Old 05-19-2014, 09:07 PM   #4593
xkwizt
Drives: 86 GT
Originally Posted by Calum View Post
Its a different measuring system for the octane. Your 98 is ~ our 93.
You are right. Wow i didnt know that. Thanks.
xkwizt is offline   Reply With Quote
Old 05-19-2014, 09:08 PM   #4594
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Dustin View Post
For those that have checked the oil level with the use of a syringe, where did you get the syringe from?
[ame="http://www.amazon.com/EcoPlus-740610-Syringe-100CC-ML/dp/B002JLJDQ0/ref=sr_1_2?ie=UTF8&qid=1400548094&sr=8-2&keywords=200cc+syringe"]Syringe 100CC/ML: Amazon.com: Industrial & Scientific[/ame]
with some plastic tubing from the hardware store should do it.
Note, that's a 100cc syringe, the blower holds 147cc (don't quote me on that, but it's somewhere in that area), so obviously you'd need multiple fills.
Old 05-19-2014, 10:05 PM   #4595
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
I meant to post this a while ago after over filling my supercharger because it was so hard to tell when the oil was on the stick. My gf gave me a perfume spray bottle and I cut the stem to the correct length. Them just squirt it out till it stops. Perfect every time.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 05-19-2014, 10:07 PM   #4596
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
That's pretty clever.
Dustin is offline   Reply With Quote
Old 05-19-2014, 10:11 PM   #4597
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Here's another link for a syringe. https://jonbondperformance.com/index...2ukq27ie92hug6
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 05-20-2014, 11:18 PM   #4598
NickFRS
Drives: 2013 Asphalt FRS
One of the bolts that holds onto the elbow of my blower randomly had a head disappear when I was taking photo's for a buyer. Of course the shop who replaced my blower under warranty with Innovate isn't going to accept blame. Even though they are the only ones who have touched those bolts..... How do I extract this damn thing and how much are replacements?
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 05-20-2014, 11:26 PM   #4599
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
Reverse drill bit should work perfectly. First drill a hole with a regular bit, and then use the corresponding reverse bit (usually labelled on box), crank by hand, and it should come out. Can't imagine it being in there that tight.
spitz is offline   Reply With Quote
Old 05-20-2014, 11:53 PM   #4600
NickFRS
Sounds good.... Now just have to find these magical bits and magical bolts. Is this a known issue? Id imagine they went cheap and just re-used all my old bolts when swapping out the blower.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 05-20-2014, 11:55 PM   #4601
TemeCal
Drives: 86
Honestly, it should come out if you just wiggle it out with a pick. I had 3 bolt heads break, and every single one came out by using a pick. They're very loose in there. I'd try that before you tap into it.
...it's a bit disappointing that Innovate isn't accepting any blame. I've seen lots of bolt heads breaking, and everyone says they were properly torqued. Innovate completely falls short in the customer service area...compared to Vortech.
TemeCal is offline   Reply With Quote
Old 05-21-2014, 12:17 AM   #4602
NickFRS
didn't even budge with a pick.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 05-21-2014, 12:20 AM   #4603
TemeCal
Drives: 86
Innovate (Sprintex) Supercharger Owners Topic
Bummer...that's too bad. Sucks that this is a common issue for many of us.
BTW...I'd go down to your hardware store and purchase better bolts. I did this to mine.
Old 05-21-2014, 12:25 AM   #4604
NickFRS
Will due.... I mainly blame the shop who replaced the blower and tightened these damn things to high heaven.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 05-21-2014, 03:30 AM   #4605
sw20kosh
Drives: 2013 Black FR-S
Weird. They never snapped on my car. They must have a time limit like after a certain amount of heat cycles.
I do remember losing a bolt or two down below the blower never to be seen again lol
Old 05-21-2014, 08:16 AM   #4606
Dustin
Twin Screw You
Dustin's Avatar
Try removing the other 5 bolts that hold the intake casting on. It should then slide of that one bolt and you'll be able to get a pair of vice grips on it and unscrew it.
Edit* - you will also have to remove the 3 vacuum lines on the back, probably unclip the TPS sensor and disconnect the intake tube from the throttle body.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
