Old 05-17-2014, 11:49 PM   #1
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Finally got my OFT mounted
Ive been contemplating ways to mount my Tablet FOREVER, and finally had a weird dream about how to mount it last night
I use a Rockform case for my iPhone 5s. It has a badass mounting system on the back and even a magnet. It is an impressive case. I few months ago, I accidentally dropped it in a large spill pan full of 5w-30. I pulled it out quick enough and the phone was fine, but the felt backing on the inside of the case turned into mush.
So I bought another case and have had this other one lying around. This pictures show the rest. I cut the case with an air cutting wheel(not the best choice as it melts the plastic) and then use some 3M Double sided tape to adhere it to the back of the OFT. I then ran the cable under the steering column and into the ob2 port.
It doesn't interfere with the turn signal and I use the same mounting spot with my phone turned sideways for gps and its perfectly visible in the drivers seat.
Heres a link for the case: http://www.rokform.com/iphone5-cases/
I realize $40 is a little steep for a mounting solution, but if you sign up for their email list, I regularly get 20% off coupons and occasionally 40%
The Racers Line is offline   Reply With Quote
The Following 13 Users Say Thank You to The Racers Line For This Useful Post:
Anorexic 86 (05-21-2014), FrsDuke (05-19-2014), Garrett@Openflash (05-21-2014), jbravo373 (05-19-2014), JonAvalon (05-18-2014), keen as (05-18-2014), neutron256 (05-18-2014), Pistol (05-18-2014), PMok (05-18-2014), Robert@Openflash (05-20-2014), Shiv@Openflash (05-18-2014), troek (05-18-2014), Tromatic (05-18-2014)
Old 05-17-2014, 11:54 PM   #2
Trac Toy
Trac Toy's Avatar
Now that, actually looks like a nice install! How easily does that clip in and out? Just a slight twist?
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 05-18-2014, 12:00 AM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
That's really nice! I gotta try that myself. How sturdy is it? Does it vibrate/shake when you drive?
Shiv@Openflash is offline   Reply With Quote
Old 05-18-2014, 12:09 AM   #4
The Racers Line
Just a simple twist, but it is very sturdy.
Old 05-18-2014, 12:12 AM   #5
The Racers Line
Hopefully you can try mine out soon , I work for EQ tuning
No vibration or anything though, it looks solidly mounted but can be easily removed.
Old 05-18-2014, 01:02 AM   #6
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
looks good.
Old 05-18-2014, 10:54 PM   #7
PMok
Codename: Stitch
PMok's Avatar
great job, looks good!
The Following User Says Thank You to PMok For This Useful Post:
The Racers Line (05-19-2014)
Old 05-18-2014, 11:14 PM   #8
Tromatic
The cut-and-paste method looks like it will for for a GTab as well!
Old 05-19-2014, 12:54 AM   #9
The Racers Line
Yeah you could technically adapt the mount for use with a bunch of different things.
Old 05-20-2014, 07:12 AM   #10
Anorexic 86
Trim the Fat & add Boost
Anorexic 86's Avatar
Drives: sometimes I fly
Clever,
lol... that poor weathertech badge.
Anorexic 86 is offline   Reply With Quote
Old 05-20-2014, 12:15 PM   #11
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Great idea and good location. Any particular reason why u cut a case? instead using the universal mount $24.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
The Following 3 Users Say Thank You to TIE Pilot For This Useful Post:
Anorexic 86 (05-21-2014), finch1750 (05-22-2014), The Racers Line (05-20-2014)
Old 05-20-2014, 02:10 PM   #12
The Racers Line
Wow didn't realize they sold that! Even better. I cut up an old case that was oily from an accident
Old 05-20-2014, 02:16 PM   #13
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
@WiebTech Performance Pls Check PM Got some parts piling up..
CO>CA Cartel
Norkoastal is offline   Reply With Quote
The Following User Says Thank You to Norkoastal For This Useful Post:
Old 05-23-2014, 01:42 PM   #14
Norkoastal
Norkoastal's Avatar
For those not wanting to permanently glue anything to the back of the OFT, there is suction cup tape! I tested this morning and the OFT didn't budge an inch. This stuff is strong enough to stick to the dash piece and stay there.. Info below.. I'd probably recommend pulling it off and placing in the glovebox while parked in sunny spots as the OFT will bake.
"A 4 in x 1 in piece of the tape is strong enough to hold a 1 lb flat piece of steel to most non-porous, smooth, dry substrates."
https://www.inventables.com/technolo...ction-cup-tape
CO>CA Cartel
Anyone with pics of Enkei SR6 mounted? ericmpena Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-07-2017 12:22 PM
fS SoCal swift springs already mounted SliverBrz Brakes, Suspension, Chassis 4 10-14-2013 07:20 AM
Something new for us, mounted up a set of 19" wheels on the FRS - NOT BAD! WheelDude.com FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 44 10-01-2013 11:42 AM
where can i get my front spoiler mounted? VoiD Mid-Atlantic 1 09-19-2013 12:08 AM
Stock Tires mounted? feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-19-2012 05:02 PM
