Old 05-21-2014, 08:19 PM   #1457
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Well to make things easier on you, we don't really have an ETA on our own RCE plates. Just having major supply issues, so go with the Raceseng tops. The HVTs are good as well.
- Andy
When I am financially ready to purchase plates, I'll message you just to see if by any chance things have changed regarding your RCE plates.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
The Following User Says Thank You to Turkish For This Useful Post:
Racecomp Engineering (05-21-2014)
Old 05-21-2014, 08:28 PM   #1458
juliog
juliog's Avatar
Drives: 86
It stabilizes the car; zero toe will result in a car that wants to follow all the cracks and grooves in the road.
^ This. After zeroing out my toe, I no longer (dare to) drive on the freeway with only one hand on my steering wheel. Car can feel loose when going over over the lines where old and newer pavement meet.
juliog is offline   Reply With Quote
Old 05-21-2014, 09:05 PM   #1459
CSG Mike
CSG Mike's Avatar
You need to relax your grip :p
Old 05-21-2014, 09:23 PM   #1460
chadori
chadori's Avatar
Drives: brz
It stabilizes the car; zero toe will result in a car that wants to follow all the cracks and grooves in the road. It also stabilizes the car under hard cornering/power, but at the (minimal) cost of ultimate grip.
A track aligned car on the street my get some camber wear, and feel slightly skittish, but nothing unmanageable if you're doing one track day every 2 months, and are always holding on the steering wheel.
Seriously, some people drive without hands on the steering wheel...
That's very possible, depending on the alignment, and how it affects contact patch.
Also, if you get square tires, you have the ability to rotate the tires for maximum life and even wear.
Assuming we're talking the same tire compound, I'd take the car with the narrower tire and great alignment.
Yes go square with wheel and tire width.
- Andy
So all in all get same width wheels and tires. Is that what is meant by "square"? Let's say that one were to get 17x9's for the sake of running a wider tire and potential for more contact patch.
Now, I'm assuming the amount of contact has to do with the alignment? (correct me if i'm wrong), thus theoretically, a 17x9 on 245's can do better than the 17x8's on 225's, if and only if the alignment is better??
Sorry if these questions may seem redundant, the brz is my first rwd
Thanks for all the help thus far
chadori is offline   Reply With Quote
Old 05-21-2014, 09:25 PM   #1461
CSG Mike
CSG Mike's Avatar
Yes, otherwise you'd be using just the outer (or inner if you have WAY too much camber) edges of your tires under cornering.
A 245 will be more stable and forgiving under cornering, and more difficult to break loose, but a 225 is generally faster (not always, but most of the time) overall.
Old 05-22-2014, 02:20 AM   #1462
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
It sounds like it's kinda the same as the rear fins stabilizing an arrow or a dart - the rear fins give slight "resistance" and drag, to stabilize the front mass and forward momentum, without too much resistance.
...maybe this is an easier way to understand it.
fooddude is offline   Reply With Quote
The Following User Says Thank You to fooddude For This Useful Post:
CSG Mike (05-22-2014)
Old 05-22-2014, 02:20 AM   #1463
fooddude
Originally Posted by normancw View Post
...and alignment settings from @CSG Mike
Can you please share Mike's magical settings?
Old 05-22-2014, 03:48 AM   #1464
CSG Mike
CSG Mike's Avatar
It varies with every car... my recommendations are not generic.
Old 05-22-2014, 12:18 PM   #1465
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Originally Posted by solidONE View Post
I've found a complete coilover system...for just above $5K!
Nitron suspension:
http://www.nitron.co.uk/Automotive/T...gt86-12-ntr-r3
At today's exchange rate, that's just above $6K, and still inexpensive for a quality 3-way. FWIW, there are quite a few UK-based cars running Nitrons - it's common to see them in used race car listings.
dradernh is offline   Reply With Quote
Old 05-22-2014, 12:41 PM   #1466
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Just ordered a set of T2's! Excited!
