Old 05-20-2014, 03:00 AM   #239
DC2R
Drives: 2014 Scion FR-S
So it seems shifts are tougher and sloppier than stock/kart boy from what i read here. Would this plus mtec be perfect fit /solution?
Sent from my SM-G900T using Tapatalk
DC2R is offline   Reply With Quote
Old 05-20-2014, 12:48 PM   #240
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Shifts are tougher, but will not be as tough as Kartboy. This has to do with the longer shift lever. The shifts are also not sloppy in the slightest. If you've torqued everything down properly, there is virtually no play in the shifter at all with everything else being stock. Not sure if the Mtec would make a big difference, maybe someone who has both can chime in.
xxBrun0xx is offline   Reply With Quote
Old 05-21-2014, 03:36 AM   #241
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
I have the kartboy short shifter, rear bushing & Mtec springs. The shifter is not at all tough or sloppy to shift with even with a very lightweight knob.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
The Following User Says Thank You to SirBrass For This Useful Post:
Sportsguy83 (05-22-2014)
Old 05-21-2014, 10:26 AM   #242
TM
TM's Avatar
Drives: DGM BRZ 6MT
I just received the quick shifter today.
Reading through the instruction manual: are the deep sockets and 8" extension necessary to reach the nuts?
TM is offline   Reply With Quote
Old 05-21-2014, 10:41 AM   #243
stockysnail
Just the tip
stockysnail's Avatar
For me it was
The Following User Says Thank You to stockysnail For This Useful Post:
TM (05-21-2014)
Old 05-21-2014, 11:09 AM   #244
TM
TM's Avatar
Drives: DGM BRZ 6MT
I scanned the instructions into a PDF for anyone who wants to look at it.
File Type: pdf trd quick shifter instructions guide.pdf (2.67 MB, 1050 views)
The Following 11 Users Say Thank You to TM For This Useful Post:
aaguirre123 (06-08-2014), aristo (09-03-2014), Carlitoz3 (07-14-2014), Cop (10-09-2014), jcw99 (12-07-2015), Kimsey47 (07-30-2014), Koa (12-19-2014), MonoRaven (07-27-2014), Sportington (10-08-2014), voyager2285 (05-14-2015), xxBrun0xx (05-21-2014)
Old 05-21-2014, 11:10 AM   #245
OrbitalEllipses
Drives: Attitude
Purty sure my 5th gear issues are a result of the rear stay bushing. Took it out and suddenly (while there's more slop of course) I no longer have resistance going into 5th at speed.
You will not be able to unbolt the rear stay bushing without the extensions. A flex socket and extension would be your best bet - there's just not much room in there when coming in from underneath.
Old 05-21-2014, 11:44 AM   #246
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by tjohnson104 View Post
the bolt that comes with it is dipped in some type of thread lock. It looks like rust, but its there to make sure it wont come off
Is this good enough or should I use Loctite on that adapter bolt?
Any other bolts I should be using Loctite on?
Old 05-21-2014, 12:35 PM   #247
xxBrun0xx
xxBrun0xx's Avatar
Blue loctite for sure. I actually was trying to put the adapter on backwards at first (who needs directions, anyways?) By the time I was putting everything together properly, I had no loctite no the end of the bolt. I figured it would be fine. After about 500 miles, I noticed the shifter slop was back from the video I posted a few pages ago. Jacked the car up and tightened it in a parking lot with an allen key that didn't fit right I bought from a local autozone since I was about 2 hours from home with no tools and no garage. Despite that, it kept loosening up that weekend, but the bolt never came completely off. Threw the car on the lift when I got home and covered that bolt with blue loctite. I was at my sister's graduation and it was pretty embarassing having to jack up my car and get under it, considering it hasn't even had its first oil change yet. Seems to be holding just fine now, though, as expected.
I haven't tried a Kartboy, but I would think that due to the shorter shifter height, it would require more effort than stock/TRD quickshift. I'm thinking about moment arms, but it may actually not be that simple because the pivot point is not the same on the two shifters, so who knows?
Old 05-21-2014, 01:31 PM   #248
SirBrass
SirBrass's Avatar
It does require some additional effort, but when you're actually driving you don't really feel it. You just do it and the gears go through the gate with more positive "click".
Old 05-21-2014, 03:34 PM   #249
stockysnail
Just the tip
I posted this last week but got no responses. Perhaps some of you can go 45mph or so and slam the brake pedal as hard as you can (to simulate track day or emergency stop) while holding or touching the shifter to see if the drive shaft rubs the shifter rod.
Anyone else have any issues under very hard braking and large speed bumps with the bottom of the shifter hitting the stock drive shaft? I noticed it when I was auto crossing and also when going 30 over those long wide speed bumps. I'l a little worried. I wonder if Perrin engine mounts would stiffen it up enough where it doesn't flex to hit the shaft...
Old 05-22-2014, 12:04 AM   #250
stockysnail
Just the tip
I'm definitely rubbing on the stock drive shaft when hard braking in 2nd but not in 3rd. This doesn't bode well for track days.
gonzo (06-02-2014)
Old 05-22-2014, 12:46 AM   #251
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Are you guys that are rubbing have stock driveline mounts, as in engine, transmission, or differential mounts?
I have Cusco engine, Kartboy trans, and Whiteline diff mounts, and occasionally get knocking on speed bumps with the stock driveshaft. Haven't noticed it on track though.
JDKane527 is offline   Reply With Quote
The Following User Says Thank You to JDKane527 For This Useful Post:
unsurety (05-22-2014)
Old 05-22-2014, 01:20 AM   #252
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Dude that sucks. I just ordered my quickshifter too
Can anyone else confirm this?
unsurety is offline   Reply With Quote
TRD Quickshifter lovebeingbleu98 Brakes, Suspension, Chassis 3 02-13-2014 12:14 AM
Amazing Wax geb2391 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-12-2013 04:42 PM
The most amazing thing I've done with my BRZ so far azngolfur BRZ Photos, Videos, Wallpapers, Gallery Forum 8 01-09-2013 08:23 PM
Concept-Three-LED's DRL's are AMAZING! soros151 Cosmetic Modification (Interior/Exterior/Lighting) 4 11-09-2012 01:42 AM
