Old 05-10-2014, 03:53 AM   #43
steve99
Drives: FT86
Originally Posted by Turdinator View Post
I updated to OFM 1.08.0 last night and then did my log today. Could it be it just hasn't been updated on the 700G roms? Or do I need to download something extra?
download and apply latest template file as well
Turdinator (05-10-2014)
Old 05-11-2014, 12:14 PM   #44
phrosty
Originally Posted by wparsons View Post
C# is what I do, porting to a web app would be trivial!
Sorry for the delay, car's been in the shop after being vandalized. Took some time to clean up the code and added OL scaling too:
https://github.com/scalablecory/scalemaf
phrosty is offline   Reply With Quote
Old 05-11-2014, 10:50 PM   #45
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Kodename47 View Post
The simple solution is to zero out the IAT compensation table while scaling the MAF. You should really do that to all compensation tables while calibrating for that very reason.
On ECUtek you fill the table with values of 1, RR is 0.
The IAT compensation isn't a simple hot/cold +/- as it reverses as air volume increases too. I would return the stock table when you've done calibration.
Now I'm getting really anal with my MAF scale, I've found that the intake air temp correction to be somewhat inconsistent to what I found earlier with around 95 vs 75 temps once the IAT get lower than 68 degrees... now the question is to zero or not to zero the IAT compensation tables or not. What do you guys think? Any thought or advice on the temp compensation, or just deal with it as is?
Old 05-11-2014, 11:18 PM   #46
vgi
Drives: frs
fyi, updated proggie is now posted.
vgi is offline   Reply With Quote
Old 05-11-2014, 11:45 PM   #47
phrosty
We have the compensation tables... it seems like we should be able to anti-compensate to get more accurate corrections.
Old 05-12-2014, 12:23 AM   #48
solidONE
solidONE's Avatar
Link?
Old 05-12-2014, 12:40 AM   #49
solidONE
solidONE's Avatar
I would think so, but the compensation tables are a bit strange. It is zeroed at 68 degrees and at 11.23 g/s. At temps of 104 or above the compensations below 11.23 g/s is negative, but anything over 11.23 g/s it goes to positive. The inverse is true for temps below 68 degrees. Not sure of the logic behind this. I'd like to learn more about why it is done this way before making any changes.
Old 05-12-2014, 02:36 AM   #50
Kodename47
Kodename47's Avatar
Drives: UK GT86
I can't work it out, it must be due to the behavior of air at those temperatures.
As for zeroing out the IAT comp, just do it while doing the MAF and then put them back as stock would be my recommendation.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-12-2014, 07:07 AM   #51
steve99
Drives: FT86
I suspect the table is correcting for errors in the maf sensor behaviour due to temperature rarther than trying to compensate for air density changes, i suspect that calculation is done in ecu code somewhere using iat.
Old 05-12-2014, 07:27 AM   #52
vgi
Drives: frs
Link?
Same place, link is on RR forum and I believe has been posted here.
The Following User Says Thank You to vgi For This Useful Post:
solidONE (05-12-2014)
Old 05-12-2014, 08:25 AM   #53
Turdinator
Señor Member
Turdinator's Avatar
I noticed a while ago that the car felt the nicest to drive when the outside temps were around 20c. If we could tweak the table for more performance when cold and a tad safer when warm I'd be very happy.
1974 TA22 Celica
2013 86 GT
Old 05-12-2014, 04:50 PM   #54
solidONE
solidONE's Avatar
If there is a temp compensation table for ignition advance, it can be done. The nicer feeling you're getting at 20c is probably just the increased power from cooler iat. Though, this engine seems more knock prone when temps are higher. The iat compensation for maf scale will only dictate how much or little fueling correction the computer will make to hit your target afr.
Old 05-12-2014, 05:30 PM   #55
Kodename47
Kodename47's Avatar
Drives: UK GT86
The IAT is a load compensation table, not MAF.
There are 2 ignition timing vs IAT tables, one that changes timing depending on IAT and the other determines the % of that applied depending on RPM and load.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-12-2014, 08:04 PM   #56
solidONE
solidONE's Avatar
Really? So it's the load that gets adjusted... that would explain the relatively low % of adjustment in the table, I guess. I've decreased the entire IAT compensation table by .4%. I'll see if it has the desired result.
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 08:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 02:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
