Old 05-22-2014, 02:13 PM   #1681
xwd
Yeah in the end it's just a bunch of pipes, hoses, and clamps and doesn't really need any super special tools. I would recommend first laying everything out as it's supposed to be installed with all the hoses, connectors, clamps, etc. and take a picture of it to reference as you go along.
In the end yeah I would budget 2-3 days, there are lots of little things which add up time wise. A pro who has done a couple could easily do one in a day.
Does the FBM kit come with sealant for the oil pan?
Old 05-22-2014, 02:23 PM   #1682
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Nope, but your local Subie/Yoda dealer sells it.
Also make sure you guys do the checklist FBM provides!
Ironsquid is offline   Reply With Quote
Old 05-22-2014, 02:34 PM   #1683
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I did the checklist and the item I was missing was checked on the list, haha. Make sure you have your fuel rail spacers and bolts.
Old 05-22-2014, 02:36 PM   #1684
King Tut
NASA SpecE30 Racer
King Tut's Avatar
All the Subaru EJ motors had their oil pans sealed with Fuji Bond while for some reason the FA20 motor calls for a super rare Three Bond product that the dealer probably won't have the exact product referenced in the factory service manual. I went with the Fuji Bond and never had any leaks. The Subaru dealer will definitely have a tube of it. I consider it a more watery version of Honda Bond.
Old 05-22-2014, 03:26 PM   #1685
xwd
I still have some tubes of Fuji Bond laying around. I went with the RacerX pan which has its own rubber gasket, but was just curious because it's one of those things most people probably don't have laying around.
Old 05-22-2014, 05:15 PM   #1686
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
It's just another bolt on
Take your time, and allow yourself plenty of time to do the work. I knew what I was doing but I still allowed myself two full days dedicated to it.
i want to take 3 days off . so i can make sure i take my time. just hope i can understand everything
FRS-HHH is offline   Reply With Quote
Old 05-22-2014, 05:16 PM   #1687
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
oem or need extra? for the fuel rail spacers and bolts
Old 05-22-2014, 07:33 PM   #1688
King Tut
NASA SpecE30 Racer
King Tut's Avatar
There are no OEM spacers. Some of the aftermarket injectors are taller than the OEM ones so that the fuel rail will no longer bolt down. That means you need the 1/2" spacers and 1/2" longer bolts to bolt the fuel rails down.
Old 05-22-2014, 09:05 PM   #1689
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
Gotcha just making sure 👌
Old 05-24-2014, 11:04 PM   #1690
Boba_kz
257F oil temperature while boost is the problem? What is maximum allowed?
Should I install oil cooller?
Boba_kz is offline   Reply With Quote
Old 05-25-2014, 12:22 AM   #1691
eazyace
Drives: wish
Quick question guys as i am in curious in buying this kit. How often do you clean the intake and is difficult to get to it once bumper is installed?
Thanks
eazyace is offline   Reply With Quote
Old 05-25-2014, 08:50 AM   #1692
Boba_kz
Kit radiator fans doesn't work. Anybody else who experienced the same problem?
Tested it, seems motors not functional. Fuses are ok. It was second day after kit installed.
Old 05-25-2014, 09:16 AM   #1693
mike the snake
My kit supplied slim fans died very quickly. Fans died from heat while the car was on the dyno.
After switching to the FB radiator, Spal fans and FB shroud, and moving the radiator forward to gain clearance, everything is working wonderfully now.
The Following 3 Users Say Thank You to mike the snake For This Useful Post:
Boba_kz (05-25-2014), Hachiroku14 (05-27-2014), Lonewolf (05-25-2014)
Old 05-25-2014, 10:43 AM   #1694
Boba_kz
Thanks
What is model or size of spal fans you used?
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
