Old 05-09-2014, 02:41 PM   #1
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Spacers and wheel wobble.
So I recently got spacers and the spacer sits flush on the hub and from what I an tell the wheel is sitting flush against the spacer. But when I drive, I can see my wheel wobbling on both sides. Any reason why this would happen?
Chen is offline   Reply With Quote
Old 05-09-2014, 02:50 PM   #2
wparsons
wparsons's Avatar
Wobbling in which direction? Up and down, or side to side?
flickr
Old 05-09-2014, 04:49 PM   #3
Chen
Regional Moderator
Chen's Avatar
Side to side.
Old 05-09-2014, 04:50 PM   #4
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
Are they hubcentric?
mkivalex is offline   Reply With Quote
Old 05-09-2014, 05:05 PM   #5
Chen
Regional Moderator
Chen's Avatar
They are. But I have have figured out the problem. It looked like when I bolted my wheels onto the spacer. It looks like my wheels are against the lug nuts. Do they offer shorter luts to hold spacers?
Old 05-09-2014, 08:26 PM   #6
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Some wheels have pockets on the back face to accomodate studs poking out, to an extent. Mine have this and I still needed 22mm in order for the wheel to mount flush to the spacer.
Alternately, you can grind/cut your studs down. You can also sell the wheels and get a set that has the offset you want without spacers. I'm not aware of any shorty studs, usually they're stock (about 1") or 3" extended.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-09-2014, 09:17 PM   #7
Chen
Regional Moderator
Chen's Avatar
My wheels do have pockets. And the studs go into the pocket. It's the nuts now.
Old 05-09-2014, 11:28 PM   #8
kberkel
kberkel's Avatar
So you have the pockets in between the holes like this, but the pockets aren't wide enough to accommodate the nuts?
kberkel is offline   Reply With Quote
Old 05-10-2014, 09:12 AM   #9
wparsons
wparsons's Avatar
Get some OEM open ended nuts? That might buy you a couple mm of clearance, which by the sound of it is probably all you need.
flickr
Old 05-14-2014, 06:39 PM   #10
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Whew, it's a good thing that YOU figured it out. By yourself. LOL
Old 05-15-2014, 03:22 PM   #11
Chen
Regional Moderator
Chen's Avatar
Correct.
That's where I'm running into trouble. I can't find any. And I'd what mm I will need or where to will find it.
Haha yes..... All by myself.
The Following User Says Thank You to Chen For This Useful Post:
DarrenDriven (05-15-2014)
Old 05-15-2014, 03:32 PM   #12
Vten
Drives: Too heavy
I believe I had the same problem with my spacer nut being to tall ... I believe it was 17mm tall. I bought the 12mm one off one of the eBay seller and it cleared my problem.
If you still need them I can check the eBay seller , shoot me a pm with your email so I can forward the email to you . Hope this help.
Vten is offline   Reply With Quote
Old 05-15-2014, 04:34 PM   #13
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
It's surprising to hear the ones that came with it were too long. What brand are these?
Jason@DSG is offline   Reply With Quote
Old 05-15-2014, 04:54 PM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Go to a hardware store and get some standard nuts in 12x1.25 size.
FS 20mm NEW Wheel Spacers 86_Otaku Wheels and Tires 5 03-18-2014 12:01 AM
where to get wheel spacers bhbnuckle CANADA 0 03-15-2014 02:40 PM
FS: 30mm wheel spacers woode Wheels and Tires 5 03-15-2014 10:16 AM
WTB: Wheel Spacers bhbnuckle Canada Classifieds 0 03-15-2014 01:37 AM
H&R Wheel Spacers! vividracing Wheels and Tires 3 06-19-2012 06:11 PM
