Old 05-18-2014, 09:08 PM   #1373
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Originally Posted by DJCarbine View Post
I rounded off my vent plug by accident because I used a metric hex
If I ever round off the dipstick/plug I'm cutting a slot in it for a flat blade screwdriver
how do you suggest we do that? i want to do this; right now i want to hammer a bigger hex key into it so i can just remove it.
F1point4 is offline   Reply With Quote
Old 05-18-2014, 10:06 PM   #1374
DJCarbine
Thupercharged
DJCarbine's Avatar
Got any Torx bits? I've had reasonable luck using those to get out rounded off allen bolts
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following 2 Users Say Thank You to DJCarbine For This Useful Post:
Basket Case (07-02-2014), F1point4 (05-19-2014)
Old 05-18-2014, 10:21 PM   #1375
ft86me
ft86me's Avatar
Drives: 2013 FRS
I did this at my shop to get them out. I hammered in a thin Flathead screw driver in there to create a groove of the Flathead. Once that is done, take a box wrench that will fit on the base of it (where the grip is) and push down on the driver as hard as possible while slowly pulling/turning the box wrench. I think my snapon drivers were a 10mm at the base. I forgot though, but hopefully you know what I mean. I also used some WD40 in hope of it slightly entering the threads.
see at the base where the grip is? you can slide a box wrench on there. I believe a 10mm.
1.slide on box wrench first to the shaft of the flathead (that's probably what she said yes i know ha ha ya ya.)
2. push down on the driver as hard as possible with all your weight while turning the box wrench in attempt to loosen the dipstick.
hope this helps!!
oh and careful going too deep. last thing you want is the shards getting into the blower. eeeeeek
ft86me is offline   Reply With Quote
The Following User Says Thank You to ft86me For This Useful Post:
Old 05-18-2014, 11:03 PM   #1376
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
I striped the dipstick and ended up hammering a 5mm into it and have never had any problems ever since. The brass is soft is it was pretty easy.
marcoaferrer is offline   Reply With Quote
The Following User Says Thank You to marcoaferrer For This Useful Post:
Old 05-21-2014, 04:08 PM   #1377
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
Does anyone know if there's an off the shelf replacement for the check valve. I need a new one (lost in transit from the original owner)... I know the Vortech part number is 7P375-378, it's $26 bucks, wondering if there's a suitable replacement I can source at a local autoparts store. thanks... If not, all good..
sissupr is offline   Reply With Quote
Old 05-22-2014, 04:23 PM   #1378
Dezoris
Dezoris's Avatar
Anyone have an issue starting a new owners thread instead of this old ass post that is way to long? It would be nice to organize a whole bunch of topics, owners, tips/tricks and problems without having to look through all this.
The Following 4 Users Say Thank You to Dezoris For This Useful Post:
diirk (05-25-2014), MyRx (05-22-2014), speedy (05-23-2014), Tye300 (05-23-2014)
Old 05-22-2014, 04:23 PM   #1379
marcoaferrer
^^^^ I second this shit
Old 05-22-2014, 06:07 PM   #1380
DJCarbine
Thupercharged
DJCarbine's Avatar
I was thinking this as well
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
Dezoris (05-23-2014)
Old 05-22-2014, 06:26 PM   #1381
marcoaferrer
i started one so lets see what happens. if you find something you think should def be included let me know
Old 05-22-2014, 08:35 PM   #1382
marcoaferrer
here she is
Vortech Supercharging - FAQ and Notes
http://www.ft86club.com/forums/showthread.php?t=66430
diirk (05-25-2014)
Old 05-23-2014, 12:17 AM   #1383
Dezoris
Dezoris's Avatar
Thanks I will post up some things in this thread instead to add, as to not clog up the new one, recommend others do the same thing.
Can all Vortech owners post up your dynos in here on what tuner you had and what basic mods?
Old 05-23-2014, 12:35 AM   #1384
Dezoris
Dezoris's Avatar
Perrin Vortech DynoJet Testing
DynoJet 4th Gear Pulls
Parts Installed:
  • Standard Vortech Tuner Kit
  • Perrin Vortech Tune v10
  • Perrin Resonated Header Back with Catted Midpipe
  • Koyo Radiator
  • Perrin Oil Cooler
  • Redline 0W20
  • Radium Dual Catch Cans
Old 05-25-2014, 11:12 AM   #1385
diirk
diirk's Avatar
Drives: 4Runner
Originally Posted by diirk View Post
Are there pics or a diagram I can use to plan this out?
Are there preferred units? I was looking at the Cusco. But I'd like something fairly compact. Is there maybe a 2 in 1 unit on the market?
thanks again.
So I picked up a FBM Catch Can for the car.
I notice that some mfg's want you to remove the PCV valve and others don't. FBM wants you too according to the instructions. Any tips on how to remove it?
Thanks
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 05-25-2014, 11:15 AM   #1386
nelsmar
Thanks
Take a socket place it over the valve and unscrew it.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
diirk (05-25-2014)
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
