Old 05-26-2014, 02:25 PM   #5699
fenton
Originally Posted by robwbright View Post
Ok, so the arm switch is a true on/off switch for the ESC? With it off, there's no boost at all and I won't hurt anything..?
A couple questions/comments then:
1: What is the point of super pursuit mode or whatever it's called? I (apparently mistakenly) though it was an on/off for the ESC.
2: I stopped at dad's for just a couple minutes and forgot to disarm the ESC when I turned the car off. When I started back up, I threw three CELs:
U0073 - Network Electrical
P0102 - Mass or Volume Air Flow Circuit Low Input
P0113 - Intake Air Temp Circuit High Input
The traction control light (wheels spinning out) was also back on like it was when I first started the car after install.
I disarmed the ESC, turned off the car and cleared the CELs. Restarted and the CELs were gone, as was the traction control. Everything seemed fine after that.
Would starting the car with the ESC already armed cause the CELs?
I haven't had any trouble but if the compressor tried to surge as the car starts that could make the ecu freak out a bit.
Definitely double check all your electrical connections with that electrical error.
fenton is offline   Reply With Quote
Old 05-26-2014, 02:29 PM   #5700
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
I'm wondering if that has something to do with the traction control warning light coming on...
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 05-26-2014, 02:32 PM   #5701
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Is that the red fuse on a wire that plugs into the fusebox? If so, yes. But then how do we explain the CELs coming back?
If that's the case you don't need to turn the esc on or off from the voltage display. Just leave it on, and it will shut off automagically.
Installed Mods:
Old 05-26-2014, 02:33 PM   #5702
Sojhinn
Sojhinn's Avatar
Sometimes the traction control light will come on for certain cels.
Installed Mods:
Old 05-26-2014, 02:40 PM   #5703
robwbright
Ok, I'll just leave it armed. Unless it causes the CELs to come back again... LOL.
2006 Saab 9-3 2.0t
Old 05-26-2014, 02:42 PM   #5704
Sojhinn
Sojhinn's Avatar
I'm wondering if arming/disarming maybe one of the issues. Try it for a bit and see what happens.
Installed Mods:
Old 05-26-2014, 06:14 PM   #5705
Robftss
Drives: VW
Originally Posted by WNDSRFR View Post
Wow
I think Shiv's thankyou list includes every Phantom owner in the world.
Except for it's creator, Rob.
Can't wait for the E-85. It's going to be AWESOME!
Ha! ~ 3 thks/day via email-text.
Your 1/2 dump should be there tomorrow.
Rob.
Robftss is offline   Reply With Quote
The Following 3 Users Say Thank You to Robftss For This Useful Post:
nlowell (05-26-2014), Shiv@Openflash (05-26-2014), WNDSRFR (05-27-2014)
Old 05-26-2014, 06:47 PM   #5706
robwbright
Just went out and started the car again after leaving it armed. No CELs.
2006 Saab 9-3 2.0t
The Following 2 Users Say Thank You to robwbright For This Useful Post:
DAEMANO (05-26-2014), Sojhinn (05-26-2014)
Old 05-26-2014, 08:54 PM   #5707
TM
TM's Avatar
Drives: DGM BRZ 6MT
Are we positive that we don't need a new tune why the ofh?
I'm curious as well.
I remember one of shiv's comments regarding the sound change at around 3.5-4k rpm due to the aggressive VVT change (stage 1 tune) was that, if we don't want the aggressive VVT sound, get an aftermarket header so the VVT doesn't have to compensate as much at the torque dip range (stage 2 tune).
In short: if you hate the vvt tuning sound, go stage 2.
Wouldn't it make sense to have a less aggressive VVT tune in the torque dip range for ESC users with UEL headers?
TM is offline   Reply With Quote
The Following User Says Thank You to TM For This Useful Post:
jwSubMOA (05-28-2014)
Old 05-26-2014, 09:33 PM   #5708
fenton
Got the track pipe on today. No weird sounds at all. Absolute lovely sound though. Really feels like it is pulling harder now that I have the track pipe and header.
Looking forward to hopefully getting a little leaner afr curve and extracting more power.
Took my buddy with a 2013 stage 1 sti for a ride today and from 0 to 130km/hr he felt it was the same speed...... This is good!
Boost videos will come soon... It rained today.
The Following User Says Thank You to fenton For This Useful Post:
alexand3r (05-27-2014)
Old 05-26-2014, 11:55 PM   #5709
shif7i7down
Erected Member
Drives: frs
Man, idk what's going on. I still have that P0108 cel no mater what i do. It doesn't seem to affect the powet of the car so should i just ignore it? But it bothers me that i have a cel on.
shif7i7down is offline   Reply With Quote
Old 05-27-2014, 12:11 AM   #5710
fenton
Maybe @shiv@vishnu forgot to disable that cel in your tune? I don't know if that is how it works or if everyone gets the exact same?
What does the code stand for again?
Old 05-27-2014, 12:12 AM   #5711
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
What is your ROM type (CAL ID)?
Shiv@Openflash is offline   Reply With Quote
Old 05-27-2014, 12:24 AM   #5712
shif7i7down
Erected Member
Drives: frs
Phantom SC A01C
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
