Old 05-15-2014, 12:48 PM   #24753
Lischynski
Weendog
Lischynski's Avatar
Drives: 2014 Scion FR-S
With an OFT, if I get new tires ave wheels, would I need to use TPMS, or would I be able to clear the tire pressure warning light?
Old 05-15-2014, 12:53 PM   #24754
B.Rice85
B.Rice85's Avatar
Drives: 2013 Subie BRZ 6MT
Originally Posted by SirBrass View Post
@OLLIS BEES! Attachment 78707
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
Thats just wrong jamie lmao
Sent from my SAMSUNG-SGH-I747 using Tapatalk
B.Rice85 is offline   Reply With Quote
The Following User Says Thank You to B.Rice85 For This Useful Post:
SirBrass (05-15-2014)
Old 05-15-2014, 01:45 PM   #24755
nelsmar
Your light will still be on. Afaik there is no way I disable it or change the pressure at which it turns on.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
Lischynski (05-15-2014)
Old 05-15-2014, 01:46 PM   #24756
Lischynski
Weendog
Lischynski's Avatar
Thanks Marin, shouldn't be a problem making it work, figured I would check.
Old 05-15-2014, 01:47 PM   #24757
nelsmar
I wish I could change the pressure setting! I ing rear tires below the warning level so my light is always on. -.-
Old 05-15-2014, 03:51 PM   #24758
B.Rice85
B.Rice85's Avatar
At least it doesnt constantly email you when they're low like my wife's car does!
Old 05-15-2014, 04:18 PM   #24759
nelsmar
I would stab my self! That's horrible haha!
Old 05-15-2014, 04:37 PM   #24760
EZWood
BAMF
EZWood's Avatar
I'd probably pull the bulb for the pressure light.
Old 05-15-2014, 05:32 PM   #24761
captain_jack
captain_jack's Avatar
I believe these bulbs are surface mounted leds though,I don't know if they are the little bulbs you can pull....
may the schwartz be with you....
Old 05-15-2014, 05:34 PM   #24762
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
They're LEDs.
^GT5 Replay Photo Mode^
Old 05-15-2014, 06:11 PM   #24763
TwoFourFive
TwoFourFive's Avatar
Drives: 13 HOT LAVA
Getting car wrapped this weekend from a buddy of mine. Gunna try and help put his name out there so if you want any vinyl done let me know!
TwoFourFive is offline   Reply With Quote
Old 05-15-2014, 06:35 PM   #24764
renfield90
The Stig's German cousin
Not difficult to remove with a solder iron, a solder vacuum, and a steady hand. Probably $20 of stuff from Radio Shack.
Unfortunately, Radio Shack does not sell steady hands.
My light is on all the time right now because my current daily drive wheels do not have TPMS. It's just another light.
I would recommend simply ignoring the light. But I would recommend more strongly that you run higher tire pressures. Correct tuning of tire pressures involves selecting the highest pressure possible before the tire starts to round off into a torus, and if you're low enough to trip the light I doubt you're there.
The Following User Says Thank You to renfield90 For This Useful Post:
Ninjin (05-15-2014)
Old 05-15-2014, 07:06 PM   #24765
B.Rice85
B.Rice85's Avatar
If it was my car I would just cover the light with a drop of black rtv silicone. Its thick, black and non-conductive. And it can be removed easily later down the road.
Old 05-15-2014, 07:23 PM   #24766
Cross
It's the Mad Cow
Cross's Avatar
Was it you that recently did the blue wrap? I look forward to seeing the results what color are you going with?
