Old 05-24-2014, 11:15 PM   #1499
brillo
Drives: 2013 Firestorm FR-S
Yellows match well with stock sways?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 05-25-2014, 08:29 AM   #1500
was385
Drives: MT WRB BRZ Limited, 2007 911s
That's a preference thing. I ran with yellows and stock sways but ended up beefing up my front sway for autox. There's nothing wrong with running the two together, it's just a question of how you want the car to behave.
was385 is offline   Reply With Quote
Old 05-25-2014, 11:22 AM   #1501
brillo
Id like it to main the stock feel which is fairly neutral with a hint of oversteer. More planted and a little less body roll. I don't want to make the car twitchy or prone to snap movements. I've been messing with cars long enough I know that it's not hard to make the handling worse than stock with the wrong set of springs. I'm not likely to go FI if that helps so likely staying with stock wheels and stock size tires.
Old 05-25-2014, 11:38 AM   #1502
Racecomp Engineering
You'll like the RCE Yellows. Get a good alignment and enjoy. Adding sways is easy later if you feel the need.
- Andy
Old 05-25-2014, 11:46 AM   #1503
was385
It will definitely improve the handling. And I'd say to leave the stock sways if that's what you're looking for. I will absolutely vouch for the yellows.
Old 05-25-2014, 12:09 PM   #1504
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
- Andy
This. If you want a bit stiffer suspension though, the RCE Tarmacs are good. Be sure to add a little front camber with any springs that lower your ride height as that will lead to a lot of understeer if you do not.
Sent from my SM-G900V using Tapatalk
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 05-25-2014, 01:30 PM   #1505
gramicci101
Off Topic
Andy and/or Miles,
Aside from height adjustability, is there any benefit to going with Tarmac Zeros over Tarmac springs and Bilstein shocks? The spring rate is the same either way. Thanks,
jeff
Old 05-27-2014, 10:02 AM   #1506
Originally Posted by gramicci101 View Post
Andy and/or Miles,
jeff
You can get a little lower and maintain more bump travel with the Tarmac 0 coilovers.
The Bilsteins may not have as much damping off the shelf as the Tarmac 0s, but can be revalved to be pretty awesome.
Two good choices.
- Andy
gramicci101 (05-27-2014)
Old 05-27-2014, 02:48 PM   #1507
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Two good choices.
- Andy
T0 is also stainless steel (B8, not SS)
fooddude is offline   Reply With Quote
The Following 2 Users Say Thank You to fooddude For This Useful Post:
gramicci101 (05-27-2014), Racecomp Engineering (05-27-2014)
Old 05-29-2014, 03:43 AM   #1508
scioneric
scioneric's Avatar
Drives: Firestorm FR-S
Does Swift Spec R spring over kill our stock shocks with its higher kg/mm?
scioneric is offline   Reply With Quote
Old 05-29-2014, 09:03 AM   #1509
IMO it's just a little too firm for the stock shocks. Not the end of the world to run them together, but I would not.
- Andy
scioneric (05-29-2014)
Old 05-29-2014, 01:20 PM   #1510
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Not sure if you considered this but you might want to look at strut tower bars as well, as an alternative to sway bars. From what I know, those are of a slight increase in steering response.
Old 05-29-2014, 01:31 PM   #1511
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I wouldn't bother with chassis stiffness on a car that has stock drive train and suspension bushings. That's where your largest compliance issues are with a stock car. Steering response increase that is truly noticeable is hard for me to see.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 05-29-2014, 03:09 PM   #1512
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
Leave the sways alone, and give the Swift Spec-R springs a try.
will we need new bump stops on a stock suspension?
SuperDave is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
