View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 05-26-2014, 01:04 PM   #4117
BRZJunkie
Drives: BRZ Sportech
Originally Posted by protpibe View Post
I added 2 oz of Shell synthetic 2stroke oil to a full tank of 94 octane fuel (10% ethanol) yesterday and the crickets are gone.
I'm actually very pleased with the results thus far. I'll post up again if they come back.
As I wrote a little up this thread, I did the exact same Petro-Can 94 + 2oz and it's gone for the most part. It comes back now and then but its because I know much too well what to listen to. It's easily burried with the rest of ambiant noises. Especially when other cars are around... So far so good.
BRZJunkie is offline   Reply With Quote
Old 05-26-2014, 04:59 PM   #4118
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by andrew20195 View Post
The noise (as determined by Fuji engineers) is caused by cavitation (bubbles) in the high pressure pump with certain fuel blends in certain conditions.
Where did you hear this?
ineedyourdiddly
Old 05-27-2014, 01:18 PM   #4119
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Chirps are starting to become insanely loud now on my replacement pump. I may finally start doing 2 cycle oil trick.
JonAvalon is offline   Reply With Quote
Old 05-27-2014, 10:31 PM   #4120
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I bought a small 2.6oz bottle of the Lucas oil low ash today, couldn't really measure it out so I dumped most of it in and left some in the bottle. If I keep doing it I'll find some better way of measuring. Either way, it worked. By the time I got home the crickets were gone. I'm being told that I shouldn't be adding anything though. People seem to very skeptical of this. I keep seeing it being asked and answered, but I still don't know if this is safe for the engine. I've put a question out to a relative that owns a car shop about it this. Hopefully he can provide a clear answer.
It's nice not having crickets, but killing a noise isn't worth hurting the engine.
Nevermore is offline   Reply With Quote
Old 05-28-2014, 08:28 AM   #4121
HunterGreene
Hail Magnet
HunterGreene's Avatar
Considering that the oil is designed to be consumed in the combustion process, and its "ashless," there shoudln't be much of a problem. Another owner who posted a couple pages back said that he hasn't seen any buildup on his oxygen sensor.
Also, most people are having good results with a small amount, maybe a capful (which usually comes to about 1 oz). That's the way I would go, anyways, finding the bare minimum that works.
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
sybrite (05-28-2014)
Old 05-28-2014, 08:51 AM   #4122
andrew20195
Drives: 2013 Subaru BRZ
It's in the TSB for the fuel pump chirp.
andrew20195 is offline   Reply With Quote
Old 05-28-2014, 09:38 AM   #4123
FR-S Matt
Hearing less and less chirps since I used the Lucas upper cylinder lubrication on this tank of gas. Only gone about 30 miles so far on this tank of 93 oct from Chevron. Need to use a bit more of it to confirm, but so far so good. I'll report back after a few tanks.
Old 05-28-2014, 10:54 AM   #4124
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
The noise (as determined by Fuji engineers) is caused by cavitation (bubbles) in the high pressure pump with certain fuel blends in certain conditions. It makes sense to me that adding a lubricant to the fuel can affect the noise, as the oil changes the surface tension of the fuel making it less likely to foam up.
The only potential downside is the additives may reduce the octane rating of the fuel, but 2 oz. per tank is negligible.
Cavitation is due uneven pressure regions in the fluid causing dissolved gases in the fluid to suddenly come out of the fluid (in areas of low pressure) and then suddenly get "pressed back into" the fluid in areas of high pressure. When you get a bunch of these areas of hi and low mixing, you get bubbles forming and collapsing insanely fast and the energy is exerted as shock waves which can result in sound and physical damage.
The bubbles don't produce foam per se but surface tension does affect the pressures it takes to allow the gases to come out of solution and then go back.
I am surprised at how this produces a squeak though - usually when a pump or propeller cavitates in a liquid it sounds like rocks are going through it.
Sauces:
- [ame="http://en.wikipedia.org/wiki/Cavitation"]Cavitation - Wikipedia, the free encyclopedia[/ame]
- My education and work
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
The Following User Says Thank You to Frost For This Useful Post:
HunterGreene (05-28-2014)
Old 05-28-2014, 01:29 PM   #4125
strat61caster
Thanks, I forgot Subaru specifically called it out.
The purpose of this bulletin is to provide information regarding a high-pitched "chirp", "squeak" or "cricket" sound you may hear coming from the engine’s high-pressure fuel pump. Not all pumps may exhibit this condition. Some may have internal components which in combination with certain fuel temperatures or fuel formulations, may result in aeration of the fuel within the body of the pump and cause this sound when the engine is idling. This result is non-detrimental to the fuel system or engine.
ineedyourdiddly
NIN69 (05-28-2014)
Old 05-28-2014, 01:46 PM   #4126
JoeC
Drives: Subaru BRZ Limited
I just filled up with my second consecutive tank of Ethanol free 91. Zero crickets regardless of the fuel level. Problem solved for me and the car runs a little better on straight gas. I'm not looking forward to the eventual scenario where I have to get gas with corn additive.
JoeC is offline   Reply With Quote
The Following User Says Thank You to JoeC For This Useful Post:
glorydays (05-28-2014)
Old 05-28-2014, 01:49 PM   #4127
mla163
Overthinking it
Drives: BRZ in CS
I'm not pouring ****ing oil in my gas tank.
mla163 is offline   Reply With Quote
Old 05-28-2014, 02:19 PM   #4128
mweidner311
Drives: N/A
Forgive me if this was already covered in the earlier pages of this thread but out of curiosity has anyone tried running Marvels Mystery Oil in the gas?
People have done this and most that do swear by it for decades now. Supposed to clean the fuel system, lube the upper cylinders, give your balls a tingly feeling ext ext.
Just wondered if it would help the crickets out since this would seem a safer alternative to using 2 stroke oil.
mweidner311 is offline   Reply With Quote
Old 05-28-2014, 02:25 PM   #4129
because racecar
Drives: 310 yards, Callaway xhot N14
Originally Posted by RobertB View Post
Anybody try Lucas Upper Cylinder lubricant/injector cleaner to quiet the chirps?
http://www.lucasoil.ca/products/prod...&cat=HeavyDuty
One ounce did not do the trick...
because racecar is offline   Reply With Quote
Old 05-28-2014, 02:31 PM   #4130
HunterGreene
Hail Magnet
Either that, or this is the best joke I've heard all day.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
