Old 05-10-2014, 03:35 PM   #491
DC2R
Drives: 2014 Scion FR-S
Originally Posted by xjohnx View Post
Just tested, bingo! Thanks a ton for this! Have you had any luck adding other bluetooth profiles or using different radio apps?
go for it. you're safe!
Going to reset mine and do this now. Then i got to move brackets, add hub, relocate GPS/Wi-Fi. Thinking of putting modules where stock GPS goes...right above gauge cluster. Maybe I can get better Wi-Fi receptionthat way
Sent from my SM-G900T using Tapatalk
DC2R is offline   Reply With Quote
Old 05-10-2014, 03:45 PM   #492
xjohnx
Grip>Slip
xjohnx's Avatar
I can't imagine any scenario shy of installing the wifi adapter in a lead box that would cause wifi reception issues in a car of our size. What kind of reception issues are you experiencing?
Old 05-10-2014, 04:25 PM   #493
DC2R
Live in apartment so no access to Wi-Fi at home. I setup another AP near the front of my office so I could get some Wi-Fi at work. I can stream using Wi-Fi tethering but rather not use it for downloads, etc..currently outside Starbucks rooting. Should I wait after entering terminal command to reboot? Very slow for last five minutes but don't want to interrupt if it's doing something.....
Old 05-10-2014, 06:14 PM   #494
DC2R
Wooohooo. Just rooted! New dongle on the way. Shame about partition size. Have to delete apk every few installs. Custom recovery would be icing on the cake. I saw in that post on xda other firmware....compatible?
Old 05-10-2014, 06:52 PM   #495
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Excited for what the future leads with this. Now to pony up the cash.
sent from HTC one M8 while driving
cruizin01 is offline   Reply With Quote
Old 05-10-2014, 07:09 PM   #496
DC2R
Check briefly but not able to read cpu speeds. Overclock and performance setting in kernel would rock
Sent from my GT-N5110 using Tapatalk
Old 05-10-2014, 07:55 PM   #497
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Have you guys that rooted been able to do any of the things you wanted to do? Like change the default applications that open from the physical buttons or the home screen launcher? I would be interested in knowing how difficult that kind of stuff is. My only Android experience is this head unit and the stock Nexus 7 I'm typing this post on.
Prog is offline   Reply With Quote
Old 05-10-2014, 08:00 PM   #498
DC2R
I haven't yet. Got put back some. I reset unit due to issues. GPS button goes to Google maps via regular setting in menus. Downloaded offline map of my area.
I plan to download some sort of button mapping app. I'll probably use Titanium backup to freeze the launcher that runs on top of stock launcher and then install Apex launcher.
I'd like to also get a Recent Apps button.
I use LMT on my phone and tablet so maybe I'll do that.
Old 05-10-2014, 10:20 PM   #499
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Whoa... crazy developments in this thread since I had time to look last.
Awesome.
and I was just going to post that netflix works great, watched a movie in the car wash today
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
The Following User Says Thank You to SHIFTER For This Useful Post:
DC2R (05-11-2014)
Old 05-10-2014, 10:20 PM   #500
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Originally Posted by burmjeff View Post
Here I took some pics for you:
wow that looks great in the kia! how was the install of the unit?
Andrew
Old 05-11-2014, 12:22 AM   #501
DC2R
Just got everything patched up, drive home, parked, came back out, and I got no sound. Tried rebooting a couple times, killing all apps, tried radio, Bluetooth, sdcard, USB. Any ideas? Couldn't imagine apparent harness would come loose while parked....
Old 05-11-2014, 04:39 AM   #502
DC2R
Update: did more troubleshooting and now radio it's unresponsive. Tried reset button and pulling battery. Just boots but controls do nothing. Prior to troubleshooting forgot to mention Wi-Fi would not come on.
Old 05-11-2014, 09:47 AM   #503
xjohnx
Grip>Slip
xjohnx's Avatar
Ok, so it looks like the OBDlink sx USB cable does work on torque too, at least it did last night.
I'd highly recommend a USB cable over the bluetooth one. Refresh rates are MUCH faster, meaning less lag on the display.
Old 05-11-2014, 10:28 AM   #504
burmjeff
Drives: Kia Optima
The install was actually pretty easy. After watching someone do it on youtube it took me like 15 minutes to disassemble everything.
The wiring is a different story haha. Some of the wires on mine were actually mislabeled/miscolored so I had to go by the diagram on the top of the head unit.
Then after everything was put back in place.... The sound only came out of one speaker, took me a while to realize it was something as simple as the the balance needs to be slightly right and down. I guess it's because I have the harness that allows me to use the 8 speakers and amplifier in the car.
Still not sure exactly about the backup camera, I assume its this last unplugged wire that I will have to cut into and add an RCA connector.
burmjeff is offline   Reply With Quote
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
