Old 05-15-2014, 07:20 PM   #99
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by gramicci101 View Post
Your desk needs to be cleaned.
I'm using all that stuff. Right now. Even the oil sample container and the box of .410 shells. I swear.
The Following User Says Thank You to extrashaky For This Useful Post:
bakerr6 (05-16-2014)
Old 05-15-2014, 07:33 PM   #100
Bigmaxy
Drives: Pegasus GTS86
The thing is that most people on these forums probably don't own a completely stock vehicle. So any stats being gathered here would be skewed.
You would have no way of knowing if the 98% of owners who never visit a forum dedicated to this car have a failure or are completely happy.
Only someone in Subaru/Toyota head office truly knows the full story.
I must say though, it's my opinion that these engines do appear to be very robust with no inherent problems. Some lemons will always exist though. (Knock on wood here big time after writing that) :-)
Bigmaxy is offline   Reply With Quote
The Following User Says Thank You to Bigmaxy For This Useful Post:
Blu-by-U (05-16-2014)
Old 05-15-2014, 08:32 PM   #101
BRZnut
Drives: BRZ DGM Limited
Originally Posted by Monogram View Post
That is not my point at all. In each and every case of engine failure, there are either mods, lack of maintenance, or major accidents involved.
I'm still waiting for someone to post a singe engine failure where the vehicle is unmodified, has been properly maintained, and/or has not been wrecked.
Next I'd like to see a cross reference of engine failures by age of driver.
How about this guy? Stock engine that self destructed when he jump started his dead battery:
http://www.ft86club.com/forums/showt...ght=jump+start
Old 05-15-2014, 09:34 PM   #102
evan
Drives: fr-s
There's a monster peeking at us from behind those ports. Feed it ($$$).
evan is offline   Reply With Quote
The Following 2 Users Say Thank You to evan For This Useful Post:
bakerr6 (05-16-2014), extrashaky (05-16-2014)
Old 05-15-2014, 09:46 PM   #103
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Seriously? Perrin Intake does not make it a stock engine. The previous one I looked at had a Perrin crank pulley and it lost a crank bearing.
This appears to be a serious over-rev situation (most likely a downshift at high rpm). There is no way this engine damage was caused by someone starting a vehicle: No way.
Yup. Looks the valves developed a close personal relationship with the piston. Definitely not caused by jumping the battery.
billwot is offline   Reply With Quote
The Following User Says Thank You to billwot For This Useful Post:
SirBrass (05-16-2014)
Old 05-16-2014, 01:26 PM   #104
extrashaky
Yes way. As I mentioned on the other thread for that failure, there are other ways a valve can hit a piston besides over-revving. I had a TR6 that once that had a valve spring break and take out the retaining clip at the top of the valve stem, allowing it to drop right into the cylinder. This was under light acceleration and was nowhere near the rev limit. The valve made contact because the part holding it in place failed, not because of interference while over-revving.
Obviously this engine is set up differently, but the first thing I thought when I saw that bit of ejected bearing on the first page of that thread was that there was a catastrophic failure in the head that allowed the valves to travel too far. That could certainly happen from a cold start.
My gut tells me the OP did absolutely nothing wrong there and just had a freak failure. I might not believe it either if I hadn't seen it happen myself on one of my cars.
SuperDave (05-16-2014)
Old 05-16-2014, 07:07 PM   #105
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
I really fucking dislike this thread.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
The Following User Says Thank You to BRZPDX For This Useful Post:
Lonewolf (05-17-2014)
Old 05-16-2014, 07:15 PM   #106
extrashaky
There is way to much damage for this to have happened at startup. I have seen many failed engines over my lifetime, and the story does not match the damage.
Could be. But my gut still tells me this is the one time when the seemingly unlikely story is actually true. From what he said, it sounds like he let it run rather than shutting it down immediately. He also said he revved it to 5000 RPM when he started it.
