface area. I say that as someone that prefers small light wheels so I'm not into Dubs.
Old 05-29-2014, 02:29 AM   #98
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
Not quite true if your overall diameter is the same.
RiskyTrousers is offline   Reply With Quote
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 04:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 06:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-27-2012 11:20 PM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 08:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 11:17 AM
