Old 05-23-2014, 08:33 AM   #71
Lord Peth
Drives: 2014 BRZ
Well, the cotter pin came out in about 15 seconds and I just spent 20 minutes trying to remove that ^%&*%*&*&%!! spring. I am now irritated in the way that only a car can provide. Going to have to get a robogrip from work I guess
Lord Peth is offline   Reply With Quote
Old 05-23-2014, 08:45 AM   #72
Nhil
Drives: 2013 Scion FRS
After removing the pin I depressed the clutch pedal and just gave the top of the spring a few good jabs with a punch. It came off super easy.
Nhil is offline   Reply With Quote
Old 05-23-2014, 09:06 AM   #73
Rinn310
Drives:
Besides making the clutch easier are there any actual uses to this spring? Does taking it out increase any wear or have any negative effects to speak of? Started on old school Toyota clutches and hate the new feel. Just wondering if there are any negatives to taking this out.
Rinn310 is offline   Reply With Quote
Old 05-23-2014, 10:01 AM   #74
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
I would think that, if anything, removing it would actually cause less wear, as there is no longer any extra pressure always acting (slightly) upon the clutch pedal.
Just my guess, of course. I'm just a guy, and it's been a while since I last spent the night at a Holiday Inn Express.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 05-23-2014, 07:02 PM   #75
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
Size:  84.4 KBName:  uploadfromtaptalk1400886062318.jpg
Not easy to see but this is what the metal brackets blocking the clutch assembly looks like on a RHD.
Sent from my HTC_0P6B using Tapatalk
blue cat is offline   Reply With Quote
Old 05-23-2014, 07:16 PM   #76
Slysdexia
Slysdexia's Avatar
Drives: '14 Monogram 6MT FR-S - Hot Lava
That's a problem.
Sent from my PO-T4T0 with Eyes.
Slysdexia is offline   Reply With Quote
Old 05-23-2014, 07:16 PM   #77
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
I just did this mod today and adjusted the pedal to 1-2mm above the brake. This is a MUST DO mod.
Sent from my LG-D800 using Tapatalk
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
The Following User Says Thank You to zdr93523 For This Useful Post:
xxBrun0xx (05-25-2014)
Old 05-23-2014, 08:50 PM   #78
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I'm sorry to say, but that is going to be a PITA. Why in the hell would they do that?
You might need one of these
But for reference, I did it with channel locks. To find out what worked, I pushed away and pulled the spring/perch towards me, as well as wiggled it sideways to try and get it loose.
unsurety is offline   Reply With Quote
Old 05-23-2014, 08:51 PM   #79
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
just did it a few minutes ago. I tried the ziptie idea, but didn't work out so well. Between the spring pressure, the grease all over the spring, and the amount of coils open ~1-2, my 5 medium zipties all either broke, or slipped. But what really worked well, was once I had the pin out, I used a pair of channel lock pliers, with the pedal up I just clamped the top and bottom spring pearches in the jaws, then pressed the pedal to the floor with my other hand, let go with the pliers and it shot right out. If I like it I'll be trying to remove the other perch.
and yeah, it sucked bad enough on mine, RHD looks like a dog in heat.
Target70 is offline   Reply With Quote
Old 05-23-2014, 09:06 PM   #80
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I think the zip tie idea was for putting the spring back in.
The Following User Says Thank You to Andrew025 For This Useful Post:
Slysdexia (05-23-2014)
Old 05-23-2014, 09:14 PM   #81
Panda Mao
Panda Mao's Avatar
Drives: 2014 Scion FRS
I am curious to try this hen I first got the car I kept stalling all over the place cuz it felt so soft and I couldnt tell where the clutch bite was but now after driving for 2 months more or less I've gotten used to it and am now able to press the clutch and shift between all gears in less than a minute with no issues even in stop n go traffic I havent had any issues dunno if my left foot just adapted or I have some kinda placebo effect on me
Panda Mao is offline   Reply With Quote
Old 05-23-2014, 09:30 PM   #82
Slysdexia
Slysdexia's Avatar
You adapted. Realistically, I could have chosen to adapt but I knew about this head of time and had some time to kill after dropping off the check for the car, so out it came and I instantly had no trouble shifting smooth.
Old 05-23-2014, 09:40 PM   #83
Target70
Target70's Avatar
true, but if it works to put it back in, why not to take it out? Well I found out, the problem turns out to be access to more than just two coils. With it sitting in front of me I should be able to get zip ties around 4 coils, but in the car, with the pearches in the way, I could only get 2, which just wasn't enough to compress the spring when the pedal was pushed in.
I really haven't had a chance to drive with it (did it on break at work), but just from sitting in the car and feeling it, I think the issue is the progressive rate of the spring. The pedal is not much different near the floor between helper spring and no helper spring, but up top it is a lot harder to get started without the helper spring. Now that it is out, It feels like the same force is needed to push the pedal all through the range, insted of light at the top progressing to heavy at the bottom. Plus now I just found out the disengagement point is really close to the floor.
Old 05-23-2014, 10:55 PM   #84
Toxzik
Drives: Subaru BRZ CBS limited
Did this today all I can say is WOW I have a clutch now!
Toxzik is offline   Reply With Quote
clutch helper spring, helper spring removal
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
