Old 05-12-2014, 07:53 PM   #57
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Originally Posted by murselyfe View Post
When installed on KW V3s, does it create an additional lowering in the front? If so... how much?
About 3/8", IIRC.
BTW, since I have it apart, here are some pics of the spring perch showing the integrated torrington bearing. Note the black rubber seal on the brass part that seals the bearing into the top part of the perch and keeps it clean. Note also that there should actually be two washers, one for each side of the bearing. I discovered one was missing when I was preparing to put the car together, must have flown somewhere during the disassembly process last fall.
Ground Control took care of me and got me a replacement washer at no charge, and in only two business days.
neurokinetik is offline   Reply With Quote
Old 05-13-2014, 12:27 AM   #58
autoXracer
Drives: 2013 WRB BRZ
It lowered roughly about 1/2 inch.
autoXracer is offline   Reply With Quote
Old 05-13-2014, 12:36 AM   #59
autoXracer
I've had the camber plates on the car for 2 months now, and so far no issues. I'm happy with the product and also with gound-control customer service.
Old 05-13-2014, 01:43 AM   #60
murselyfe
murselyfe's Avatar
Drives: It's black.
Nice, thanks for the replies guys. Also, thank you @neurokinetik for the side note. I'm expecting my plates in a couple days.
2013 Subaru BRZ Limited- Crystal Black Silica
murselyfe is offline   Reply With Quote
Old 09-09-2014, 12:05 PM   #61
Top-Secret
Drives: FRS monogram
@GC_Adam will these work with stock shocks and RCE Springs?
Top-Secret is offline   Reply With Quote
Old 09-09-2014, 08:18 PM   #62
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
No, they are designed for 2.5" "coilover" springs. Look at HVT or raceseng for hats that will work with stock diameter springs.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 09-12-2014, 08:37 AM   #63
Top-Secret
next question since iv now opted out on getting springs now. @GC_Adam or anyone else that can answer this
the kit on the website they have has the koni shocks with eibach springs? whats the different spring rates they offer as it just says touring/race/aggressive and is it possible to opt for a different set though GC. havent heard anything good about eibach in awhile so im trying to stay away.
but if not, how do the koni/eibach combo compare to KW3s
Old 04-12-2015, 07:04 PM   #64
jdmblood
jdmblood's Avatar
Drives: white subaru brz
bringing back an old thread here i know. does anyone know if these would work with a set of tein street basis coilovers?
jdmblood is offline   Reply With Quote
Old 01-01-2018, 03:13 AM   #65
Archfarseer
Drives: 2013 Scion FR-S, 2007 Porsche 911
Originally Posted by AX FRS View Post
I purchased GC's complete suspension kit for my FR-S.
Installed it and was able to get only 2.1 degrees negative camber in the front. I wanted 3.0+. Discussed this with Adam and he said he'd check with the engineers and call back. I think I was the first FR-S for their suspension kit.
He called back 2 days later and said the engineers had built different shock towers and they were on the way to me (at no cost). Installed them and was able to get 3.0+ negative no problem. The handling (autocross) on the car is now really good at 3.0.
GC's customer service with Adam is outstanding. He kept me posted on what was being done to fix the problem.
I highly recommend Adam and GC for your suspension upgrades on these cars.
Jim H.
DFW, Texas
@AX_FRS were you able to get -3.0 in the front? I got my GC full suspension in 2017, but max front camber is -2.5.
Archfarseer is offline   Reply With Quote
Old 01-01-2018, 03:42 AM   #66
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Before resurrecting a thread and posting a question you might like to check the activity of the person you are asking.
http://www.ft86club.com/forums/member.php?u=7762
Last Activity: 09-06-2013 02:03 PM
Archfarseer (01-02-2018)
Old 01-02-2018, 11:09 AM   #67
Archfarseer
oops, got it. Sorry still new to the forum thing.
Ground Control faq/video/picture/ideas thread GC86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 57 03-29-2014 10:54 AM
Ground Control for 86/FRS/BRZ phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 11-14-2012 07:56 PM
Considering the Ground Control Setup dale.m Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 11-14-2012 01:05 PM
Ground Control needs your Help GC_Adam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 11-13-2012 05:08 PM
Ground Control is working on some stuff for us :) D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-24-2012 06:21 PM