You saw that pile of shards that was left. If you run that engine for 15 seconds while idling at 1000 RPM and coming apart, that's 250 revolutions for all those pieces to be bouncing around in there. I seriously doubt it would take very long to amass a serious collection of divots in the head, much like what that nasty pic showed. And it sounds like he ran it longer and revved it so that he shard-blasted everything in that cylinder.
Over-revving is the obvious assumption, so I can see why one's mind might jump there. But having been on the other side of that argument ("Really! I was just driving along! I wasn't racing!"), I'm willing to give him the benefit of the doubt.
Old 05-16-2014, 08:15 PM   #107
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
A wise man once gave me a piece of advice when I was very young and it holds true to this very day.
That advice was..
"If you're gonna be stupid, you better be strong."
PRO86 | WTCC | STL
Old 05-16-2014, 08:43 PM   #108
BRZnut
plus..if you look at the end of that thread, damage was covered and his car made new again. So no fault of the OP for the failure. Also, I would not consider his Perrin intake as an engine that was modified to any great degree.
Old 05-16-2014, 09:42 PM   #109
Mr.Zoolittle
Drives: Five Axis FR-S, MR2 Turbo, TacomaDC
I was at my local dealership two days ago and the tec said they replaced a "cooked" engine in a FR-S. Makes me want to get out of this. I had an MR2 Turbo with 212k miles on it. No engine problems.
Mr.Zoolittle is offline   Reply With Quote
The Following User Says Thank You to Mr.Zoolittle For This Useful Post:
Mr 286 (05-16-2014)
Old 05-16-2014, 10:11 PM   #110
Mr 286
Mr 286's Avatar
Drives: 2014 Camry SE V6 | 1991 MR2 Turbo
I posted it to let the community be aware of another failure on a car that is driven normally in mostly city traffic, has been well maintained, not modified beyond the TRD exhaust and is one of the first of these cars to hit the dealerships.
I pretty much knew it might devolve into arguments about the reliability of these cars, or people wanting to blame my age, my driving habits, my maintenance, the accident damage, mods, solar flares or anything else but the fact that the engine simply failed and can fail even when properly maintained ...
Mr 286 is offline   Reply With Quote
Old 05-16-2014, 10:21 PM   #111
Mr 286
Mr 286's Avatar
The cars are generally very well engineered and put together, but there are some issues here and there. I've had some items serviced well before the guy backed into me. I had tons of issues with other cars like my old Mazda3, but this is the first time I bought a brand new car that needed a new engine block after less than 40,000 miles. And designing a car to run on fuel that isn't even available in most markets is absurd. Either have 93 octane or just deal with "acceptable" amounts of detonation? Get real.
My MR2 Turbo has an upgraded intercooler, running well above stock boost, 3" exhaust, suspension, and more. Even with a couple times having air in the coolant system causing it to boil over (common MR2 issue), and being driven much harder than I drive the FR-S its race-engineered 3S-GTE is still holding strong.
Nonetheless, once everything is back together and I have the car running again I'll let you guys know how it's going and my impressions of the new motor. I'll be trying to just drive it normally as before, and not be paranoid that it may be a ticking time bomb lol
Old 05-17-2014, 12:02 AM   #112
extrashaky
93 octane is available in the majority of US states. Some guy on the Corvette forum did a survey.
http://forums.corvetteforum.com/c6-c...cross-usa.html
blown engine
Engine Failure (#4 Rod Bearing + Short Block) eriktherod Issues | Warranty | Recalls / TSB 215 10-30-2015 12:24 AM
Crawford posts of engine failure example at 218hp OICU812 Engine, Exhaust, Transmission 95 03-27-2015 05:40 PM
Major accident/Engine failure after repeated P0351/P0017/P0019 DB86 Issues | Warranty | Recalls / TSB 48 09-16-2014 03:05 PM
Stock Engine Failure Annahra Issues | Warranty | Recalls / TSB 37 06-25-2014 01:42 PM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
