Old 05-15-2014, 01:02 PM   #43
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by J_kennington View Post
If you are say, traveling 70mph in 6th(manual mode on at). Say you want to downshift to the lowest gear possible(from my own experience at 70 it's about 4th gear). So you start flapping the paddles and then OH NO I hit it 3 times instead of 2". The car will audibly beep at you and stay in 4th. To say "hey bozo, if I go to 3rd your gonna blow me up so I'm staying in 4th whether you like it or not".
FYI 3rd gear at 70 mph is about ~6200 rpm from experience, perfect for the powerband on an MT. Since AT has longer ratios you'd be even lower in the rpm range.
But you're spot on in the operation of the car in that it won't shift into a gear that harms itself.
http://www.ft86club.com/forums/showp...55&postcount=5
ineedyourdiddly
Old 05-15-2014, 01:35 PM   #44
J_kennington
Drives: 2013 asphalt scion FRS
Ah, I just knew 70 was close to top of 3rd so I said 4th.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 05-16-2014, 03:39 AM   #45
kavanagh
Fat on Corn Syrup
For what it's worth as an AT driver:
I'm either in plain old auto transmission and full TC left enabled, or I'm in manual transmission with TC disabled by the three second button hold. Sport mode in the AT tranny is cool, but manual mode is more fun to me - autoblip downshifts rule.
The Following User Says Thank You to kavanagh For This Useful Post:
Demandred7 (05-17-2014)
Old 05-16-2014, 05:19 AM   #46
Fortis
Fortis's Avatar
Drives: 2014 FR-S AT Asphalt
Wow, 3rd gear in the Auto's must be much taller than the MT. In 3rd gear, I can hit 85 mph @ 6500 rpm's in manual mode. At redline in 3rd, I'm right at 90.
Fortis is offline   Reply With Quote
Old 05-16-2014, 12:29 PM   #47
strat61caster
http://www.ft86club.com/forums/showthread.php?t=5404
All the gears are taller in the Auto, the increased fuel economy isn't because of the slushbox, it's because of the ratios allowing for lower rpm at cruising speeds.
ineedyourdiddly
Old 05-16-2014, 12:50 PM   #48
hamzam
Proud dad of 2 boys :)
hamzam's Avatar
Drives: Firestorm 6-MT
[ame="https://www.youtube.com/watch?v=i98TdQTKVe4"]Travis Demonstrates the Scion FR-S Traction Control System - YouTube[/ame]
hamzam is offline   Reply With Quote
Old 05-16-2014, 08:12 PM   #49
wooly35
Drives: 2014 Scion FR-S LS3
This is a great find. ive always had it on VSC mode. Cant wait to try this with no traction control.
wooly35 is offline   Reply With Quote
Old 05-16-2014, 08:40 PM   #50
wooly35
also, does holding down the traction control for 5 seconds enable the same as doing the pedal dance? Same two yellow lights come on. just curious.
Old 05-16-2014, 10:00 PM   #51
stevesnj
stevesnj's Avatar
Nope, auto LSD is still engaged and the TRAC and VSC will not turn back on automatically. Auto LSD is still on to a minor amount. Pedal dance (Inspection mode) will disable Auto LSD totally and retain ABS under braking.
Old 05-17-2014, 12:11 AM   #52
Hot Lava
The Antiriced
Hot Lava's Avatar
Drives: women wild
Now wait a second here. The way I understand it when you hold the trac button down until the 2 lights come on then everything is turned off. Both stability control and abs right? What you're saying is this Auto LSD is still on in the mode I described? Sure seems like everything is off. From my experience I don't notice any vehicle control besides the driver when getting crossed up in the wet. Manual trans for reference.
Hot Lava is offline   Reply With Quote
Old 05-17-2014, 06:40 AM   #53
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by CatDaddysBBQ View Post
I find that it kicks in way too soon to be very useful in the dry. In the wet, I have had situations that it'll interrupt oversteer so violently that it'll cause a bit of a "tank slapper" in the opposite direction.
This situation you described in wet conditions, do you feel you don't experience that in the dry? I have before while using VSC sport and chalked it up to me being twitchy through a corner. Now I'm starting to think otherwise.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 05-17-2014, 07:47 AM   #54
Mikem53
Drives: FR-S 6MT
The pedal dance will also turn off the EBD
Mikem53 is offline   Reply With Quote
Old 05-17-2014, 08:58 AM   #55
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Sport mode in VSC, as others have stated, just raises the threshold before VSC intervenes and attempts to straighten the car. It allows for more wheelspin and a higher angle/degree of oversteer before it intervenes.
Every car I've owned with a stability control system has had some sort of "sport" mode, but I've found that the "sport mode" causes an abrupt change in the vehicle balance when it engages (i.e. "tank slapper"). The only reason I can think of is that the driver already counter-steers for the slide and when the system engages (often via braking and throttle input) it doesn't account for the steering angle, thus ending the slide and essentially trying to change direction because of the driver's input. This system isn't as violent as other vehicles I've owned, but it also doesn't have the same ability to spin tires at will either.
I will say, that Chevrolet's PTM (Performance Traction Modes) on the ZR1, ZL1 and Z/28 are supposedly (and track proven, with a well known race driver) to be faster around a track with the proper setting (wet, dry, etc) versus a driver (ie, well known race driver, Randy Pobst) with PTM disabled. Of course F1 and MotoGP have used forms of traction control and stability control in the past (currently TCS is used in MotoGP), so it does have a "race bred" heritage.
A common misconception people have is that VSC/TCS is there to "make you a faster driver". This is true when it's utilized that way by the manufacter (i.e. Chevy's PTM). In reality... and in probably 95% of production vehicles sold in the US, VSC/TCS is only on the vehicle because it's mandated by the NHTSA that ALL vehicles under 10,000lbs GVWR have VSC by MY2012. Link Rather than develop a "race level" VSC system, most manufacters just use a basic system that intervenes to help prevent/reduce skids. Regardless of the level or ability of the VSC, nothing can change physics, so the system cannot fix your mistake all of the time.
Personally, since I grew up in the days before "nannies", I drive with VSC/TCS off (5sec button hold) 99% of the time. The only instance when I'll leave it on is when caught in a torrential downpour, and occasionally in snow/ice (where VSC sport mode is actually quite handy). There is no replacement for driver experience, nor is there a solution for stupidity.
Kwaziekeller is offline   Reply With Quote
The Following 3 Users Say Thank You to Kwaziekeller For This Useful Post:
acro (05-22-2014), Jyn (05-22-2014), kavanagh (05-20-2014)
Old 05-17-2014, 07:23 PM   #56
wooly35
guess i need more practice doing the pedal dance. lol
AT Sport Mode - What does it do exactly? karbon BRZ First-Gen (2012+) — General Topics 49 09-02-2014 02:40 AM
DIY Auto VSC Sport and AT Sport Mode Seattle944t DIY (Do-It-Yourself) Guides 0 09-08-2013 05:02 PM
Cruise control with Sport or VSC Sport mode notout86 Scion FR-S / Toyota 86 GT86 General Forum 12 08-29-2013 06:50 PM
normal mode/vsc sport/trc off Toyota GT 86 Scion FR-S / Toyota 86 GT86 General Forum 48 04-09-2013 01:47 PM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 11:50 AM
