#29 | |||
#30 |
That's from @FullBlown 's tranny, 700+ whp I believe. My tranny has messed up synchros but I'm sure I'll shear a tooth
The Frozen North
#31 | |
Diameter does have a slight affect on it because it can limit the pitch you can use, but you would need extremely small diameters before that comes into play.
#32 |
Subaru Certified Sales
Drives: '13 BRZ Premium, '05 WRX STi
Sorry to hear about the trans letting go, @JK21. The FRS is a beast! I really can't wait for you to turn it up. Sucks that the tranny will be a delay but I'm sure it will be back better than ever.
![]() Oh, btw, I'm the Asian dude who troubled you while swapping on your radials and was amazed that you actually fit a 275 on the back.
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85 [Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s [Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans "The only thing that I trust in this world is cars!" - Don 'The Goods' Ready |
| The Following User Says Thank You to Boss Paco For This Useful Post: | JK21 (03-17-2014) |
#33 |
An oil cooler and pump would go a long way towards making our transmissions hold up with big power on track days, where the trans does get hot/heat soaked.
Years ago when I was researching transaxles for a racecar I was building, I found info on the old Porsche 911 gearbox (model 915) which had a torque max of like 180 ft/lbs, but the higher up gearbox was rated for something like 225 ft/lbs, and the only difference was a cooler and pump. With gearboxes, bad things happen when they get hot. |
#34 | |
#35 | |
Drives: 2013 GBS BRZ Limited
One of the reasons I stated that 4th is less likely to fail is that (in this car at least) 4th & 5th are the two gears closest to 1:1 ratio (4th = 1.213, 5th = 1), so in those two gears the drive shaft gear and the lay shaft gears are almost the same size so they share almost equal stress. (5th may not have any "gears" as it might just connect the drive shaft to the input shaft directly - that is one case where different trannys can be different). If that is the case, then 4th has the lowest stress on gear teeth than any other gear (in this tranny) 1st is 3.626, so the smaller of the two gears in that pair would have the greatest stress of any gear in the stack. 2nd is 2.19 so would have the 2nd higest stress, etc. Sorry to continue to show my ignorance of the subject
#36 |
Placement of the gears on the shafts has a lot to do with failures too. If the gears are far away from the bearings or supports, then under load the shafts can flex, causing the gears to push away from each other.
#37 |
Drives: Attitude
#38 |
That guy
Drives: Ultramarine mt FR-S
With all of these transmission failures above 400 hp (300ish tq) it seems that I am on borrowed time. I'm starting a project to come up with an inexpensive (not v160) that will hold sufficient power. I have a plan of attack, and hopefully I get some good news after my trip to the you-pull-it tomorrow.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
| The Following 2 Users Say Thank You to Hawaiian For This Useful Post: | kiichiro (05-22-2014), Sportsguy83 (03-26-2014) |
#39 |
#40 |
| The Following User Says Thank You to stugray For This Useful Post: | Sportsguy83 (05-22-2014) |
#41 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Enjoying 300+ hp at the track as well
INDE this weekend and realizing this is a ticking time bomb for us all
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
#42 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | Sportsguy83 (05-22-2014) |
| Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode | SteveH | Other Vehicles & General Automotive Discussions | 7 | 02-13-2013 12:08 AM |
| Reverse Gear not going into gear? MT | joergasm | Issues | Warranty | Recalls / TSB | 22 | 11-29-2012 12:08 AM |
| No more 1st gear thump or 2nd gear notchiness | kc4mne | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 09-06-2012 08:39 PM |
| 5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 07:44 PM |
| Reverse gear on the first and second gear side | randytindoggy | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 01-29-2012 01:21 PM |
