Anorexic
Drives: 2003 Honda S2000 Suzuka Blue
Poor Man's Racing STX Build
Hi fellow autocrossers!
I'm a former SCCA Time Trials driver (although I still hold my license) that transistioned full-time into Solo 2 at the beginning of the season. Regional Membership: Washington, DC SCCA Region Local Membership: Autocrossers, Inc., National Capital Chapter BMW CCA, Capital Driving Club Contigency: FT-86 SpeedFactory (Nationals/Regionals), Subaru of America (ProSolo), BFGoodrich (ProSolo) SUSPENSION Coilovers: KW Variant 3 Coilovers Camber Plates: Raceseng Camber/Caster Plates Rear Camber: SPC Lower Control Arms Sway Bars: Hotchkis 25mm Hollow Front Roll Bar End Links: Whiteline Adjustable Front Endlinks and Kartboy Rear Endlinks Upper Strut Bar: OEM Bushings: Whiteline Subframe Bushings ALIGNMENT SETTINGS Ride Height: -- [rake] Rake: -- Camber: -- Toe: -- Caster: Max Shock Settings: 10/6 Weight: 2897 Weight Distribution: 50.02% Corner Weights: 793 (LF), 759 (RF), 635 (LR), 600 (RR) ENGINE & DRIVETRAIN Header: Borla Over Pipe: Private Label MFG Front Pipe: Private Label MFG Cat-Back: Invidia N1 Intake: SuperTek Intake Tubing and K&N Drop-in Air Filter with sound generator delete and snorkel modification ECU: EcuTek, tuned by Visconti Tuning, 8200RPM Redline Battery: Shorai LFX21LS-BS12 Engine Pulleys: OEM Motor Mounts: Cusco LSD: OEM Bushings: Whiteline Transmission Bushing, Kartboy Rear Shifter Bushing Short Shifter: Kartboy Clutch Line: MTEC Industries Stainless Steel Clutch Line Engine Oil: OEM Clutch Oil: Prestone DOT 4 Brake Fluid Transmission Oil: Motul 1L Transmission GEAR 300 75W90 Differential Oil: Motul 1L Transmission GEAR 300LS 75W90 WHEELS & TIRES Wheels: Enkei Racing RPF1 17x9, +35 Tires: Hankook RS3 - Version 1 245/40R17 Brakes: Ferodo DS2500 (Front), HAWK Performance HPS (Rear) Brake Fluid: ATE Super Blue Racing Fluid Brake Lines: MTEC Industies Stainless Steel Tire Pressures: 33 (F), 31 (R) [Cold]36 (F), 34 (R) [Hot] INTERIOR Seats: Sparco Evo 3 Harnesses: Sparco 4 pt. Harness Bar: Agency Power DYNO RESULTS 184.57 WHP (Dynojet)144.44 FT LBS (Dynojet) 205.1 WHP (Dyno Dynamics)160.6 FT LBS (Dyno Dynamics) ![]() ![]() ![]()
2003 Honda S2000, SCCA Club Racing T3
2013 Subaru BRZ Limited, SCCA Solo II STX 2008 Honda S2000 CR, SCCA Solo II STR ![]() Last edited by PoorMansRacing; 07-10-2014 at 11:30 AM. |
| The Following User Says Thank You to PoorMansRacing For This Useful Post: | FRSTRM (05-27-2014) |
#2 |
| The Following 2 Users Say Thank You to s2d4 For This Useful Post: | Lonewolf (06-23-2014), PoorMansRacing (05-19-2014) |
#3 |
Well, youre the first Ive heard of shaving the rivals.
#4 |
Drives: '13 BRZ Ltd
Saw this car this past Sat, really like the color combo of the silver/gunmetal. That 8200 redline I'm sure was nice to have on Sat's course!
| The Following User Says Thank You to Wepeel For This Useful Post: | PoorMansRacing (05-19-2014) |
#6 | |
Anorexic
Definitely expected that! lol!
![]() The Dyno Dynamics dyno reads 11% higher than the Dynojet. I originally had Open Flash Tablet prior to EcuTek. I definitely recommend OFT as a cost effective tuning software.
2013 Subaru BRZ Limited, SCCA Solo II STX 2008 Honda S2000 CR, SCCA Solo II STR ![]() |
#7 | |
Drives: '13 BRZ Ltd
I need to get a header and availability/price is pushing me toward the Borla. HKS seems to make the most power but is $$$ and would also require a custom tune (even more $$$). I would get the OFH if there wasn't such a lead time on it. |
#8 |
Anorexic
@Wepeel I did. Powerwise, there wasn't a huge difference, but the custom tune definitely smoothed out my A/F ratio and completely removed my torque dip and idle issues. I'm running about 4% less aggressive tune with the same power output. Launch control was dropped from 5600 RPMs to 4000RPMs (at my request). Max RPMs went from 7500 to 8200.
I can't comment on the flat-foot shifting or revmatching features. Haven't tried them out. I went with the Borla, because it's the lightest on the market. Here are my dyno sheets:
| The Following User Says Thank You to PoorMansRacing For This Useful Post: | Wepeel (05-19-2014) |
#9 |
Drives: '13 BRZ Ltd
^Great info, thanks, that really helps. I will def need to come over and say hi next event - I was running the white BRZ #23. Love the huge STX field down in DC. Not sure yet if I will make it down yet on the 8th.
#10 |
Anorexic
Definitely let me know when you're coming back down to the DC area, so we can properly meet
@Wepeel
#11 |
Anorexic
WDCR-SCCA First Ever Night Autocross, 6/1/2014
Ran the new Hankook RS3 (v1) over the weekend. My first impressions were they take the same amount of time, if not more, to warm up as the Rivals, but they are definitely a lot grippier than the Rivals. So far, I am very pleased with the new set of tires and decided to run them for the rest of the season. ![]() ![]() ![]() ![]()
#12 | |
Drives: '13 BRZ Ltd
| 2014 Scion Racing Road Race Build | MicheleAbbate | Member's Car Journals | 148 | 04-22-2016 08:13 AM |
| Blackworks Racing Turbo Build | BRZ_Driver | Forced Induction | 23 | 03-26-2014 11:59 PM |
| Your Poor man LFA s here!!! | Whitigir | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 12-10-2013 11:47 AM |
| BRZ's very poor reception | theredtape | Electronics | Audio | NAV | Infotainment | 3 | 10-05-2013 12:23 PM |
| Poor fellow... | gzpermadi | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 04-24-2013 04:35 PM |
