Old 05-13-2014, 04:12 PM   #2213
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
Originally Posted by JdelFrs View Post
Don't know... they are looking at the case but WCI do not have the best Customer service....
Man I'd be pissed! If you have a clear indication that you ordered a certain offset and they sent the wrong offset its on them. I'd fight that to the end
mkivalex is offline   Reply With Quote
Old 05-13-2014, 04:13 PM   #2214
mkivalex
@blags that setup looks so flush and perfect, But when I look at other cars with a similar offset to what you listed (18x10 Et 20), they require much more camber. I love your set up but I just don't kknow how your fitting an 18x10 ET 20 without stupid camber or with crazy poke
Are you sure those are the specs?
The Following User Says Thank You to mkivalex For This Useful Post:
blags (05-13-2014)
Old 05-13-2014, 05:34 PM   #2215
blags
Drives: Toyota 86
Originally Posted by SupremeOrigin View Post
@blags did you have to do any body work to get that fitment to work?
Don't mean to copy but I know for a fact that I want to go with the Work MEISTER S1R
18" . I also plan on doing sti Brembos since I still have mine that I bought for my Wrx a couple years back. And I'm wondering if the O-Disk size will work?
Thank you
To be safe, a quick roll on the rear and had to cut the rear bar tab. No idea if o-disk will work with brembos... perhaps someone else can chime in and answer this?
blags is offline   Reply With Quote
Old 05-13-2014, 05:53 PM   #2216
SupremeOrigin
Drives: 14' FRS, 90' Miata
Rear bar ? Sorry.
SupremeOrigin is offline   Reply With Quote
Old 05-13-2014, 11:36 PM   #2217
636
636's Avatar
Drives: '23 CWP BRZ
Just bought some 18x10 +25's! Nothing too crazy, but better than my 18x9.5 +38's right now. Looking for some moar camber.
Hopefully should be able to fit them with -3 up front, and -5 out back.
I'm sitting at -1.5, and -3.5 right now perfectly fine with room to spare. Think I'll be alright?
Also, anyone have any axle problems with that much camber? Sorry for the 21 questions. :P
636 is offline   Reply With Quote
Old 05-14-2014, 03:19 AM   #2218
blags
Drives: Toyota 86
Thanks dude. 18x10 +23 is the rear, the front it +20, I always get them mixed up. It's only 3mm difference, not very noticeable. Camber was around -3 degrees. I guess others add more camber to tuck them in further to avoid damaging things.
Old 05-14-2014, 03:21 AM   #2219
blags
Drives: Toyota 86
Rear bar ? Sorry.
Where the rear bar meets the quarter panel, I cut some of that off because my tyres were hitting.
Old 05-14-2014, 03:20 PM   #2220
stancypants
stancypants's Avatar
Drives: FR-s
you will be fine and you are about right now with the camber. I ran 10.5 +30 and was running -6.5 camber in the rear. Should look great cant wait to see it.
stancypants is offline   Reply With Quote
The Following User Says Thank You to stancypants For This Useful Post:
636 (05-14-2014)
Old 05-14-2014, 10:03 PM   #2221
Bizborky
Drives: 2013 WRX
Originally Posted by FRSdrive View Post
WOW!!!
16s? 17s?
Car looks awesome!
Bizborky is offline   Reply With Quote
The Following User Says Thank You to Bizborky For This Useful Post:
FRSdrive (05-16-2014)
Old 05-15-2014, 10:52 PM   #2222
Mcpot132
Drives: Hopefully a BRZ!
Originally Posted by Juvenile View Post
Attachment 75026
Specs unknown
VERY AWESOME
Mcpot132 is offline   Reply With Quote
Old 05-16-2014, 01:28 PM   #2223
JdelFrs
Drives: 2013 Fr-S Release Series 10 (MT6)
Rear starting to look good I should order the front LCA !
JdelFrs is offline   Reply With Quote
The Following 2 Users Say Thank You to JdelFrs For This Useful Post:
Kosmos (05-16-2014), WhiteLightning (05-16-2014)
Old 05-16-2014, 01:48 PM   #2224
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Originally Posted by Speed Element View Post
Those wheels....()()
are soooo aggressive...
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 05-16-2014, 02:14 PM   #2225
mkivalex
Would I have any issues with the airlift bags rubbing or hitting with about 2 degrees of negative camber on an 18x9.5 ET 35 front set up? I want to try and fit it with proper tires (255/35/18). I know its a lot to fit in there but do you guys think its doable?
Old 05-16-2014, 02:17 PM   #2226
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
You might need to stretch your tires
Sent from my SM-N900P using Tapatalk
Kosmos is offline   Reply With Quote
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
