Old 05-25-2014, 11:18 AM   #1387
diirk
diirk's Avatar
Drives: 4Runner
Originally Posted by nelsmar View Post
Take a socket place it over the valve and unscrew it.
Yeah, yeah. LOL. I tried that.
The intake is in the way. I need to find my offset extensions and see if that will work.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 05-25-2014, 11:26 AM   #1388
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
Questions and Discussion on Vortech Supercharging Systems
It's do able just a bitch. You def need an offset extension. I had a hard time when I installed mine. What was even harder was finding a way to tighten it all down
marcoaferrer is offline   Reply With Quote
Old 05-25-2014, 11:58 AM   #1389
Cal3000
Drives: Panda FR-S
Originally Posted by Dezoris View Post
Thanks I will post up some things in this thread instead to add, as to not clog up the new one, recommend others do the same thing.
Can all Vortech owners post up your dynos in here on what tuner you had and what basic mods?
Maybe we should start a new dyno thread? It might get cluttered here.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following User Says Thank You to Cal3000 For This Useful Post:
marcoaferrer (05-25-2014)
Old 05-28-2014, 11:17 PM   #1390
Dezoris
Dezoris's Avatar
Not to clutter other thread do any of your run the oem resonator attached too vortech airbox? If so anyone dyno with and without? Vortech instructions dont say to use it
Old 05-29-2014, 12:45 AM   #1391
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Are you talking about the snorkel? If so, yes, I am still running it. From page 37 of the manual:
Install the airbox assembly onto the supercharger inlet and vehicle. Align the airbox to the mounting holes, forward facing inlet duct and previously installed airbox mounting bracket
HRTROB is offline   Reply With Quote
Old 05-29-2014, 12:07 PM   #1392
Dezoris
Dezoris's Avatar
@Brian@Vortech
Well if thats the case does it make a difference? Because that's not how I read the instructions because in page 8 section G:
Unplug the Mass Air Flow (MAF) connector from the MAF sensor
located on the air filter lid. Disconnect the rubber inlet duct from
the throttle and remove it with the air filter lid and set aside.
Unfasten the air filter box at the three mounts and remove.
Remove and save the rubber cushion mount assemblies and
hardware for reinstallation in a later step. The duct and other air
filter box components will not be reused.
Old 05-29-2014, 12:47 PM   #1393
HRTROB
HRTROB's Avatar
Drives: Toyota 86
@Brian@Vortech
I don't think they are referring to the intake duct "snorkel" because the bumper is still installed in that step. They tell you to remove the bumper later on at page 18 (page 25 on the PDF).
They are probably referring to the intake tube which they refer to as a "rubber inlet duct"
The Following User Says Thank You to HRTROB For This Useful Post:
marcoaferrer (05-29-2014)
Old 05-29-2014, 12:49 PM   #1394
marcoaferrer
^^^ agreed
Old 05-29-2014, 12:50 PM   #1395
Dezoris
Dezoris's Avatar
I never used the snorkel and wonder now if it makes any measurable difference.
Old 05-29-2014, 12:55 PM   #1396
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I'm guessing that you should have a louder induction sound without the snorkel? I'm not sure how the snorkel affects intake air temperatures since we have an intercooler.
Old 05-29-2014, 12:55 PM   #1397
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
idk, i use mine :shrug:
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 05-29-2014, 01:40 PM   #1398
nelsmar
I didn't use mine. I remember trying to do some checking of before and after from simple logging and didnt notice anything standing out as for IAT but it was a while back so I really don't remember. It seems as if I was getting a higher flow without the snorkel though. If I still had my unit I would test it =( It is possible to remove the snorkel without removing the bumper if someone was to test it. On an NA car the IAT's go up a fair bit but they don't have something cooling the air further in the pipework.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
Dezoris (05-29-2014)
Old 07-02-2014, 06:27 PM   #1399
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
finally got all my parts ready to install... CAN'T WAIT! Anyone in Chicago want to lend a hand/advice, have some drinks (preferably after the install, or maybe not!), on a long 4th weekend... send me a PM... you are more than welcome to join!
sissupr is offline   Reply With Quote
Old 07-12-2014, 11:48 AM   #1400
Cal3000
Drives: Panda FR-S
My factory Vortech belt finally broke after 32,000 moderately hard miles on the kit.
It completely peeled off one rib. I looked at all the pulleys and really couldn't determine the mode of failure.
I do know the belt dealigned itself one time with a portion of the belt riding the edge of the AC pulley for an unknown number of miles. I realigned it and drove for about 1,000 miles before I had this failure
My theory of the belt dealignment is that under sudden hard acceleration, the engine rotates which causes the belt to lose tension. It's probably a combined effect with the belt not being aligned straight on the idler pulleys.
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
