Old 05-07-2014, 10:51 AM   #15
Fr-s.h
Drives: Golden White
ill let you know in a couple of weeks how everything went im going all out and doing
sub frame inserts
outrigger for the diff
motor mounts
`13 Whiteout Fr-s.h
Fr-s.h is offline   Reply With Quote
Old 05-07-2014, 10:52 AM   #16
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Perfect, good luck Thanks!
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 05-07-2014, 11:33 AM   #17
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
I've had these on my car along with the subframe and trans bushing for a few months. At about 75-77mph, you can really hear the diff howling. I haven't decided if I am going to keep them or not because it was such a great upgrade. But with a 60 mile commute starting next week, I don't know if I can handle it.
The Racers Line is offline   Reply With Quote
Old 05-07-2014, 12:02 PM   #18
Mikepage
Mikepage's Avatar
For me, the sound start at 68mph or 110km/h
o= FR-S =o
Old 05-07-2014, 09:35 PM   #19
Zaneman
Drives: 2013 BRZ limited
My only complaint from these bushings is the horrible clunk they make for every shift into 1st and 2nd. It sounds like something is breaking back there. I made sure to torque everything back to spec but it just doesn't sound normal. I never had these issues with just the transmission and rear subframe inserts so I know it has something to do with these.
Zaneman is offline   Reply With Quote
Old 05-07-2014, 10:17 PM   #20
Mikepage
Mikepage's Avatar
Whiteline differential insert bushings review
Same situation for me, with the trany and the subframe inserts, everything was fine. Its supposed to be normal Whiteline said.
The revers, for you, have the clunk also? I think it's on very gears but more on the 1st and 2nd...
Am curious to know if the cusco will make the trany sound like this... Anyone run the cusco diff brace here?
o= FR-S =o
Old 05-07-2014, 10:34 PM   #21
mike the snake
Our cars really need stiffer engine mounts too. Stiffening all the points (engine mounts, trans mounts, shifter, rear subframe, rear diff) will I'm sure make the car feel proper.
Old 05-07-2014, 11:35 PM   #22
Mikepage
Mikepage's Avatar
I don't want to have more NVH then now.
Then I don't think I will upgrade the engine mounts.
But you want to mean, with the engine mount, we will probably not hear the clunk sound during shifting anymore?
o= FR-S =o
Old 05-07-2014, 11:58 PM   #23
Mikepage
Mikepage's Avatar
I just found this good review : http://www.ft86club.com/forums/showthread.php?t=30313
o= FR-S =o
Old 05-08-2014, 01:41 PM   #24
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
I thought there was a DIY on this somewhere? Can't seem to locate it anymore
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 05-08-2014, 06:41 PM   #25
Mikepage
Mikepage's Avatar
I don't think we have a DIY in the forum but with the instruction you will receive with the bushings, it's pretty easy...
You can also download it on the Whiteline website.
Right here : http://www.whiteline.com.au/product_..._number=KDT925
o= FR-S =o
Old 05-08-2014, 07:05 PM   #26
Mikepage
Mikepage's Avatar
After discussing with the Whiteline tech about the gear noise, I can now clarify the concern and shared their response almost word of word, I only added some comments.
We can drive it hard but do not drop the clutch. Like you probably already know, this is not good stock anyway.
Things will be louder it's just typical rear wheel drive mechanics. This noise is expected, the gearbox in these vehicles are not small, but do not be concerned.
All will be fine unless you're at the race track everyday.
Again, racing the car completely stock everyday will probably break something too...
If the car is driven respectively, don't worry.
Then enjoy your mod!!!
o= FR-S =o
Old 05-10-2014, 05:58 PM   #27
Mikepage
Mikepage's Avatar
After investigate to find the real source of the sound after releasing the clutch, am pretty sure it's produced by the clutch mechanism itself...then nothing to worry about.
o= FR-S =o
Old 05-11-2014, 02:25 AM   #28
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Has anyone thought of packing the diff bushings with Windo Weld? I've used it on several projects in the past with amazing results, personally.
Wonder if that would help stiffen it up without the NVH issues.
Coheed is offline   Reply With Quote
DIY - Whiteline Rear Crossmember Mount Insert Bushings F1point4 DIY (Do-It-Yourself) Guides 91 01-17-2021 02:23 AM
Whiteline crossmember bushing insert review Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 11-09-2016 03:30 PM
Rear Shifter/Transmission Mount Insert Bushings TheseColorsDontRun Mid-Atlantic 7 08-30-2013 10:29 AM
Whiteline diff bushings and trans mount insert. Simmons Transmission and Driveline 7 06-09-2013 08:45 PM
WhiteLine Positive Shift and Rear Subframe Bushings Review @ Pure Automotive Pure Automotive Mid-Atlantic 5 01-16-2013 05:15 PM
