Old 05-17-2014, 08:22 AM   #1
Brahsbrah
Drives: 2013 BRZ Sport Tech White Pearl
Transmission is damn hot...
I was doing some quite spirited driving yesterday, and kept thinking my heat was on, which I was checking and it was on the coldest setting (without AC). After a while a notuiced the shifter was actually getting pretty warm, and then I put my hand down by the transmission and the floor and everything was QUITE toasty.
I know this car is pretty low to the ground and the transmission is basically sitting beside you, but this is the first time I noticed this. I was driving around town with a lot of 0-60 pulls going on. Has anyone else noticed this? I'd assume it's normal and I just never noticed it.
Outside temp was about 18*c.
Brahsbrah is offline   Reply With Quote
Old 05-17-2014, 08:24 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
its normal, wait for summer
Old 05-17-2014, 08:57 AM   #3
Maritime Storm
Maritime Storm's Avatar
Drives: 2013 Scion FR-S 6spd, Whiteout
A quick run down the 102 should cool her off. It's a nice day for a run to Truro anyway.
Maritime Storm is offline   Reply With Quote
Old 05-17-2014, 10:15 AM   #4
Brahsbrah
I live down the 103, that cooled er off pretty good! Suprised at the presence of Atlantic Canadians on here!
I've been considering changing my fluid to something a bit more "performance" and recently have really contemplated not driving my car next winter so some Redline or Gear 300 might be in order. I know that won't help with the temps...
Old 05-17-2014, 10:39 AM   #5
wparsons
wparsons's Avatar
Don't forget that the exhaust runs under there too, so that'll heat up a bunch when you're pushing it harder.
flickr
Old 05-17-2014, 11:21 AM   #6
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Seeings how FI kits like Ptuning run a turbo literally right beside tranny it has to be no concern really.
Old 05-17-2014, 11:38 AM   #7
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
The transmission is no where near your hands. Its next to your feet. Remember the outputshaft is near the shifter and the transmission is foreward of that. Underish the radio.The heat was probably your exhaust. Rhd?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 05-17-2014, 02:34 PM   #8
Brahsbrah
Left hand drive. And good point, I forgot you can see most of the tranny under the hood. I could literaly feel the heat coming off of the...shaft that shifter is connected too. Like under the shift boot was pretty warm.
It doesn't look like this should be much of a concern! I'd say some of the heat was being generated from the exhaust as well...
Old 05-17-2014, 02:43 PM   #9
OICU812
Just a dude
OICU812's Avatar
On that note once have car on jackstands again take a boo. If you pop off drive shaft lots of room to work there, you could easily install some thermal barrier if you wanted to, easy to clean that area prior to installation and also would be easy to apply. I plan this next winter on spraying on some MLV Zero noise and thermal barrier in that tunnel area myself.
Old 05-18-2014, 06:28 AM   #10
Maritime Storm
Not sure if changing the transmission fluid would help any. I may change mine before the snow, mine was bought with the intention of driving year round.
DAMN I'M HOOKED Touge Monster Tracking / Autocross / HPDE / Drifting 0 12-26-2012 03:46 PM
GGGRRRR Damn it!!! NMMI89 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 11-11-2012 09:38 AM
Damn you Blizzard! denkigrve Off-Topic Lounge [WARNING: NO POLITICS] 8 05-31-2012 03:17 PM
Damn Raccoons! WRXGuy1 Off-Topic Lounge [WARNING: NO POLITICS] 13 05-27-2012 09:54 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
