Old 12-23-2013, 05:37 PM   #1247
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Originally Posted by jonbatz01 View Post
will give that a try mate, tested the ELM with my android phone so im thinking its the bluetooth dongle at fault.
I am gonna try to see if the bluetooth could work by itself to eliminate the splitter as faulty.
Missed that you were in Oz rather than USA ( the mate gave it away!). Here's one on the Oz ebay site http://www.ebay.com.au/itm/New-Bluet...4c8919c&_uhb=1
My sister lives in Perth. Beautiful place but stinking hot for us Wellingtonians!
nzer is offline   Reply With Quote
Old 12-23-2013, 05:42 PM   #1248
jonbatz01
jonbatz01's Avatar
Drives: ZD8
haha cool! yes it is hot! im in Perth too
just to confirm, is this the screen you get when Bluetooth isn't compatible?
Sent from my GT-I9100T using Tapatalk 2
EOJ | PERTH | ZD8
jonbatz01 is offline   Reply With Quote
Old 12-23-2013, 05:46 PM   #1249
nzer
nzer's Avatar
Yep, that or goes away and tries to connect and keeps connecting and disconnecting. For A$10 you may as well try another dongle.
Old 12-23-2013, 06:22 PM   #1250
jonbatz01
jonbatz01's Avatar
Drives: ZD8
Sweet mate! new dongle it is! Thanks for the help! will let you know how it goes in the new year.
So for those wanting to try this root. Targus 4.0 Bluetooth Dongle doesnt work.
http://www.ebay.com/itm/TARGUS-BLUET...item3cda2b17dc
EOJ | PERTH | ZD8
Old 12-24-2013, 02:28 PM   #1251
GreenPants
Drives: Burnt Orange GT86
Originally Posted by nzer View Post
Might mean this thread becomes a little redundant and even misleading if someone buys the 4.1.1 unit and bricks it with these root files.
Maybe @2forme could amend the OP to have a big warning that this is only for the android 2.3 version.
From what I've seen/heard, the 4.1 units use a different set of files so shouldn't be an issue - but I'll update the FW thread anyway.
GreenPants is offline   Reply With Quote
Old 02-13-2014, 10:44 PM   #1252
chris's fr-s
@theexquisite86
chris's fr-s's Avatar
Drives: 2013 Firestorm FR-S
Any info on the pumpkin android unit?
ML24 widebody, FA20 turbocharged, Avant Garde wheels sponsored 2013 Scion FR-S
Instagram:Theexquisite86
chris's fr-s is offline   Reply With Quote
Old 02-16-2014, 04:19 AM   #1253
mrlizard
Drives: BT50
Hello everyone again
I'm starting to get a little bit bored with my normal display and apps (still all the same as when you root it) what does your head unit screen look like and what apps do you find helpful.
mrlizard is offline   Reply With Quote
Old 02-19-2014, 07:28 PM   #1254
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Im working on a custom one right now. Full custom startup, home screen and torque gauges to match my brz, coming together really nice. Here is the RPM gauge. I wanted it to look similar to the stock brz. I did add my own little take on it, but overall, its how i wanted it. Real easy to make however i want. You cant see the needle, numbers or tick marks, etc. Because this is the mockup, and not the live torque, but it looks good, i just need to take some screenshots in the unit. I have it out of the car right now as i am working on the customs mounts and stuff.
Main thing i use is Nova launcher, that allows custom homescreen. Also looking into tasker, to setup custom things to launch, shutdown, etc based on certain criteria. I will post some screenshots soon.
To be clear im using a nexus7.
gdrider77 is offline   Reply With Quote
Old 02-25-2014, 02:21 AM   #1255
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
Hey guys, I'm having really bad problems with my unit. I bought it off of ph0en1xtk and it was pretty much plug and play. He did all the work and rooted it, but it's been giving me problems since I got it. I would be driving, then you'd hear a pop and the unit would shut off. In order to turn the unit back on, I'd have to push on the screen to turn it back on. The warranty is up and I'm pretty much running out of options. It's a tu21a unit I believe. I thought it was acting this way because maybe some electrical tape got off and wires were touching, but I cleaned up everything and wrapped everything perfect and it's doing it more than ever now. If anyone can chime in and let me know what's wrong, that would be great.
Also, my AC lights don't work. Not sure why. If anyone knows what wires I'm supposed to use to get those working, that'd be great. ph0en1xtk didn't like the lights on the head unit, so he took off them I guess by disconnecting a wire. I would like the head unit lights back on and also my AC lights. thanks.
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
enjoi23 is offline   Reply With Quote
Old 05-11-2014, 05:05 PM   #1256
DC2R
Drives: 2014 Scion FR-S
Have 4.1 unit. Boots but no response from touch/buttons. Ideas? Really don't want to send back.
DC2R is offline   Reply With Quote
Old 05-11-2014, 05:12 PM   #1257
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Before try a reset (hard reset) and then if freezy too try to flash with fw #2.7.9, a friend of mine just this morning solved this way under my suggest.
here you can find all infos.
http://forum.xda-developers.com/show....php?t=2528349
Warn..if you get troubles...start with System Version 2.6.40 and then update to System Version 2.7.9
Trap63 is offline   Reply With Quote
Old 05-11-2014, 05:18 PM   #1258
DC2R
Tried reset with all variations of reset button but just sends to be a power reset
Sent from my SM-G900T using Tapatalk
Old 05-11-2014, 05:19 PM   #1259
DC2R
My unit is DashLink4. Had A8 processor. Wil these files for A9 processor work?
Old 05-11-2014, 05:21 PM   #1260
Trap63
Trap63's Avatar
This FW is ONLY for HU Android 4.1
Hardware
CPU: ARM Cortex A9 MST786 Dual Core 1GHz
GPU: Mali-400 MP
RAM: SKHYNIX 1G DDR3 RAM H5TQ4G83AFR
iNAND: SanDisk 8GB SD1N5C2-8G (1GB system storage, 6GB internal USB storage)
MCU: STM8AH ST
Bluetooth: BlueCore5 CSR
Screen: Capacitive 800*480
GPS: SiRF Atlas V GPS Processor
Radio: Philips TEF6624
Sound Effect Processor: BD37534 ROHM
Outputs: 4x 45w outputs, Toshiba TB2929
Additional Outputs: 1x Subwoofer, 4x pre-outs
Microphone: Built in microphone
IF YOU HAVE A8: you run Android 2.3
not 4.1
Operation System: Android 2.3.4
CPU: FREESCALE I.MX535D Cortex A8 1GHz
see here http://forum.xda-developers.com/show....php?t=2110546
and here for fw upgrade, v4 is the latest one http://www.ft86club.com/forums/showp...78&postcount=1
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-19-2013 11:51 PM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 10:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 03:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 05:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 10:47 PM
