Old 05-10-2014, 04:21 PM   #15
jflogerzi
jflogerzi's Avatar
Stories like this really make me hesitant to boost the twins
The Following User Says Thank You to jflogerzi For This Useful Post:
FRS_FIEND (06-25-2014)
Old 05-10-2014, 04:25 PM   #16
BRZnut
Drives: BRZ DGM Limited
I feel the same way. Everyone says a proper tune will make a boost "safe" but I don't buy it after reading about engine failures like this one (if that is what it turns out to be)
Old 05-10-2014, 05:07 PM   #17
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Eeekkk.... curious as to what happened.
N1rve
Old 05-10-2014, 05:10 PM   #18
Annahra
Annahra's Avatar
Drives: 2014 WRB BRZ LTD
Mine blew at 37K. This makes me less inclined to think it was due to the year old front end repair. Especially since they gave me no trouble whatsoever about replacing the engine, even knowing about the previous work.
Sent from my SPH-L720 using Tapatalk
Annahra is offline   Reply With Quote
The Following User Says Thank You to Annahra For This Useful Post:
Mr 286 (05-12-2014)
Old 05-10-2014, 05:12 PM   #19
Muskokan
Drives: white Sport-tech
How long on that oil? Last time checked? Go through any overly big puddles lately? Check air filter lately? Notice any smoke from the exhaust after warm up? ANY sign of anything going bad?
Muskokan is offline   Reply With Quote
The Following User Says Thank You to Muskokan For This Useful Post:
strat61caster (05-11-2014)
Old 05-10-2014, 05:22 PM   #20
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Keep us posted. Sure all will be resolved without any headaches. Good luck buddy.
AVodka14 is offline   Reply With Quote
The Following User Says Thank You to AVodka14 For This Useful Post:
Mr 286 (05-12-2014)
Old 05-10-2014, 05:25 PM   #21
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
dammm should be covered by warranty.. yeah keep us updated
Old 05-10-2014, 05:50 PM   #22
DAEMANO
Time Traveller
Sorry about your car OP.
Still $14k of collision damage could have netted some impact on the engine that was not diagnosed during the original repair. This one I wouldn't lump with other failures on that reason alone.
The Following 11 Users Say Thank You to DAEMANO For This Useful Post:
Creole (06-09-2014), evan (05-10-2014), FRSBRZGT86FAN (06-10-2014), ftc~brz (05-16-2014), Lonewolf (05-10-2014), Mr 286 (05-12-2014), Pseud0logik (05-13-2014), strat61caster (05-11-2014), transition (05-23-2014), tyrantcf (05-11-2014), zoth (05-14-2014)
Old 05-10-2014, 06:42 PM   #23
Pish
#teamswagoi
Pish's Avatar
Drives: 2014 Raven FR-S Monogram
Man that sucks , hopefully everything goes well man .
On the bright time you get to spend some quality time with old faithful
Pish is offline   Reply With Quote
The Following 2 Users Say Thank You to Pish For This Useful Post:
Mr 286 (05-12-2014), SirBrass (05-12-2014)
Old 05-10-2014, 06:52 PM   #24
evan
Drives: fr-s
The motor is fine. There are flukes in any mass produced object. People would be surprised at how many iPhones Apple "swaps" under warranty. Yet, the phones are held in the highest regard in terms of build quality.
evan is offline   Reply With Quote
The Following 6 Users Say Thank You to evan For This Useful Post:
Creole (06-09-2014), FRSBRZGT86FAN (06-10-2014), Pseud0logik (05-13-2014), samisons (05-11-2014), Sportsguy83 (05-11-2014), strat61caster (05-11-2014)
Old 05-10-2014, 06:52 PM   #25
evan
Drives: fr-s
That was one of many thoughts I had.
The Following User Says Thank You to evan For This Useful Post:
DAEMANO (05-10-2014)
Old 05-10-2014, 07:05 PM   #26
jflogerzi
jflogerzi's Avatar
While you are right I guess my issue is if I were to boost my car and something did happened, it would hurt financially. This post just reinforces you gotta pay to play.
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
The Following 3 Users Say Thank You to jflogerzi For This Useful Post:
evan (05-10-2014), Mr 286 (05-12-2014), Sportsguy83 (05-11-2014)
Old 05-10-2014, 07:11 PM   #27
evan
Drives: fr-s
That is correct. It will hurt financially. If you can support your hobby without straining your wallet, then all power to you. While I am fortunate to be able to do so, I am sometimes attracted to the idea of a factory reinforced/high-power car and keeping the warranty. Yes the initial outlay is higher, but over time it amounts to less headaches and money spent. Problem is, modding is addictive regardless. Once you catch the bug, it's really hard to shake off.
Old 05-10-2014, 07:53 PM   #28
Annahra
Annahra's Avatar
Originally Posted by Monogram View Post
How many major engine failures are on record where there was no tune, no aftermarket parts, vehicle has not been in a major accident, etc.?
Define "major." OP had $14K of cosmetic damage. Is that major if it's not mechanical?
blown engine
Engine Failure (#4 Rod Bearing + Short Block) eriktherod Issues | Warranty | Recalls / TSB 215 10-30-2015 12:24 AM
Crawford posts of engine failure example at 218hp OICU812 Engine, Exhaust, Transmission 95 03-27-2015 05:40 PM
Major accident/Engine failure after repeated P0351/P0017/P0019 DB86 Issues | Warranty | Recalls / TSB 48 09-16-2014 03:05 PM
Stock Engine Failure Annahra Issues | Warranty | Recalls / TSB 37 06-25-2014 01:42 PM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