The Following 5 Users Say Thank You to ATL BRZ For This Useful Post:
buddy32 (05-22-2014), CSG Mike (05-22-2014), fooddude (05-22-2014), Racecomp Engineering (05-22-2014), was385 (05-22-2014)
Old 05-22-2014, 12:52 PM   #1467
buddy32
Drives: WRB Subaru BRZ Limited
In process of finishing up the install of the T2s! Thanks @normancw for all the help with the install questions!
buddy32 is offline   Reply With Quote
Old 05-22-2014, 02:04 PM   #1468
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Yes your right about the exchange rates, but I've found a place listing them for just over $5K. Although... they have none in stock. Reason they give is that they are still under development.
The Following User Says Thank You to solidONE For This Useful Post:
dradernh (05-22-2014)
Old 05-22-2014, 02:26 PM   #1469
fooddude
Originally Posted by ATL BRZ View Post
I haven't heard of any coating/rust issues recently with the Teins.
I know it's biased quoting their site, but this seems pretty comprehensive:
"9. Thoroughgoing Rust-Proofing!
Upper mounts and lower brackets are coated with rich TEIN green powder paint. This powder paint has high coating film strength, is highly durable yet is low-pollution due to non-use of harmful solvent. After the shot blasting pre-treatment, the patented "2-layer/1-bake" treatment using anti-rust powder paint is applied for superior durability and high corrosion resistance. (Patent No. 4347712)
On shell case, TEIN's self-developed one-of-a-kind "ZT Coating" is applied, for tougher protection against chipping, often caused by bounced pebbles, and rust. With zero claim rate, against adhesion, out of 500,000dampers sold, we are confident that people living in snowfall area or near seashores would even be very satisfied."
I read this too about their "one of a kind coatings" and thought it was funny.
To me, and to be frank, it sounds like marketing BS.
Any company can and will say they have this or that as their special magical coating..made out of gold and diamonds, puppies and kittens, that will protect your coilovers. The only real truth is by looking at used pics from real users (for any coilover)
Just do a simple google search and you will see EVERY used Tein is very chipped, paint peeling, ugly and a bit rusting/corrosion on both the bodies/mounts and threads. Yes, I know no coilover is indestructible and others have rusting too ..but used Teins seem to appear the worst over time to be honest.
This does Not really give me any confidence in their product. I don't care how good the valving and design is.. if I have to worry that my Tein coilover will crumble like an ancient roman temple in a few years..then forget it.
Heck..even Tein admits their stuff needs touchups:
http://teinusa-blog.com/touch-ups-anyone/
*even in this touch up blog post..you can see heavy rust under the chipped paint. IDK what metal material Tein uses; but it surely doesn't look like a premium metal. Anyone know what metal material Tein uses for their lower mounts and bodies??? That rust and coilover looks like it came from an American Pickers episode lol (and I bet it was only a few years old).
At least Bilstein and KW use Stainless Steel iirc.
Anyways..nice to hear you went for the RCE's
Edit:
To be honest, I've never looked into materials used, or as a priority, much until now (I've only been concerned about performance, history, reviews, damping, etc.). But, the more I read into it, it seems like most "JDM" coilovers do not list as Stainless Steel built; and most German ones are SS. And, I think materials should be one of the top deciding factors for a DD/street coilover (since we'd prolly never change them out and they will be on the car for years to come...as opposed to true race cars that change out and rebuild parts every season/session).
So, with that being said...which JDM coilovers actually have Stainless Steel build? Or, are they all, or the majority of them, made out of galvanized steel?
It would be nice to make a list of which are galvanized and which are SS (maybe this feature, should be included in the FT86club Options List suspension-coilover description directory: http://www.ft86club.com/forums/showthread.php?t=8739)
ATL BRZ (05-22-2014)
Old 05-22-2014, 03:13 PM   #1470
CSG Mike
CSG Mike's Avatar
@fooddude: our Teins are stainless in the front (inverted strut) and Aluminum in the rear.
You're welcome to stop by and hold them in your hands, and inspect them yourself
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
