Old 05-22-2014, 09:19 PM   #1485
CSG Mike
CSG Mike's Avatar
Originally Posted by glamcem View Post
newbie question, how can I tape measure to toe? Can I simply use one of those level tools to see if it's changed? FYI, my toe was set to "0"
Thanks again
You'll need an assistant with a tape measure.
Pick a groove in the tire, put the "L" end of the tape measure in the groove against the tread block on the "front" side of the tire. Now read the measurement against the same groove on the other tire on that axle.
Repeat, but on the back side of the tire, at the same height as when you did the front side. The difference in front/rear is the toe you're seeing. Using a tape measure isn't perfect, but it'll at least tell you how much you're off if there was a change, and you'll always be able to zero out the toe using take measures.
Thrust angle is a different story, but this is more about "making it back home" without destroying your tires, or to do a quick spot check.
An alignment shop would be using a square rod instead of a tape measure, and scribing a line to measure with on the tires, for more precision.
glamcem (05-22-2014)
Old 05-22-2014, 11:05 PM   #1486
FRSGT86
FRSGT86's Avatar
Drives: 2013 Raven FR-S, 2005 Dodge Ram
Originally Posted by FRSGT86 View Post
So I'm 95% sure I'm going to go with KW V3s, looking to do a drop of no more than 1 1/2 inches. Now the question, besides the coilovers what else do I need to get? Crash bolts, adjustable top hats, something else I'm missing?
Just to add a little more info, I'm running 18x8.5 +44/235 40 fronts and 18x9.5 +38/255 35 rears
Hey guys still anxiously awaiting a response on this one.
2013 FRS 6AT in Raven!
FRSGT86 is offline   Reply With Quote
Old 05-23-2014, 04:12 AM   #1487
clintavo
Are you driving with any of the aids on?
Aids are off, but no pedal dance. Light to moderate braking to shift weight to the front results in more tire-punishing push. (225 Goodyear Eagle F1)
Will the pedal dance alone eliminate the plow?
clintavo is offline   Reply With Quote
The Following User Says Thank You to clintavo For This Useful Post:
CSG Mike (05-23-2014)
Old 05-23-2014, 04:25 AM   #1488
CSG Mike
CSG Mike's Avatar
I'd recommend RaceSeng CasCam plates, and SPL rear lower control arms.
PM us for a quote with all 3 packaged together.
You won't need crash bolts with this setup.
Old 05-23-2014, 04:26 AM   #1489
CSG Mike
CSG Mike's Avatar
If the plow is caused by EBD interfering with trail braking, yes.
clintavo (05-23-2014)
Old 05-24-2014, 12:47 AM   #1490
FRSGT86
FRSGT86's Avatar
Mike,
Tried to pm you for the quote but your mailbox is full.
Old 05-24-2014, 12:59 AM   #1491
CSG Mike
CSG Mike's Avatar
Mike,
You'd be surprised how quickly 5000 messages fill up.... try again please
Old 05-24-2014, 01:07 AM   #1492
FRSGT86
FRSGT86's Avatar
PM sent, thanks
For a guy like you I bet 5000 messages fills up quick!
Old 05-24-2014, 01:25 AM   #1493
CSG Mike
CSG Mike's Avatar
PM sent, thanks
Ahaha and to think I do this on a volunteer basis...
Old 05-24-2014, 05:11 AM   #1494
troek
troek's Avatar
Drives: 2012 Toyota 86
Well if ur ever in japan, on behalf of us greatful padawans, i got ur back.
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
CSG Mike (05-24-2014)
Old 05-24-2014, 11:34 PM   #1495
brillo
Drives: 2013 Firestorm FR-S
I'm struggling with coming up with a spring / sway bar combination that would be characterized as OEM+. I'm looking for a very modest drop and streetability that will allow for a bit more control and precession on my hpde days.
Thinking RCE yellows for springs but not sure on sways. I don't want to upset balance of the car. I run stock wheels and stock size tires just upgraded to Michelin PSS. I've already added camber bolts and steering rack bushings.
Suggestions for best solution at minimum cost?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 05-24-2014, 11:55 PM   #1496
CSG Mike
CSG Mike's Avatar
Leave the sways alone, and give the Swift Spec-R springs a try.
Old 05-25-2014, 12:10 AM   #1497
brillo
Not sure I want to drop that low, suggestions for springs less than an inch?
Old 05-25-2014, 12:13 AM   #1498
CSG Mike
CSG Mike's Avatar
RCE Yellows
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
