Old 05-16-2014, 09:12 AM   #15
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Here's the package I generally recommend to those using their car in the manner that you are:
Skip the OEM sized replacement discs. That won't give you an appreciable performance increase, and there's no sense tossing your OEM discs if they are severely cracked or run past their minimum thickness.
My recommended setup will give you:
  1. Increased heat capacity in the pads to prevent pad fade (firm pedal but car doesn't slow down).
  2. Increased heat capacity in the fluid to prevent fluid fade (mushy pedal due to air bubbles from fluid boiling).
  3. Improved pedal feel and modulation (pads and SS lines)
  4. Quicker response time (SS lines)
  5. The DS2500 are easy on discs, last a solid length of time, and only make a very small amount of noise in most cases (typically they'll only give a squeak just as you roll up to a complete stop). They can be autoX'd, or even driven on some tracks, and they aren't terribly expensive given their performance.
I lived in LA for 5 years, so I know all about canyons. Topanga, Latigo, Mulholland..mmmmmm...dang I miss those.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
The Following User Says Thank You to JRitt For This Useful Post:
Pseud0logik (05-17-2014)
Old 05-16-2014, 10:24 AM   #16
wparsons
wparsons's Avatar
DS2500's are virtually silent unless you overheat them. I'm on my second summer with them and they barely ever made noise. They've been a tiny bit noisier since the last track day, but seem to be getting quieter after a couple weeks of street driving.
flickr
Old 05-16-2014, 10:31 AM   #17
Maximal
Maximal's Avatar
Drives: Dodge Stealth
I'm a huge fan of Carbotechs. The AX6's are perfect for what you're looking for. They're a bit dusty but they don't have the noise you get one some performance pads.
http://store.maximalperformance.com/.../i-241239.aspx
Maximal is offline   Reply With Quote
Old 05-16-2014, 10:51 AM   #18
dp1
driving smoother faster
Drives: Sold
Same here, I have Sprint AP BBK and use Carbotech bobcats (1521) for year round street (north east) and XP12 for track. No need to clean rotors when swapping pads and both are pretty gentle on rotors.
dp1 is offline   Reply With Quote
Old 05-16-2014, 12:49 PM   #19
Maximal
Maximal's Avatar
On my car (granted it's a Stealth) I run AX6's for the street and XP8's at the track and they work great as you don't have the annoying noise on the street and don't need to swap pads.
I can see the 1521s working well for some spirited street driving and then you don't have as much dust as you get with the AX6s.
Carbotechs are a bit pricey but in my mind they're worth it. I actually ran them before I started carrying them and liked them so much I signed on to carry them. :p
Brake upgrade if you're looking at 350hp DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 11-19-2013 01:26 AM
Dan Gardner DG spec brake upgrade JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-06-2013 08:32 PM
$98 Brake Fluid Upgrade Texas BRZ Tracking / Autocross / HPDE / Drifting 15 10-22-2012 02:50 AM
TRD Brake Upgrade Opie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-21-2012 04:10 PM
