#239 |
Drives: 2014 Scion FR-S
So it seems shifts are tougher and sloppier than stock/kart boy from what i read here. Would this plus mtec be perfect fit /solution?
Sent from my SM-G900T using Tapatalk |
#240 |
Drives: 2014 WRB BRZ Limited
Shifts are tougher, but will not be as tough as Kartboy. This has to do with the longer shift lever. The shifts are also not sloppy in the slightest. If you've torqued everything down properly, there is virtually no play in the shifter at all with everything else being stock. Not sure if the Mtec would make a big difference, maybe someone who has both can chime in.
#241 |
Trust me, I'm the Doctor
I have the kartboy short shifter, rear bushing & Mtec springs. The shifter is not at all tough or sloppy to shift with even with a very lightweight knob.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
| The Following User Says Thank You to SirBrass For This Useful Post: | Sportsguy83 (05-22-2014) |
#242 |
Drives: DGM BRZ 6MT
I just received the quick shifter today.
Reading through the instruction manual: are the deep sockets and 8" extension necessary to reach the nuts?
#243 |
Just the tip
For me it was
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| The Following User Says Thank You to stockysnail For This Useful Post: | TM (05-21-2014) |
#244 |
Drives: DGM BRZ 6MT
I scanned the instructions into a PDF for anyone who wants to look at it.
| The Following 11 Users Say Thank You to TM For This Useful Post: | aaguirre123 (06-08-2014), aristo (09-03-2014), Carlitoz3 (07-14-2014), Cop (10-09-2014), jcw99 (12-07-2015), Kimsey47 (07-30-2014), Koa (12-19-2014), MonoRaven (07-27-2014), Sportington (10-08-2014), voyager2285 (05-14-2015), xxBrun0xx (05-21-2014) |
#245 | |
Drives: Attitude
You will not be able to unbolt the rear stay bushing without the extensions. A flex socket and extension would be your best bet - there's just not much room in there when coming in from underneath. |
#246 | |
Drives: DGM BRZ 6MT
Any other bolts I should be using Loctite on?
#247 | |
I haven't tried a Kartboy, but I would think that due to the shorter shifter height, it would require more effort than stock/TRD quickshift. I'm thinking about moment arms, but it may actually not be that simple because the pivot point is not the same on the two shifters, so who knows? |
#248 |
It does require some additional effort, but when you're actually driving you don't really feel it. You just do it and the gears go through the gate with more positive "click".
#249 |
Just the tip
I posted this last week but got no responses. Perhaps some of you can go 45mph or so and slam the brake pedal as hard as you can (to simulate track day or emergency stop) while holding or touching the shifter to see if the drive shaft rubs the shifter rod.
------------------------ Anyone else have any issues under very hard braking and large speed bumps with the bottom of the shifter hitting the stock drive shaft? I noticed it when I was auto crossing and also when going 30 over those long wide speed bumps. I'l a little worried. I wonder if Perrin engine mounts would stiffen it up enough where it doesn't flex to hit the shaft...
#250 |
Just the tip
I'm definitely rubbing on the stock drive shaft when hard braking in 2nd but not in 3rd. This doesn't bode well for track days.
| The Following User Says Thank You to stockysnail For This Useful Post: | gonzo (06-02-2014) |
#251 |
Drives: Asphalt Scion FR-S
Are you guys that are rubbing have stock driveline mounts, as in engine, transmission, or differential mounts?
I have Cusco engine, Kartboy trans, and Whiteline diff mounts, and occasionally get knocking on speed bumps with the stock driveshaft. Haven't noticed it on track though. Sent from my SCH-I535 using Tapatalk
| The Following User Says Thank You to JDKane527 For This Useful Post: | unsurety (05-22-2014) |
#252 |
aeiou
Drives: WRB BRZ
| TRD Quickshifter | lovebeingbleu98 | Brakes, Suspension, Chassis | 3 | 02-13-2014 12:14 AM |
| Amazing Wax | geb2391 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 04-12-2013 04:42 PM |
| The most amazing thing I've done with my BRZ so far | azngolfur | BRZ Photos, Videos, Wallpapers, Gallery Forum | 8 | 01-09-2013 08:23 PM |
| Concept-Three-LED's DRL's are AMAZING! | soros151 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-09-2012 01:42 AM |
