Old 05-18-2014, 01:36 PM   #43
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
Originally Posted by Mikepage View Post
Doesn't prove anything. It's about motorcycle torques. I need mathematics and formulas. Bro, I am Asian.
blackhawkdown is offline   Reply With Quote
Old 05-18-2014, 10:21 PM   #44
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Send me a pm with your email and i will send you a PDF
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 05-19-2014, 04:00 AM   #45
peebking
Drives: BRZ limited
I got those rear subframe bushing, LSD bushing, Steering bushing and tranny bushing installed, and the car feel more solid toward the ground and more respond toward the steering
peebking is offline   Reply With Quote
The Following 2 Users Say Thank You to peebking For This Useful Post:
Grateful Dave (06-07-2014), Mikepage (05-19-2014)
Old 05-19-2014, 09:32 AM   #46
Mikepage
Mikepage's Avatar
I have the same setup, I have also the steering bushings, just not mentioned in my first post...
o= FR-S =o
Old 05-19-2014, 10:08 AM   #47
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
I ordered the KDT925. The problem is I already installed a diff brace. Would anyone know if I could use the bushings with the brace? If not, I'll just use the outrigger bushings.
Tye300 is offline   Reply With Quote
Old 05-19-2014, 10:12 AM   #48
sshole
Please clarify as I have torqued many bolts with anti-seize to recommend torques on aircraft before. Where does it say you cannot torque bolts like that? I am curious.
When you install those fasteners on aircraft, are you given specific instructions to use anti-seize with the specified torque or are you using anti-seize just because you have it available to you?
I work on submarines and we need to specify exactly when and where the anti-seize goes. If we use anti-seize, we also need to specify a dry (no lube) and wet (lubed with anti-seize) torque. The dry torque is always higher than the wet torque.
sshole is offline   Reply With Quote
The Following 2 Users Say Thank You to sshole For This Useful Post:
gramicci101 (05-19-2014), Mikepage (05-19-2014)
Old 05-19-2014, 04:24 PM   #49
Mikepage
Mikepage's Avatar
Whiteline differential insert bushings review
Check my pictures... I don't think...
Why do you want bushings if you have brace already?
Do you have sound like we describe before with the brace? Am curious...
o= FR-S =o
The Following User Says Thank You to Mikepage For This Useful Post:
Old 05-19-2014, 04:33 PM   #50
gramicci101
Off Topic
Exactly my experience with F-16s. You don't use antiseize unless the tech data tells you to. If it does tell you to use it, the stated torque value takes the antiseize into account.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 05-19-2014, 09:29 PM   #51
Tye300
Tye300's Avatar
I don't have the sound you guys are having. I'll try installing the outrigger bushings with the brace.
The Following User Says Thank You to Tye300 For This Useful Post:
Mikepage (05-20-2014)
Old 05-20-2014, 12:14 PM   #52
Mikepage
Mikepage's Avatar
Mmm no sound? Interesting... Do you have others bushings?
o= FR-S =o
Old 05-20-2014, 12:40 PM   #53
Tye300
Tye300's Avatar
I have the subframe inserts and the brace. I also have an aluminum driveshaft. With all the noise I get from the exhaust and the other bushings, I may be missing the sound you are saying. Haha! I'll report back after I install the outrigger bushings.
Old 05-29-2014, 10:37 PM   #54
Mikepage
Mikepage's Avatar
The sound is more perceptible windows closed, radio at off and when you shift from the first to the second gears.... After release the clutch not hardly but not too firmly.... It's also possible to avoid the sound if you slowly drop the clutch....
The sound come from the clutch mechanism on the trany like mentioned before and probably just normal but mor perceptible with all bushings installed....
o= FR-S =o
Old 06-07-2014, 10:09 AM   #55
Tye300
Tye300's Avatar
Finally installed the bushings. I was not able to install the rear ones because I have the diff brace already. The outrigger inserts definitely stiffened up the diff as I can hear the noise the other guys are talking about.
Mikepage (06-09-2014)
Old 06-07-2014, 12:11 PM   #56
ramiram1984
Drives: 2016 STi DGM
Originally Posted by mike the snake View Post
Our cars really need stiffer engine mounts too. Stiffening all the points (engine mounts, trans mounts, shifter, rear subframe, rear diff) will I'm sure make the car feel proper.
It does
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
DIY - Whiteline Rear Crossmember Mount Insert Bushings F1point4 DIY (Do-It-Yourself) Guides 91 01-17-2021 02:23 AM
Whiteline crossmember bushing insert review Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 11-09-2016 03:30 PM
Rear Shifter/Transmission Mount Insert Bushings TheseColorsDontRun Mid-Atlantic 7 08-30-2013 10:29 AM
Whiteline diff bushings and trans mount insert. Simmons Transmission and Driveline 7 06-09-2013 08:45 PM
WhiteLine Positive Shift and Rear Subframe Bushings Review @ Pure Automotive Pure Automotive Mid-Atlantic 5 01-16-2013 05:15 PM
