Old 05-19-2014, 04:51 PM   #1
Aviato
Aviato's Avatar
Drives: 2015 BRZ, 2001 Toyota 4runner-Sold
Five Axis Wheels Stock Height Question
I am looking at buying the FR-S within the year and would like to make sure I get winter tires put on my stock wheels right away. I will also be buying a set of wheels to use in the spring/summer. I was thinking the Five Axis SF:5 18x8.0 40 offset. Or if it would not look to over the top, I like the S7:F 19x8.5 45 offset wheels. I am not looking to alter the ride height or to have to change the camber for wheel rub. Any knowledge/opinions on this topic??
Aviato is offline   Reply With Quote
Old 05-19-2014, 05:04 PM   #2
DAEMANO
Time Traveller
18x8 +40 would fit with no modifications. Just follow standard +1 sizing for your tires.
19x8.5 +45 would also fit, you would follow +2 for your tires.
Keep in mind that to keep the stock circumference, the more wheel you add, the less room for tire sidewall you have left over. Going with narrower profile tires will affect the ride of the tire negatively. Also generally speaking the larger diameter tire you buy, the more expensive they become.
18 inch, 19 inch, five axis wheels, stock height
Stock height + Aftermarket wheels compilation!!!! eddieEndo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 244 03-25-2019 02:32 AM
18x9.5 stock height stock struts etherealfall Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-11-2017 06:44 AM
Question: Will 225/45 or 225/50 winters tires fit the stock wheels?? wbradley Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 12-30-2013 04:13 PM
Height question for mt owners. At people can chime in too bdanisi Scion FR-S / Toyota 86 GT86 General Forum 17 03-08-2013 12:49 AM
quick question about the height.. VenomRush Scion FR-S / Toyota 86 GT86 General Forum 13 12-22-2009 11:42 PM
