Old 05-22-2014, 01:07 PM   #1
mankarn86
Drives: 2007 Altima 3.5 SE 6sp
Question Headliner ticking/rattle
Having trouble getting the dealer to rectify a rattle/metallic ticking sound in the headliner. I'm pretty sure it's in the headliner or possiblly under the C pilar cover because if I put my hand over the headliner close to the passenger side or middle the rattle goes away. I have exhausted the forums for tips and so far this is what I could come up with for potential culprits:
- antenna cable
- bolts under the headliner near the side airbag not tightened
- metal bracket that support the side airbag in the C Pilar
So couple questions...has anyone tried to get up there to tighten/dampen anything under the headliner? I removed the C pilar cover on the passenger side and the headliner clips and there still isnt enough room to clear my hand to get a socket wrench in there without creasing the headliner. Is it possible to shimmy the headliner off the B pilars by just removing the clips and the C pilar cover?
mankarn86 is offline   Reply With Quote
Old 05-22-2014, 01:14 PM   #2
Muskokan
Drives: white Sport-tech
Subbed, sounds like my passenger side super annoying in the morning till I turn the heat on then goes away. Taken the door panel off twice to rectify but couldn't solve it. Maybe the tweeter housing right above the vent? Think that's where I'm trying next
Muskokan is offline   Reply With Quote
Old 05-22-2014, 01:21 PM   #3
mankarn86
Is you issue near the front or the rear of the car? Mine is near the C pilar (most rear pilar).
Old 05-22-2014, 03:51 PM   #4
Muskokan
Ah sorry I saw pillar and assumed, mine is at the front by the (a?) pillar. Faack in annoying haha
Tapping/Ticking in 2nd gear radroach Issues | Warranty | Recalls / TSB 5 03-02-2014 05:00 PM
Ticking sounds from exhaust when off Kefu Issues | Warranty | Recalls / TSB 26 12-20-2013 02:11 PM
Ticking sound, under load norsamerican Issues | Warranty | Recalls / TSB 1 12-19-2013 03:53 PM
Rattle in drivers side headliner-help! meadowz06 Issues | Warranty | Recalls / TSB 5 09-18-2013 10:44 PM
ticking noise? iHeartmyFR-S Issues | Warranty | Recalls / TSB 13 04-18-2013 05:42 PM
