#5601 |
Time Traveller
| The Following User Says Thank You to DAEMANO For This Useful Post: | robwbright (05-23-2014) |
#5602 | |
Drives: SWP BRZ
My install was getting frustrating, until I found this helpful hint posted earlier in this thread. Unfortunately cannot recall the poster to thank them.
| The Following 3 Users Say Thank You to Gums For This Useful Post: |
#5603 |
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Thanks, guys. I didn't really want to tackle it by myself - I haven't really worked on car engines much other than oil changes, tire rotations, replacing window actuators, other minor stuff - I'm better working on dirt bikes. But when the ESC came today and my father in law wasn't available to assist... well, I just had to get it up and running.
The install probably took me a total of 3 hours of actual work time. Longer than some because I had to take a conference call and revise a contract right in the middle of installing the batteries and wiring. That's when I missed putting the brass/copper connector back on the main dump batteries... which caused me to have to redo about 20-30 minutes of work (I had already tightened down the battery pack and started hooking up wiring). If I hadn't missed that, I'd have probably been around 2-2.5 hours. Maybe I'm just slow. LOL. Of course, then I ran into the CEL issue, which was apparently just a matter of hooking up that connector I had forgotten to connect. But it took more than an hour of driving it, turning it the car off, looking around the engine compartment, posting on here again... Anyway... Now I've done a number of WOT runs. Frankly, it's night and day from stock. 3500 or even 3000 rpm has decent pickup, but from 4000 on it really takes off. My most recent (relatively) fast car comparison is my brother in laws Genesis 6cyl MT. The ESC BRZ is not quite that quick, but it feels to me like it's getting close. Quite of bit of fun actually being pushed back in your seat by a 2.0l 4cyl. I'll be interested to see if it gets even stronger in the next couple days as the batteries condition. It's enough right now that I'm quite pleased with the purchase. Finally, for someone who didn't even initially know what he was looking at with the sound tube (i.e. a newbie when it comes to car mods and I hadn't really studied the install instructions before beginning), I'd say that the instructions could be a bit more detailed. In several of the pics it was hard to see exactly what was going where and all that. Even the part about "removing the lower console panels" had me hesitate for a minute - I hate breaking things and I was a bit concerned about just pulling away without any instruction about how to remove them. A simple addition to the instructions like, "It's easy - just pop the plastic rivets loose on the left, middle and right of each panel" would have helped. But that's just me. All that said, the instructions were detailed enough to figure out what was going on (especially with the live customer support from you guys on here). Aside from those minor quibbles, the kit itself is VERY WELL DESIGNED. The cables and wires are all as long as they need to be to give you a little extra but not so long that you're trying to figure out where you're going to put the rest. The install of the ESC itself is very simple. It's putting the batteries all together and doing the wiring that takes awhile. Great work, Rob! And thanks again, guys!
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe 2006 Saab 9-3 2.0t 1997 Honda Accord Coupe 1995 Honda Prelude VTEC |
#5604 | |
Drives: WRBrz
@DAEMANO and I were scratching our heads on how we got his to fit better than mine...mine looked exactly like the picture...
then I saw your advice, and had to go fix the fitment right away...even tho I just did 5+ wot pulls...hands are a little singed right now but it was worth it ![]() Thank you so much for the tip @Gums!! Quote:
EBSC - dt.FF - MXP CompRS
| The Following User Says Thank You to WRB5titch For This Useful Post: | Gums (05-23-2014) |
#5605 | |
Drives: SWP BRZ
#5606 |
Drives: 2013 Scion FRS
Nice job guys. Post up some logs. Second gear 3k to redline then third gear same. Third will get you some speed so you might need to do that on a freeway
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
#5607 |
Also, before you start logging, on the OFT go to customize channels, turn off something you don't need, then go down all the way to the bottom and turn on boost logging.
#5608 |
I didn't even realize boost logging was an option. Thanks!
#5609 |
#5610 |
Log 3 - you'll probably see a couple odd things in there - I'm still getting used to the extra power. I tried a couple fast launches and I over-clutched trying to avoid wheelspin.
http://www.datazap.me/u/robwbright/e...3?log=0&data=1
#5611 |
Drives: 2013 Subaru BRZ Premium
#5612 | |
Drives: Viper, Mustang, FD RX7, FFR GTM
Progress sounds awesome, Open source? Guys using a Tactrix, or still the Tablet thing and TunerPro? |
#5613 |
Custom User Title
Drives: Spaceship
So I received the correct battery today and the install went great. I'm on a 6AT and I am quite impressed with this system for the cost. In Sport Mode it holds boost (throttle down the whole time), shifts in the blink of an eye and just KEEPS PULLING through the gears... my batteries aren't even conditioned yet...
----------- Story Time ----------- I was out "conditioning the batteries" and a 350Z pulled up next to me. It was lowered, had exhaust and who knows what else. Anyway, I was by myself and he had someone in the car... but I pulled a full car length ahead of him on our way up to 70 (highway), which really surprised me.
| The Following User Says Thank You to alexand3r For This Useful Post: | raven1231 (05-24-2014) |
#5614 | |
It changes the car, in a good way ![]() Just think you got the battery break in and 1.5 conversion still as well
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
